Home » Archived » BIRT » Error in viewer when calling it from RCP but not from eclipse (with Birt 2.0)
Error in viewer when calling it from RCP but not from eclipse (with Birt 2.0) [message #120086] Mon, 30 January 2006 17:12 Go to next message
Originally posted by: nicolas._no.spam_legrain.fr
hi,
I 've updated my installation from birt v1.0.1 to v2.0.
At the beginning, I've got an "HTTP internal error 500" when I launch the
preview from eclipse. Then, I restart Eclipse with the -clean option and now
the preview works well from eclipse.
But, I launch my RCP application, if I open the preview (from my application), I
always got this error : internal error 500
HTTP Status 500 -
> type Exception report
> message
> description The server encountered an internal error () that prevented it
> from fulfilling this request.
I've got the third party jars, I've make the -clean and it works in eclipse but
not in my application. I really don't understand.
The only thing that I haven't done yet is suppressing all the folders of the
v1.0.1 of birt in my eclipse directory. (But if it works in eclipse, ...)
Thanks for your help.
Re: Error in viewer when calling it from RCP but not from eclipse (with Birt 2.0) [message #120202 is a reply to message #120086] Mon, 30 January 2006 20:04 Go to previous messageGo to next message
Paul Reeves is currently offline Paul ReevesFriend
The RCP also requires the same additional third-party libraries that BIRT
Report Designer does.
If you've already loaded these, you can also start the RCP Report Designer
using the -clean option. This should solve your problem.
"nm" <nicolas@_no.spam_legrain.fr> wrote in message
news:drlhg5$poc$1@utils.eclipse.org...
> hi,
> now
> application), I
> HTTP Status 500 -
> > message
> > it
> eclipse but not in my application. I really don't understand.
> the v1.0.1 of birt in my eclipse directory. (But if it works in eclipse,
Re: Error in viewer when calling it from RCP but not from eclipse (with Birt 2.0) [message #120688 is a reply to message #120202] Tue, 31 January 2006 08:34 Go to previous messageGo to next message
Thank you for your answer.
The problem is that I am talking about my own RCP application (which embed birt)
not the "RCP Report Designer". I don't use the "RCP Report Designer".
I've made a simple test .rptdesign with eclipse (not RCP Report Designer).
In eclipse, the preview works but when I call the preview from my RCP
application it fails.
When I run my application from eclipse, I think it use the Birt's plugin from my
eclipse directory with the third-party libraries, no?
If I run the application out of eclipse (after exporting it) I have the problem.
I've also tried to use -clean option when I launch my application.
>> hi,
>> now
>> application), I
>> HTTP Status 500 -
>>> message
>>> it
Re: Error in viewer when calling it from RCP but not from eclipse (with Birt 2.0) [message #120748 is a reply to message #120688] Tue, 31 January 2006 10:14 Go to previous messageGo to next message
Application server stack trace :
exception
javax.servlet.ServletException: L''exécution de la servlet a lancé une exception
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:269)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:193)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:256)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
at org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
at org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
at org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
at org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
at java.lang.Thread.run(Thread.java:595)
cause mère
java.lang.LinkageError: Class javax/servlet/ServletContext violates loader
constraints
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.d efineClass(DefaultClassLoader.java:370)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:233)
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClassImpl(DefaultClassLoader.java:343)
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClass(DefaultClassLoader.java:235)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:183)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:141)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:68)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
org.eclipse.birt.core.framework.PlatformServletContext.getFi leList(PlatformServletContext.java:58)
org.eclipse.birt.core.framework.server.ServerPlatform.<init >(ServerPlatform.java:55)
at org.eclipse.birt.core.framework.Platform.initialize(Platform .java:85)
at org.eclipse.birt.report.engine.api.ReportEngine.<init>(ReportEngine.java:80)
org.eclipse.birt.report.services.ReportEngineService.setEngi neContext(Unknown
Source)
at org.eclipse.birt.report.viewer.servlet.ViewerServlet.doGet(U nknown Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
at org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:247)
> embed birt)
> from my eclipse directory with the third-party libraries, no?
> problem.
>> BIRT Report Designer does.
>> Designer using the -clean option. This should solve your problem.
>>> hi,
>>> the preview from eclipse. Then, I restart Eclipse with the -clean
>>> option and now
>>> application), I
>>> HTTP Status 500 -
>>>> message
>>>> prevented it
>>> of the v1.0.1 of birt in my eclipse directory. (But if it works in
>>> eclipse, ...)
Re: Error in viewer when calling it from RCP but not from eclipse (with Birt 2.0) [message #121613 is a reply to message #120688] Tue, 31 January 2006 15:05 Go to previous messageGo to next message
I think I've found the origin of my problem.
I don't launch the "birt viewer" webapp well in the embedded tomcat.
But I don't know how to do this.
Here is the code I use :
//This fails (but works with birt 1.0.1)
WebappManager.start("birt" , "org.eclipse.birt.report.viewer", new
Path("/birt"));
String url =
"http://"+WebappManager.getHost()+":"+WebappManager.getPort()+ "/birt/";
url+="run?__report=C:/myproject/new_report.rptdesign";
org.eclipse.birt.report.viewer.browsers.BrowserManager.getIn stance().createBrowser(false).displayURL(url);
If I don't start the webapp myself and I use this code:
WebViewer.display("C:/myproject/new_report.rptdesign", WebViewer.HTML);
I can view the report (but I've oda problems if i use jdbc).
So I think the method I use to start the viewer webapp isn't good.
What should I do?
> embed birt)
> problem.
>>> hi,
>>> option and now
>>> application), I
>>> HTTP Status 500 -
>>>> message
>>>> prevented it
>>> eclipse, ...)
Re: Error in viewer when calling it from RCP but not from eclipse (with Birt 2.0) [message #122021 is a reply to message #121613] Tue, 31 January 2006 17:53 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
One of the things that changed between 1.0.1 and 2.0 is that the viewer
plugin doesnt have the plugins folder any longer.
If you are deploying it without all the other BIRT Plugins, you will need to
create the older style plugins directory beneath the the
Viewer plugin or just add the required ones directly to the Eclipse/plugins
folder.
Jason
news:drnub3$rm3$1@utils.eclipse.org...
> Path("/birt"));
> String url =
> WebViewer.display("C:/myproject/new_report.rptdesign", WebViewer.HTML); I
> What should I do?
> nm a
Re: Error in viewer when calling it from RCP but not from eclipse (with Birt 2.0) [message #122126 is a reply to message #122021] Tue, 31 January 2006 21:49 Go to previous message
If I launch the webapp with
Path("/birt"));
it doesn't work => http error 500
but if I use
WebappAccessor.start("birt" , "org.eclipse.birt.report.viewer", new
>> Path("/"));
it works.
> folder.
> Jason
>> Path("/birt"));
>> String url =
>> What should I do?
>>> embed birt)
>>> Designer).
>>> problem.
>>>>> hi,
>>>>> option and now
>>>>> application), I
>>>>> HTTP Status 500 -
>>>>>> message
>>>>>> it
>>>>> eclipse, ...)
Previous Topic:Extra Plugins needed?
Next Topic:BIRT Charts API in an Action/Servlet
Current Time: Wed Jan 15 10:53:42 GMT 2025
Powered by FUDForum. Page generated in 0.04110 seconds
