| Anchors and resizing [message #119372] |
Wed, 25 February 2004 02:15  |
Hi all,
I have a number of Figures that send Points to their anchors to control
the anchors' locations. The anchors move with the Figures, but when the
Figures are re-sized, the anchor positions don't expand and contract.
I've tried updating the location Points in the Figures' paintFigure()
method, but it hasn't been working. Any thoughts?
I apologize in advance if this has been asked elsewhere, but I hadn't
found it.
Matt
| Re: Anchors and resizing [message #119798 is a reply to message #119722] |
Sat, 28 February 2004 07:43  |
You should not do like that. You needn't code in figure if
your anchor extends AbstractConnectionAnchor. Because when
figure translated or moved, Figure#fireMoved() will be
called, thus listener added by AbstractConnectionAnchor
will notify listeners of connections to update. And as a
result, the connections will call the anchor's
getReferencePoint() and getLocation() again to get a newer
location.
joseph wrote on 2004-2-27 20:19:
> implement the following code in you figure.
> public void validate() {
> if(isValid()) return;
> //you can use getSize method to get the new location of
> your figure. layoutConnectionAnchors();
> super.validate();
> hope these can give you some suggestions.
> Ryan Pu wrote:
>> Matt,
>> You needn't update anchor locations in your own code
>> if your anchor extends the AbstractConnectionAnchor.
>> Matt wrote on 2004-2-25 15:15:
>> > Hi all,
>> > the Figures, but when the Figures are re-sized,
>> > thoughts?
>> > elsewhere, but I hadn't found it.
>> > Matt
FUDForum. Page generated in 0.03973 seconds
