Home » Language IDEs » Java Development Tools (JDT) » in M5 class disappear?
in M5 class disappear? [message #119906] Mon, 24 November 2003 05:30 Go to next message
On M5 I get several exceptions like the following:
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/jface/text/ITextViewer
at java.lang.Class.getDeclaredConstructors0(Native Method)
it happens in some plugins and CDT and this problem not occur on M4
is the problem in my environment only or is an expected behavior ?
thanks,
Luca
Re: in M5 class disappear? [message #119920 is a reply to message #119906] Mon, 24 November 2003 06:15 Go to previous messageGo to next message
> !STACK 0
> thanks,
> Luca
I experienced a similar problem with the X-men plugin (in that case it
was the org/eclipse/jface/text/source/SourceViewerConfiguration class.
I solved it by adding the jface-text plugin to the list of the required
plugins of the X-Men plugin.
I.e.:
Open plugin.xml in the folder of the plugin and add a line under
<requires>: <import plugin="org.eclipse.jface.text"/>
I don't know if this is a problem or a planned change to the
plugin-descriptor.
HTH
Christoph
Re: in M5 class disappear? [message #119943 is a reply to message #119920] Mon, 24 November 2003 07:36 Go to previous messageGo to next message
If you had read the changelist of Eclipse 3.0M5, you would know, that the
Eclipse API has undergone major API changes. This changes will break almost
all plugins.
CDT1.2.0 is for Eclipse 2.1.x and Eclipse 3.0 up to M4 only.
>> !STACK 0
>> thanks,
>> Luca
> I.e.:
> plugin-descriptor.
> HTH
> Christoph
Re: in M5 class disappear? [message #119998 is a reply to message #119920] Mon, 24 November 2003 08:25 Go to previous messageGo to next message
>> !STACK 0
>> thanks,
>> Luca
> I.e.:
Thanks Christoph, I will try asap your hack ;-))
bye,
Luca
> plugin-descriptor.
> HTH
> Christoph
Re: in M5 class disappear? [message #120011 is a reply to message #119943] Mon, 24 November 2003 08:25 Go to previous messageGo to next message
> all plugins.
I read that on "Eclipse Project Draft 3.0 plan posted", but I have no
warnings found about incompatible changes between M4 and M5, maybe they
are in the build notes?
CDT 1.2.0 doesn't work for other reasons in M4 too.
I will wait until CDT will work on 3.0, in the meanwhile if someone have
oher hacks to let it work under M5 are wellcome!
thanks again,
Luca
>>> !STACK 0
>>> thanks,
>>> Luca
>> required plugins of the X-Men plugin.
>> I.e.:
>> plugin-descriptor.
>> HTH
>> Christoph
Re: in M5 class disappear? [message #122788 is a reply to message #120011] Thu, 27 November 2003 17:38 Go to previous message
Originally posted by: dschaefe.ca.ibm.com
Yes, the changes in Eclipse 3.0 M5 were pretty dramatic. We have now caught
up and have released an M5 version of CDT 2.0 that will (at least) run in
E3.0 M5.
Doug
>> almost all plugins.
> thanks again,
> Luca
>>>> !STACK 0
>>>> thanks,
>>>> Luca
>>> Hi,
>>> I.e.:
>>> plugin-descriptor.
>>> HTH
>>> Christoph
Previous Topic:packaging jars (un?required ant jars)
Next Topic:Passing compiler(javac) -source 1.5 ...how ?
Current Time: Mon Oct 27 20:06:41 EDT 2025
Powered by FUDForum. Page generated in 0.05016 seconds
