Home » Newcomers » Newcomers » Changing US_export_policy.jar and local_policy.jar files for Java encryption
Changing US_export_policy.jar and local_policy.jar files for Java encryption [message #119446] Wed, 23 November 2005 23:03
Originally posted by: bill_coke.comcast.net
I would like to be able to compile my Java code in Eclipse with full
encryption enabled. Normally to turn on full encryption capabilities you
simply update the US_export_policy.jar and local_policy.jar files in the
/lib/security directory of your Java installation.
For instance normal out of the box Java allows you to use 128 bit AES
encryption, but full strength Java AES encryption is 256 bits. But you
can't get the full strength version until you update the
US_export_policy.jar and local_policy.jar files.
I don't see where in the Eclipse installation where I can update these
files and enable the full encryption capabilities of Java.
I realize I'm new to Eclipse, so this is probably something easy. Could
someone help me out with this?
Bill
Previous Topic:Workspaces and projects
Next Topic:How to open Web page from my plugin??
Current Time: Thu Nov 14 09:07:02 GMT 2024
Powered by FUDForum. Page generated in 0.08729 seconds
