Home » Language IDEs » ServerTools (WTP) » JBoss 4.0.3 definitions
JBoss 4.0.3 definitions [message #119281] |
Mon, 11 July 2005 07:37  |
Originally posted by: thisisnot.mymail.com
The plugins I found on the newsgroup don't work for me well, I'm using
WTP M5 and eclipse 3.1;
Anyone to update their plugin?
Re: JBoss 4.0.3 definitions [message #139922 is a reply to message #120478] |
Wed, 21 September 2005 09:12   |
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
--------------080502020500010202040203
Hi Dave,
I'm receiving a bunch of errors if I start my JBoss. See attached jboss log.
I use JBoss 4.0.2 with WTP 0.7.
I configured Eclipse to use JDK 1.4.2_09 (in
C:\Programme\Java\j2sdk1.4.2_09) and use it with the server declaration.
The JavaHome in my server declaration is also set to this path (it
complains if I use the JRE path).
On start the server tries to access files in
C:\Programme\Java\j2sdk1.4.2_09\lib which are found in
C:\Programme\Java\j2sdk1.4.2_09\jre\lib (e.g. ZoneInfoMappings).
What's wrong here ?
The server starts up and EJBs run fine. But when I try to invoke the
Hypersonic Database MAnager from the jmx-console this does not work (one
more ZoneInfo error in log).
Workaround is to copy the files from
C:\Programme\Java\j2sdk1.4.2_09\jre\lib to
C:\Programme\Java\j2sdk1.4.2_09\lib.
The file "jboss4.serverdef" contains some differences to some earlier
posts regarding JBoss 4 ("<classpath id="jboss">" element)
Best regards
Wolfgang
name="JBosslog.txt"
Content-Disposition: inline;
filename="JBosslog.txt"
ZoneInfo: C:\Programme\Java\j2sdk1.4.2_09\lib\zi\ZoneInfoMappings (Das System kann den angegebenen Pfad nicht finden)
20:12:57,750 INFO [Server] Starting JBoss (MX MicroKernel)...
20:12:57,750 INFO [Server] Release ID: JBoss [Zion] 4.0.2 (build: CVSTag=JBoss_4_0_2 date=200505022023)
20:12:57,750 INFO [Server] Home Dir: C:\temp\jboss-4.0.2
20:12:57,750 INFO [Server] Home URL: file:/C:/temp/jboss-4.0.2/
20:12:57,750 INFO [Server] Library URL: file:/C:/temp/jboss-4.0.2/lib/
20:12:57,750 INFO [Server] Patch URL: null
20:12:57,765 INFO [Server] Server Name: default
20:12:57,765 INFO [Server] Server Home Dir: C:\temp\jboss-4.0.2\server\default
20:12:57,765 INFO [Server] Server Home URL: file:/C:/temp/jboss-4.0.2/server/default/
20:12:57,796 INFO [Server] Server Data Dir: C:\temp\jboss-4.0.2\server\default\data
20:12:57,796 INFO [Server] Server Temp Dir: C:\temp\jboss-4.0.2\server\default\tmp
20:12:57,796 INFO [Server] Server Config URL: file:/C:/temp/jboss-4.0.2/server/default/conf/
20:12:57,796 INFO [Server] Server Library URL: file:/C:/temp/jboss-4.0.2/server/default/lib/
20:12:57,796 INFO [Server] Root Deployment Filename: jboss-service.xml
20:12:57,796 INFO [Server] Starting General Purpose Architecture (GPA)...
20:12:58,171 INFO [ServerInfo] Java version: 1.4.2_09,Sun Microsystems Inc.
20:12:58,171 INFO [ServerInfo] Java VM: Java HotSpot(TM) Client VM 1.4.2_09-b05,Sun Microsystems Inc.
