can't start OSGi need help [message #899260] |
Tue, 31 July 2012 09:07 |
jessusniww Missing name Messages: 1 Registered: July 2012 |
Junior Member |
hi:
Today ,i download a new eclipse version(Eclipse Java EE IDE for Web Developers.
Version: Juno ReleaseBuild id: 20120614-1722).
After start eclipse, i run OSGi framework,it show below errors:
!SESSION 2012-07-31 16:57:35.057 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_25
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Command-line arguments: -dev file:E:/Maqetta New Eclipse/.metadata/.plugins/org.eclipse.pde.core/New_configuration/dev.properties -os win32 -ws win32 -arch x86 -consoleLog -console
!ENTRY org.eclipse.equinox.console 4 0 2012-07-31 16:57:35.916
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.console_1.0.0.v20120522-1841 [10]" could not be resolved. Reason: Missing Constraint: Import-Package: org.apache.felix.service.command; version="0.8.0"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1332)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1316)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1177)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.osgi 4 0 2012-07-31 16:57:36.181
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.console_1.0.0.v20120522-1841.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2012-07-31 16:57:36.197
!MESSAGE Could not start bundle: org.eclipse.equinox.console
!STACK 0
org.osgi.framework.BundleException: Could not start bundle: org.eclipse.equinox.console
at org.eclipse.osgi.framework.internal.core.ConsoleManager.checkForConsoleBundle(ConsoleManager.java:217)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:297)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.console_1.0.0.v20120522-1841 [10]" could not be resolved. Reason: Missing Constraint: Import-Package: org.apache.felix.service.command; version="0.8.0"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.internal.core.ConsoleManager.checkForConsoleBundle(ConsoleManager.java:215)
... 10 more
Root exception:
!ENTRY org.eclipse.osgi 2 0 2012-07-31 16:57:36.197
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-07-31 16:57:36.197
!SUBENTRY 2 org.eclipse.equinox.console 2 0 2012-07-31 16:57:36.197
!MESSAGE Missing imported package org.apache.felix.service.command_0.8.0.
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!MESSAGE Bundle org.eclipse.equinox.console_1.0.0.v20120522-1841 [10] was not resolved.
i have no idea ,how to deal with it ,can anyone give me some help?
Re: can't start OSGi need help [message #903557 is a reply to message #899700] |
Fri, 24 August 2012 10:20 |
guokai zhang Messages: 1 Registered: August 2012 |
Junior Member |
I have the same problem ,when I set OSGi Framework in Run Configurations,selected only on bundle org.eclipse.osgi and the click run throws Exception like this:
!SESSION 2012-08-24 18:17:30.968 -----------------------------------------------
java.version=1.6.0_23
Command-line arguments: -dev file:E:/OSGI/.metadata/.plugins/org.eclipse.pde.core/qqq/dev.properties -os win32 -ws win32 -arch x86 -consoleLog -console
!ENTRY org.eclipse.osgi 4 0 2012-08-24 18:17:31.453
!MESSAGE Could not find bundle: org.eclipse.equinox.console
!STACK 0
org.osgi.framework.BundleException: Could not find bundle: org.eclipse.equinox.console
at org.eclipse.osgi.framework.internal.core.ConsoleManager.checkForConsoleBundle(ConsoleManager.java:211)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
why ?
how to got it?
I know why it happend. In eclipse 4.2 IDE.the minmix osgi framework need :
org.eclipse.osgi
org.apache.felix.gogo.*(runtime shell command) five plugins
[Updated on: Sat, 25 August 2012 03:32] Report message to a moderator
FUDForum. Page generated in 0.02527 seconds
