ThreadDeath - Servicelistener ??? [message #119980] |
Wed, 22 October 2008 05:48  |
Originally posted by: a.heikhaus.cenit.de
I use osgi services for different useful thinks in my rcp app. e.g. one persistservice for persisting objects. Now I have the usecase that I have to persist some objects if the platform will be closed. So I firstly tried to do that in method stop() of my activator. But unfortunately the service is already unregisterd if this bundle will be stopped. So I implemented a servicelistener that listens on deregister events of that persistservice. If such an event occured I then persist my objects in the servicelistener. Now the problem: If I do some short thinks, all works fine. But if the persisting lasts too long then I get the attached error. My question: What happens there? Some suggestions how I can get rid of that problem?
Thanks.
java.lang.ThreadDeath
at java.lang.Thread.stop(Thread.java:698)
at org.springframework.osgi.extender.internal.util.concurrent.R unnableTimedExecution.execute(RunnableTimedExecution.java:68 )
at org.springframework.osgi.extender.internal.ContextLoaderList ener.shutdown(ContextLoaderListener.java:487)
at org.springframework.osgi.extender.internal.ContextLoaderList ener$ContextBundleListener.handleEvent(ContextLoaderListener .java:189)
at org.springframework.osgi.extender.internal.ContextLoaderList ener$BaseListener.bundleChanged(ContextLoaderListener.java:1 24)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1234)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
at org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEventPrivileged(Framework.java:1518)
at org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEvent(Framework.java:1469)
at org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:667)
at org.eclipse.osgi.framework.internal.core.Framework.close(Fra mework.java:576)
at org.eclipse.osgi.framework.internal.core.OSGi.close(OSGi.jav a:41)
at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(Ecl ipseStarter.java:420)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:200)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Re: ThreadDeath - Servicelistener ??? [message #120071 is a reply to message #120006] |
Thu, 23 October 2008 08:32  |
Thanks for your reply, but I think it does not help me, because I don´t want to handle the lifecycle of the services by myself.
I now finally used a ServiceTracker, because I´ve read some things about concurrency - problems with ServiceListener. But the problems stays the same. May be some of you can give me a hint when watching the source code. The following is one method of my ServiceTrackerCustomizer:
public class Customizer implements ServiceTrackerCustomizer {
public Object addingService(ServiceReference reference) {
return reference;
public void modifiedService(ServiceReference reference, Object service) {
public void removedService(ServiceReference reference, Object service) {
try {
Thread.sleep(15000);
catch (InterruptedException e) {
e.printStackTrace();
This is just to simplify. If I use 150 millis in sleep() method then all works fine. If I use 15000 then the error occurs. I also found out, that it also happens when I just stop only the service bundle. So I ask by myself: Is that a bug? Or is it forbidden to do some intensive work here? What can I do to handle my usecase? Noone ever heard of that problem? A lot of questions.......
Thanks.
FUDForum. Page generated in 0.03829 seconds