20:12:58,171 INFO [ServerInfo] OS-System: Windows XP 5.1,x86
20:12:58,875 INFO [Server] Core system initialized
20:13:01,406 INFO [Log4jService$URLWatchTimerTask] Configuring from URL: resource:log4j.xml
Warning: default mime table not found: C:\Programme\Java\j2sdk1.4.2_09\lib\content-types.properties
20:13:01,437 INFO [WebService] Using RMI server codebase: http://turbotante:8083/
20:13:01,609 INFO [NamingService] Started jndi bootstrap jnpPort=1099, rmiPort=1098, backlog=50, bindAddress=/0.0.0.0, Client SocketFactory=null, Server SocketFactory=org.jboss.net.sockets.DefaultSocketFactory@ad093076
20:13:06,390 INFO [Embedded] Catalina naming disabled
20:13:06,843 INFO [Http11Protocol] Initializing Coyote HTTP/1.1 on http-0.0.0.0-8080
20:13:06,843 INFO [Catalina] Initialization processed in 422 ms
20:13:06,843 INFO [StandardService] Starting service jboss.web
20:13:06,859 INFO [StandardEngine] Starting Servlet Engine: Apache Tomcat/5.5.9
20:13:06,875 INFO [StandardHost] XML validation disabled
20:13:06,906 INFO [Catalina] Server startup in 63 ms
20:13:07,015 INFO [TomcatDeployer] deploy, ctxPath=/invoker, warUrl=file:/C:/temp/jboss-4.0.2/server/default/deploy/http- invoker.sar/invoker.war/
20:13:07,156 INFO [STDOUT] ZoneInfo: C:\Programme\Java\j2sdk1.4.2_09\lib\zi\ZoneInfoMappings (Das System kann den angegebenen Pfad nicht finden)
20:13:07,281 INFO [WebappLoader] Dual registration of jndi stream handler: factory already defined
20:13:07,312 INFO [STDOUT] ZoneInfo: C:\Programme\Java\j2sdk1.4.2_09\lib\zi\ZoneInfoMappings (Das System kann den angegebenen Pfad nicht finden)
20:13:07,703 INFO [STDOUT] ZoneInfo: C:\Programme\Java\j2sdk1.4.2_09\lib\zi\ZoneInfoMappings (Das System kann den angegebenen Pfad nicht finden)
20:13:07,734 INFO [TomcatDeployer] deploy, ctxPath=/ws4ee, warUrl=file:/C:/temp/jboss-4.0.2/server/default/tmp/deploy/t mp51315jboss-ws4ee-exp.war/
20:13:07,843 INFO [TomcatDeployer] deploy, ctxPath=/, warUrl=file:/C:/temp/jboss-4.0.2/server/default/deploy/jboss web-tomcat55.sar/ROOT.war/
20:13:08,031 INFO [TomcatDeployer] deploy, ctxPath=/jbossmq-httpil, warUrl=file:/C:/temp/jboss-4.0.2/server/default/deploy/jms/j bossmq-httpil.sar/jbossmq-httpil.war/
20:13:09,890 INFO [TomcatDeployer] deploy, ctxPath=/web-console, warUrl=file:/C:/temp/jboss-4.0.2/server/default/deploy/manag ement/console-mgr.sar/web-console.war/
20:13:10,453 INFO [MailService] Mail Service bound to java:/Mail
20:13:11,062 INFO [RARDeployment] Required license terms exist view the META-INF/ra.xml: file:/C:/temp/jboss-4.0.2/server/default/deploy/jboss-ha-loc al-jdbc.rar
20:13:11,171 INFO [RARDeployment] Required license terms exist view the META-INF/ra.xml: file:/C:/temp/jboss-4.0.2/server/default/deploy/jboss-ha-xa- jdbc.rar
20:13:11,265 INFO [RARDeployment] Required license terms exist view the META-INF/ra.xml: file:/C:/temp/jboss-4.0.2/server/default/deploy/jboss-local- jdbc.rar
20:13:11,359 INFO [RARDeployment] Required license terms exist view the META-INF/ra.xml: file:/C:/temp/jboss-4.0.2/server/default/deploy/jboss-xa-jdb c.rar
20:13:11,484 INFO [RARDeployment] Required license terms exist view the META-INF/ra.xml: file:/C:/temp/jboss-4.0.2/server/default/deploy/jms/jms-ra.r ar
