Home » Newcomers » Newcomers » install or just run
install or just run [message #119809] Fri, 25 November 2005 20:47 Go to next message
Originally posted by: guyen000.hotmail.com
Hi, I downloaded the Eclipse. I downloaded both the Windows and LInux.
WIndows version seems to be working without need to install.
Is it same for Linux version?
Does it needs installing or just download and run?
I couldn't find any instruction on how to install and/or run Eclipse on
linux. THanks!
Re: install or just run [message #119837 is a reply to message #119809] Fri, 25 November 2005 22:28 Go to previous messageGo to next message
Jeff Myers is currently offline Jeff MyersFriend
Guyen,
If java 1.4.1 or later is on your path, you can simply gunzip and run
eclipse. Otherwise you can run "eclipse -vm /path/to/java" to point it
at a specific Java vm to use.
- Jeff
> Is it same for Linux version? Does it needs installing or just download
> and run?
> linux. THanks!
Re: install or just run [message #120677 is a reply to message #119837] Wed, 30 November 2005 07:54 Go to previous message
thanks.
is there way to know if ther JRE is installed on my machine.
I ran the rpm -i for JRE but after a while it says nothing about whether
the JRE is siccessully or unsuccesfully installed, and doesn't say where
it is copying the files. i got no clue what is going on
Previous Topic:How to get Java documentation displayed in content assist?
Next Topic:Eclipse Proxy Password Settings
Current Time: Fri Nov 08 23:36:23 GMT 2024
Powered by FUDForum. Page generated in 0.09822 seconds
