Re: Anchors and resizing [message #119722 is a reply to message #119398] |
Fri, 27 February 2004 12:19 |
Originally posted by: josephlee.163.com
implement the following code in you figure.
public void validate() {
if(isValid()) return;
//you can use getSize method to get the new location of your figure.
layoutConnectionAnchors();
super.validate();
hope these can give you some suggestions.
Ryan Pu wrote:
> Matt,
> You needn't update anchor locations in your own code
> if your anchor extends the AbstractConnectionAnchor.
> Matt wrote on 2004-2-25 15:15:
> > Hi all,
> > I have a number of Figures that send Points to
> > their anchors to control
> > the anchors' locations. The anchors move with
> > the Figures, but when the Figures are re-sized,
> > the anchor positions don't expand and contract.
> > I've tried updating the location Points in the
> > Figures' paintFigure()
> > method, but it hasn't been working. Any
> > thoughts?
> > I apologize in advance if this has been asked
> > elsewhere, but I hadn't found it.
> > Matt
Re: Anchors and resizing [message #119798 is a reply to message #119722] |
Sat, 28 February 2004 12:43 |
Ryan Pu Messages: 7 Registered: July 2009 |
Junior Member |
You should not do like that. You needn't code in figure if
your anchor extends AbstractConnectionAnchor. Because when
figure translated or moved, Figure#fireMoved() will be
called, thus listener added by AbstractConnectionAnchor
will notify listeners of connections to update. And as a
result, the connections will call the anchor's
getReferencePoint() and getLocation() again to get a newer
location.
joseph wrote on 2004-2-27 20:19:
> your figure. layoutConnectionAnchors();
> super.validate();
> Ryan Pu wrote:
>> Matt,
>> > Hi all,
>> > thoughts?
>> > Matt
FUDForum. Page generated in 0.03501 seconds