20:13:11,578 INFO [RARDeployment] Required license terms exist view the META-INF/ra.xml: file:/C:/temp/jboss-4.0.2/server/default/deploy/mail-ra.rar
20:13:12,171 INFO [STDOUT] ZoneInfo: C:\Programme\Java\j2sdk1.4.2_09\lib\zi\ZoneInfoMappings (Das System kann den angegebenen Pfad nicht finden)
20:13:12,875 INFO [WrapperDataSourceService] Bound connection factory for resource adapter for ConnectionManager 'jboss.jca:name=DefaultDS,service=DataSourceBinding to JNDI name 'java:DefaultDS'
20:13:13,125 INFO [A] Bound to JNDI name: queue/A
20:13:13,125 INFO [B] Bound to JNDI name: queue/B
20:13:13,125 INFO [C] Bound to JNDI name: queue/C
20:13:13,125 INFO [D] Bound to JNDI name: queue/D
20:13:13,125 INFO [ex] Bound to JNDI name: queue/ex
20:13:13,140 INFO [testTopic] Bound to JNDI name: topic/testTopic
20:13:13,140 INFO [securedTopic] Bound to JNDI name: topic/securedTopic
20:13:13,140 INFO [testDurableTopic] Bound to JNDI name: topic/testDurableTopic
20:13:13,140 INFO [testQueue] Bound to JNDI name: queue/testQueue
20:13:13,203 INFO [UILServerILService] JBossMQ UIL service available at : /0.0.0.0:8093
20:13:13,250 INFO [DLQ] Bound to JNDI name: queue/DLQ
20:13:13,406 INFO [ConnectionFactoryBindingService] Bound connection factory for resource adapter for ConnectionManager 'jboss.jca:name=JmsXA,service=ConnectionFactoryBinding to JNDI name 'java:JmsXA'
20:13:13,453 INFO [TomcatDeployer] deploy, ctxPath=/jmx-console, warUrl=file:/C:/temp/jboss-4.0.2/server/default/deploy/jmx-c onsole.war/
20:13:13,562 INFO [EARDeployer] Init J2EE application: file:/C:/temp/jboss-4.0.2/server/default/deploy/KuchenSingle .ear
20:13:13,578 WARN [MainDeployer] Found non-jar deployer for KuchenSingleEJB.jar: org.jboss.ejb.EJBDeployer@163956
20:13:13,765 INFO [EjbModule] Deploying KuchenSingle
20:13:14,531 INFO [EJBDeployer] Deployed: file:/C:/temp/jboss-4.0.2/server/default/tmp/deploy/tmp51361 KuchenSingle.ear-contents/KuchenSingleEJB.jar
20:13:14,562 INFO [EARDeployer] Started J2EE application: file:/C:/temp/jboss-4.0.2/server/default/deploy/KuchenSingle .ear
20:13:14,640 INFO [Http11Protocol] Starting Coyote HTTP/1.1 on http-0.0.0.0-8080
20:13:14,765 INFO [ChannelSocket] JK: ajp13 listening on /0.0.0.0:8009
20:13:14,765 INFO [JkMain] Jk running ID=0 time=0/15 config=null
20:13:14,781 INFO [Server] JBoss (MX MicroKernel) [4.0.2 (build: CVSTag=JBoss_4_0_2 date=200505022023)] Started in 16s:985ms
20:13:14,781 INFO [STDOUT] ZoneInfo: C:\Programme\Java\j2sdk1.4.2_09\lib\zi\ZoneInfoMappings (Das System kann den angegebenen Pfad nicht finden)
20:13:14,843 INFO [STDOUT] ZoneInfo: C:\Programme\Java\j2sdk1.4.2_09\lib\zi\ZoneInfoMappings (Das System kann den angegebenen Pfad nicht finden)
--------------080502020500010202040203--
Re: JBoss 4.0.3 definitions [message #143070 is a reply to message #139922] |
Tue, 11 October 2005 05:21  |
--------------080009050400080702070602
Based on Dave's worked and what I found here in the group I modified the
serverdef plugin to work for me (Eclipse 3.1.1, WTP 1.0M8, JDK 1.4.2).
Maybe someone could take a look whether it makes sense.
See attached file.
