Home » Archived » Test and Performance Tools Platform (TPTP) » Anyone who modified startup script of JBoss "run.sh" for TPTP Profiler, pls show me
Anyone who modified startup script of JBoss "run.sh" for TPTP Profiler, pls show me [message #120102] Thu, 03 January 2008 09:41 Go to next message
Originally posted by: takashi.s.interplay.blogdns.com
Hello there,
I try to profile remote JBoss Server running in LINUX(64bit SUSE).
Environmental details are
OS: SUSE 9.3 (64bit)
Eclipse: 3.2
Java: 1.5.0_10
Target Server: jboss-4.2.2.GA
TPTP (Installed from Eclipse)
TPTP Agent controller 4.4.0.3
I modified JBoss startup script "run.sh" like this,
(This is between line 178 and 191)
# Setup JBoss specific properties
JAVA_OPTS="-Dprogram.name=$PROGNAME $JAVA_OPTS"
JAVA_OPTS=" -agentlib:JPIBootLoader=JPIAgent:server=enabled;CGProf
$JAVA_OPTS"
# Setup the java endorsed dirs
JBOSS_ENDORSED_DIRS="$JBOSS_HOME/lib/endorsed"
# For Cygwin, switch paths to Windows format before running java
if $cygwin; then
JBOSS_HOME=`cygpath --path --windows "$JBOSS_HOME"`
JAVA_HOME=`cygpath --path --windows "$JAVA_HOME"`
JBOSS_CLASSPATH=`cygpath --path --windows "$JBOSS_CLASSPATH"`
JBOSS_ENDORSED_DIRS=`cygpath --path --windows "$JBOSS_ENDORSED_DIRS"`
fi
I added this statement around line 180,
$JAVA_OPTS"
After editing it, I tried to startup JBoss with this modified script and got
this error.
# An unexpected error has been detected by HotSpot Virtual Machine:
# SIGSEGV (0xb) at pc=0x00002aaaae3bf4b1, pid=4820, tid=47377350654720
# Java VM: Java HotSpot(TM) 64-Bit Server VM (1.5.0_10-b03 mixed mode)
# Problematic frame:
# J java.nio.ByteBuffer.arrayOffset()I
# An error report file with more information is saved as hs_err_pid4820.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
../run.sh: line 248: 4820 Aborted "$JAVA"
$JAVA_OPTS -Djava.endorsed.dirs="$JBOSS_ENDORSED_DIRS" -classpath
"$JBOSS_CLASSPATH" org.jboss.Main "$@"
What causes this error??? Does anyone face problem??
In my opinion, it is caused by my added statement.
Because when I delete the statement, it starts well.
Therefore, there might be some error in my added statement below,
$JAVA_OPTS"
Could anyone specify the error of it?? Also, if it's possible I want to see
the file collectly edited.
Because I got no information when I tried to google....
Best regards
Takashi
Re: Anyone who modified startup script of JBoss "run.sh" for TPTP Profiler, pls show me [message #120937 is a reply to message #120102] Wed, 16 January 2008 07:16 Go to previous message
Takashi,
Can you please post the JVM crash log file?
Asaf
> Hello there,
> Eclipse: 3.2
> Java: 1.5.0_10
> $JAVA_OPTS"
> if $cygwin; then
> fi
> $JAVA_OPTS"
> this error.
> $JAVA_OPTS"
> Best regards
> Takashi
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Previous Topic:Running TPTP AGR tests from ant script
Next Topic:problems in WAS 6.1
Current Time: Sat Oct 18 22:13:18 EDT 2025
Powered by FUDForum. Page generated in 0.24062 seconds
