Home » Newcomers » Newcomers » Problem debugging Java classes
Problem debugging Java classes [message #120146] Mon, 28 November 2005 11:36 Go to next message
Originally posted by: respond_to_newsgroup.nowhere.com
I'd like to set breakpoints in swing classes, but every time I try, I get an
error message about "Missing Line Information". I've attached the correct
src.zip to the Java classes, and I'm running the application with Sun
1.5.0_04. Any ideas? Anything in preferences I should check? I'm running
Eclipse 3.1.1.
Re: Problem debugging Java classes [message #120223 is a reply to message #120146] Mon, 28 November 2005 13:47 Go to previous message
"Sarah" <respond_to_newsgroup@nowhere.com> wrote in message
news:dmfbn3$clh$1@news.eclipse.org...
> an error message about "Missing Line Information". I've attached the
> correct src.zip to the Java classes, and I'm running the application with
> Sun 1.5.0_04. Any ideas? Anything in preferences I should check? I'm
> running Eclipse 3.1.1.
I found a solution to this problem--setting the JDK as the JVM for the
project, rather than the JRE, allows me to set breakpoints in the Java
classes.
Previous Topic:Eclipse Public License v1.0
Next Topic:How to make property view values non-editable
Current Time: Thu Oct 16 07:47:11 EDT 2025
Powered by FUDForum. Page generated in 0.07751 seconds