Wolfgang
Content-Type: application/octet-stream;
name="org.jboss.ide.eclipse.serverdefinitions_0.7.0.jar"
Content-Disposition: attachment;
filename="org.jboss.ide.eclipse.serverdefinitions_0.7.0.jar "
UEsDBBQAAAAIAPlx7DLSJ2rFRAEAALAFAAAVAAAAYnVpbGRmaWxlcy9qYm9z czQueG1sxZRN
bsMgEIXXRModEOoqC5C6JrkLjictCBsLYydtlbsX/G/LIXWlqqwMvJk384kx L6xRcHY4Fxkc
SQqFNh9wc5CX0uQE4xQuotKuv6LqFYBeIfFXiSghlfZIKDntd9gv7oR9g3my MaITNUIlrE9d
uovUXvnylZm00kBD4J1ehSUnPF38UxZBWvrkjeUQ4Xf3aeYhQuZnXaXQ1XI4 sANhazq4LXWN
/1LL2VjCtBHmO5lKeWZqwA/bws509Zdga7C0qBIty/e2j96UsxZkt30GF9QG uOqf4aq/gat+
AxdFmAZMXoHiNBsZDjr0HCPq+0ArAGmLsNf4fKvwatHK/P0cWjjocfnvx6Tg R6TQ4g3OSVV5
bLhT0OBG9xULtjrxnLWR61MQq2A5AdsrUNEKcBhCFK1geC/bvWHpPcJH+x1n 3T86vLNvUEsD
BAoAAAAAAESmSjMAAAAAAAAAAAAAAAALAAAAYnVpbGRmaWxlcy9QSwMECgAA AAAARKZKMwAA
AAAAAAAAAAAAAAwAAABpY29ucy9vYmoxNi9QSwMEFAAAAAgA+XHsMgggH64R AQAAPAEAABUA
AABpY29ucy9vYmoxNi9qYm9zcy5naWZz93SzsEwUYBBguMrA8Pvbn1tXXiXl rJm/5jqD3bR3
3/8zBM8Mm3miYc89hyVnVt14ffnVl8mXnlx58zl8qdSs01l9hwJefLr9/fen y08W/Xm9/ve7
Q/9P+P3fqf5nPsOvc+3/JjP8OFT559OT7xvTfnx6/WWS0ede7S95DJ/cGd7p q7zPz/jU1vBY
gOuJnOS7lvpHDAzfTpz4cuL4////GcgFij9ZGBkYdIAQCEB+YmCLdJhW4KEj 1e/xMFFQQEWa
R4yRUUJFuC1l4wKJPrc178M1Gn06HptYPKpYcDDJIEh2WrTe+13zWi9yHK1v cBIVkVOQ1tHS
iJJVUtRR01TxlJGX1FHXVI1y0Z4zx5HBGgBQSwMECgAAAAAARKZKMwAAAAAA AAAAAAAAAAYA
AABpY29ucy9QSwMEFAAAAAgA+XHsMhLZ5rq7AAAAWwEAABQAAABNRVRBLUlO Ri9NQU5JRkVT
VC5NRo2QsQrCQBBE+4D/kMbOHNFGUGys1ULBPl7GsHLZ0907Qb/emJiIneXy hpnZ2RZMZ2jI
jhAlz4t0avJkHbl0yLYfOLBZT3ZFjUU6vrpYEb+PHhwe9ck7sp3AS2UuJ69q qISBdXRVGIXc
ISXOxBQaX12mSlw5hCZjFSQObkNwbubfWhtvC0fPIrSo65DscYskyDpNF90H Wi8wEjlQjcko
+WEXDZ9CpgJDyLbyP2SRvjW59PLeQ/y9+VTaRV5QSwMECgAAAAAARKZKMwAA AAAAAAAAAAAA
AAkAAABNRVRBLUlORi9QSwMEFAAAAAgAhKpKM3v23EzGAwAATREAABgAAABz ZXJ2ZXJzL2pi
b3NzNC5zZXJ2ZXJkZWblWF9v2zYQf3aBfgdB6B5N2l6GBYGlImswDEMLBE0H 9KEvtHS26VKk
QFK2gyLffSdSkmVFTmxjS4HWT9T9/d0d747J9O02E8EatOFKRuGYjMIAZKJS LhdR+M+nP4eX
