Home » Archived » BIRT » Classload problem
Classload problem [message #119875] Mon, 30 January 2006 10:12
Hi all,
I have implemented a plugin that runs BIRT script fiels.
If I run it as a standalone it works fine. But when it runs as Eclipse
plugin gives the following error:
Script engine error: TypeError: [JavaPackage nl.fields.DynamicFields] is
not a function. (DataSet:Set.open#12)
The following package is exported in the manifest file of my plugin:
Export-Package: nl.fields
Any idea why my class does not loaded?
Said
Previous Topic:Report engine can not create html emitter.
Next Topic:Dynamic text in report
Current Time: Fri Apr 25 01:59:33 EDT 2025
Powered by FUDForum. Page generated in 0.02829 seconds
