code complete...completly confused?? [message #119900] |
Tue, 07 September 2004 18:06 |
Originally posted by: noyoucannothavemyemail.foomanchoo.com
This is pretty much as simple as it gets....
#include <string>
int main(int argc, char *argv[])
string str;
str. <HIT CTRL-SPACE>
brings up..no functions..and instead gives me a list of stuff like:
__codecvt_ok;
PTHREAD_CANCEL_ASYNCHRONOUS
any thoughts what could be wrong?
Re: code complete...completly confused?? [message #120685 is a reply to message #119966] |
Fri, 10 September 2004 21:23 |
sorry I should have specified the project type...
The project is a Standard Make, meaning the make file defines the correct
include paths, etc.. right??
In this case does the parser not use the include paths defined by the make
files?
I also tried explicity specifying the name space as well to no avail..
"Sean Evoy" <sevoy@ca.ibm.com> wrote in message
news:chl059$4hu$2@eclipse.org...
> Dan,
> Do you have the includes paths and defined symbols for the compiler
> setup? The scanner relies on those in order to understand what it finds
> in the compiler-supplied header files. Does your code specify that it is
> using the namespace 'std'. If not, then I suspect that you will get
> inconsistent content assist results (not to mention compiler errors).
> Sean
> > #include <string>
> > string str;
> > __codecvt_ok;
Re: code complete...completly confused?? [message #120695 is a reply to message #120685] |
Fri, 10 September 2004 21:45 |
Originally posted by: ddaoust.ca.ibm.com
This program does not compile at the string declaration, since you do not
have the proper namespace.
I created a managed make project with a main.cpp that contains:
#include <string>
using namespace std;
string str;
str.
I do a build (so that the compiler builtins are discovered). Then a
content assist on the str. provides a long list of completions.
- Dave
"dan" <noyoucannothavemyemail@foomanchoo.com> wrote in message
news:cht5p2$4ph$1@eclipse.org...
> files?
> > Dan,
> > Sean
> > > #include <string>
> > > string str;
> > > __codecvt_ok;
Re: code complete...completly confused?? [message #120902 is a reply to message #120695] |
Mon, 13 September 2004 19:06 |
Odd, I also tried that...still have a failure..
However..I found that in the my DEBUG folder, eclipse has marked the file:
main.d as having an error (I believe this is auto-generated by
eclipse..right?)
specifically the error is on this line...:
main.d #define __VERSION__ "2.96 20000731 (Red Hat Linux 7.3 2.96-113)"
Im guessing...I need a newer version of make? or gcc?
typeing make --version, yields 3.79.1
and gcc --version, yeilds 2.96
"David Daoust" <ddaoust@ca.ibm.com> wrote in message
news:cht6tq$68q$1@eclipse.org...
> #include <string>
> string str;
> str.
> - Dave
correct
make
> > files?
> > > Dan,
finds
is
> > > Sean
> > > > #include <string>
> > > > string str;
> > > > __codecvt_ok;
FUDForum. Page generated in 0.04455 seconds