4dv49auplebqDjRKfiyk5Rm8fhXgD7WRgcwoXFqbX1EKieC5AaL0gq6MpcYp 0QVI0Dyh3san
+xxuYM4lt+g3bNvaGt7Y2mw2ZPOrMzUZjcb084f3d8kSMjbk0lgmE6hVDb8y jvNeJcy6WM7H
E/QRvWOyNWlQOZUsgyj8+w9lTHBBRmQb7hK59oQyc7lWOWh7H/A0Cr33j0rZ G64hsUrfo7WB
YDMQUfjLdZ4L7gPwGNpSpU+LmKIw7VATJS1sbRRqX5uKnMKcFQLJqxliHFYY 6QFQ12mqwZg2
nC5jh8BYjTek697Ld72PJ7+j5xEZ9/nOlbaPXd566nn+LkeXo8NhvlNyzmtL tVeXoIsegdO9
V4c+AIlgxtwyu3wccJv1H9bZ86dlkmN/dt9SxW++lcSHKcVzm4N3Ov4LOwcZ 5bHFwlCsSpSI
l47dfFY+aOWk+sxUWog9/TKkeDUBIBuYTan7bJsvZoKbJV54xNbTJg9159Zc X6cHmkIu1D36
3xl4bBaNwRw0jjaIcRKQeirgRCDeHKkmAmHSNkqN1bZ+HfBeiE8GDKufLWCm f6CA8Vze67qZ
tFoh4DYE1705du/OhGtFUslOaY9E0zd79ioqbrf9ls0Yl+9KIy44b/0D0hBk w2mJb5T+iiOr
ye2hjM9KC4+E97t+oVl2rRdFBtKaeJgEnfq4EPaFWgbW2S1DHlhcjfHwphIl bnnWNYItBMPP
mRlPLrPysP1tPMHDzYqtGQGZKm0gJTgNTdQfxxfBZ19qwSnd83lEnZ6sT12K pjIqf64wd8vC
pmrzHYpzd0IxTs8TMU1gTyasydCuOd0CPKEvw94WT5llLYZjljS3q2YFFymZ cwFT2hB7hNdM
FBBTJ15KG+rXP8EHqNf0Ei0A9BCCI6HhFVqAJZUw2W3B53H64ddReRGAbmud BrBReRmA5ZY5
EWCt8hzAinwuzkKeU+tCvmi1OyCPrPc+yP+94l2Qx9W8A/LEqte/eqI1QnGz Bpr55wabGyDl
yBoMpkwnS76GoGRG4ZtvzdP+4PsGn/XzkD6rjeuA4sOfrJj2r/uznOGmpEIt LlbOjjPTmuYu
wEFfdM3sD4OjkNbiLbj7fgaHHFUPoiP84CrBDefHNxNi6L9PTFD115NLTPng 2Lq1JMAeRI5P
2+5/Q1ze/gVQSwMECgAAAAAARKZKMwAAAAAAAAAAAAAAAAgAAABzZXJ2ZXJz L1BLAwQUAAAA
CABdqkoznBKL9gkBAAAXAgAAEQAAAHBsdWdpbi5wcm9wZXJ0aWVzfZCxasMw EIb3QN7hJtMu
TodMAQ1uUgodiqGluyKfnQuyJE5ySN6+kuW6DpQu5qz7/u90cnroyLzLHgW8 okEmBR75ggx4
lb3TCA22ZCiQNX69cmwv1CCPiRelyXksLXexM5oO6BWTS7SoM+tn0ySehNEH rWUIJ4TufnSw
VpOJ0vXqfLTeb3kwgXr8vDkcJ789x1PYlk/l9Q9keQlYoDAxP5E87T/pL7F0 LpWZuOf31rTU
iY+8zN4W6XdgmcLw0Mfle6k38RnkoMNGav24S6tWzmlSI5WjB2JUwfJNLFpQ TN65G8N5btU0
jN6LqsjF3KgtB1Gk73yktPS+luEkin0qXSzhSzLJo8bdN1BLAwQUAAAACABB qEozI253GKcC
AAAWCwAACgAAAHBsdWdpbi54bWzNVslu2zAQPadA/4El0Fss2YlT9CDZQFyk TYH0kDjomZbG
Mg2JFEgqSfv1JSlZpGS3XpJDeTDkWR5neTNSNH0pcvQEQlLOYjwKhhgBS3hK WRbjx/nN4DOe
