Re: Need help regarding password encryption in the report(URGENT, PLEASE) [message #124133 is a reply to message #124096] |
Fri, 03 February 2006 19:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
No real name![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=brian.kallay%40bricsnet.com) Messages: 17 Registered: July 2009 |
Junior Member |
Thanks for the info Scott, this is a very good starting point.
Brian
Scott Rosenbaum wrote:
> Brian,
> This is fairly basic but you could try:
> http://www.eclipse.org/birt/phoenix/deploy/designEngineAPI.p hp
> Also if you look through the newsgroup, I believe there are a number of
> additional examples.
> Scott Rosenbaum
> BIRT PMC
> Brian Kallay wrote:
>> Hi Gary,
>> Are there any examples for the Design Engine API that I can look at to
>> get started? I am currently updating the xml using JDOM but as you
>> pointed out this could be problematic if there are schema changes so I
>> would like to start using the API instead.
>> thanks,
>> Brian
>> Gary Xue wrote:
>>> Is it possible for you to use BIRT Design Engine API to update the
>>> report
>>> design, instead of modifying the XML directly? This is your best choice
>>> since DE API is a rich abstraction layer above the report design XML. It
>>> insulates you from future schema change, and offers features like
>>> encryption
>>> and validation.
>>> Alternately you can externalize the DB password to store it outside
>>> of the
>>> report design. I have some previous posts on this topic in this
>>> newsgroup on
>>> how to do this.
>>> It may also be possible to write your own encryption extension to supply
>>> your own encyption code. I will try to some information on how to do
>>> this
>>> and post a note later.
>>> regards,
FUDForum. Page generated in 0.05293 seconds
