Home » Archived » Test and Performance Tools Platform (TPTP) » stand alone java app profiling : Agent Controller is unavailable under port 10002.
stand alone java app profiling : Agent Controller is unavailable under port 10002. [message #119858] Mon, 24 December 2007 12:55 Go to next message
Jigar Shah is currently offline Jigar ShahFriend
Member
I am following tutorial given at
http://www.eclipse.org/articles/Article-TPTP-Profiling-Tool/ tptpProfilingArticle.html
when i start "Profile as Java Application" i get following error. Wat
wrong with my configuration ? From where its taking port 10002 ?
org.eclipse.core.runtime.CoreException
Agent Controller is unavailable under port 10002. Make sure that the
service is started and the port number is correct under preferences.
org.eclipse.tptp.platform.iac.administrator.internal.startst op.AutoStartStop.hasProcessTerminated(AutoStartStop.java:275 )
org.eclipse.tptp.platform.iac.administrator.internal.startst op.AutoStartStop.startIAC(AutoStartStop.java:113)
org.eclipse.tptp.platform.execution.client.core.internal.Nod eImpl.connect(NodeImpl.java:117)
org.eclipse.tptp.platform.execution.util.internal.AgentContr ollerPool$1$EstablishConnection.run(AgentControllerPool.java :164)
at java.lang.Thread.run(Thread.java:595)
Thanks in advance
Jigar
Re: stand alone java app profiling : Agent Controller is unavailable under port 10002. [message #119870 is a reply to message #119858] Mon, 24 December 2007 13:24 Go to previous messageGo to next message
Igor Alelekov is currently offline Igor AlelekovFriend
Hi Jigar,
What system, jvm and TPTP build are you using?
Igor
Re: stand alone java app profiling : Agent Controller is unavailable under port 10002. [message #119925 is a reply to message #119870] Thu, 27 December 2007 16:17 Go to previous message
Member
Igor Alelekov wrote:
> Hi Jigar,
> Igor
I have Eclipse 3.3 Europa, TPTP Monitoring 4.4.1, Jdk 1.5_10
This error goes off if i start tptp agent controller. Why i need agent
controller for stand alone java application ?
Jigar
Previous Topic:Weblogic 8.1Profiling with jdk1.4
Next Topic:Can't get TPTP Profiler working
Current Time: Fri Nov 08 22:30:38 GMT 2024
Powered by FUDForum. Page generated in 0.03047 seconds