Tt6/i6aQ5LSU4Gwvta1VlXmVUaafEEIRvChgxgCVnDIVYy6yoPENnqUKJAgN ESRcQCAqpmgB
818lSKwBLASKPHEt0YemXai1g8qAgaDJBi1YL7iUY9y6MlJAjD/WYg/7h5Y7 qxRkImipbG7b
xl+c2vk8AUu5iPH3a23ti5sSDZ0syYmUe1OwVdFlA8FIHnytpQ/W5r6OxSFO 2qeo4GmVd+uF
kDJVjfH6AnThYYE9VROgNA2/OEej4NL8jHHYYu6HhPXbQxJxDGQUev2xMsug KGw5aCl1HCXr
55aRdeRO6IWHUHN9jJWoAHdUr253F+4A9vdZb90YVZTkD4ooHaVUvCwh7ZrI qiy5UPIeCq7g
G5dKh70kuewl5JX69vRRNGfXoLkC75wzc3JSsWQ142xJswMisKX1fSpBDKi5 owu8gBV5orwS
s9f27HqD1L2gs39cpt31Y45URKi5rhuvNEuvhvpog7NWy8tWObqqlZ73ishO pjvbWFfkjqdm
6HSXzlNYVBme+EYb1ocu1lavw+nOl7U8dMIq2jzdFiTzB4ya/14MB/DduvjJ 0cTkbH5lyBfr
0afQVjzI6NI3U5bB+/vco3D4P8fqxdhrT/RhMECPt2jGi5IzYEoOBltda2/c 271n+puI9EaQ
rDBYHm+iZSN04R/+yvZyPrE9DuCwzatz+edr9mcnUV1Z5M6GCCdlLPvb/cge v1miuzI04MeO
999WZC1LYWlfQnqbG3KeRX3xCR92yHkvaa5Xa7OoZD1EY3d1c2fYv3Synage lbD9kP0DUEsB
AhQAFAAAAAgA+XHsMtInasVEAQAAsAUAABUAAAAAAAAAAQAgAAAAAAAAAGJ1 aWxkZmlsZXMv
amJvc3M0LnhtbFBLAQIUAAoAAAAAAESmSjMAAAAAAAAAAAAAAAALAAAAAAAA AAAAEAAAAHcB
AABidWlsZGZpbGVzL1BLAQIUAAoAAAAAAESmSjMAAAAAAAAAAAAAAAAMAAAA AAAAAAAAEAAA
AKABAABpY29ucy9vYmoxNi9QSwECFAAUAAAACAD5cewyCCAfrhEBAAA8AQAA FQAAAAAAAAAA
ACAAAADKAQAAaWNvbnMvb2JqMTYvamJvc3MuZ2lmUEsBAhQACgAAAAAARKZK MwAAAAAAAAAA
AAAAAAYAAAAAAAAAAAAQAAAADgMAAGljb25zL1BLAQIUABQAAAAIAPlx7DIS 2ea6uwAAAFsB
AAAUAAAAAAAAAAEAIAAAADIDAABNRVRBLUlORi9NQU5JRkVTVC5NRlBLAQIU AAoAAAAAAESm
SjMAAAAAAAAAAAAAAAAJAAAAAAAAAAAAEAAAAB8EAABNRVRBLUlORi9QSwEC FAAUAAAACACE
qkoze/bcTMYDAABNEQAAGAAAAAAAAAABACAAAABGBAAAc2VydmVycy9qYm9z czQuc2VydmVy
ZGVmUEsBAhQACgAAAAAARKZKMwAAAAAAAAAAAAAAAAgAAAAAAAAAAAAQAAAA QggAAHNlcnZl
cnMvUEsBAhQAFAAAAAgAXapKM5wSi/YJAQAAFwIAABEAAAAAAAAAAQAgAAAA aAgAAHBsdWdp
bi5wcm9wZXJ0aWVzUEsBAhQAFAAAAAgAQahKMyNudxinAgAAFgsAAAoAAAAA AAAAAQAgAAAA
oAkAAHBsdWdpbi54bWxQSwUGAAAAAAsACwCZAgAAbwwAAAAA
--------------080009050400080702070602--
Current Time: Fri Apr 25 00:47:32 EDT 2025
Powered by FUDForum. Page generated in 0.04423 seconds
