Home » Eclipse Projects » Equinox » p2 installing jdk 1.5 bundles under jdk 1.6
p2 installing jdk 1.5 bundles under jdk 1.6 [message #118655] Mon, 29 September 2008 22:31 Go to next message
Edwin Park is currently offline Edwin ParkFriend
I am trying to install a feature into a p2-enabled RCP application that is
running under JDK 1.6. When I try to install the feature using the p2 ui,
it tries to calculate requirements and returns an error complaining about
unsatisfied java package dependencies for javax.xml.bind.annotation and
javax.xml.stream in org.apache.camel.camel-core 1.3.0 (the full error
message is at the end of this post). The javax.xml.bin.annotation and
javax.xml.stream packages are part of JDK 1.6 but not JDK 1.5. I looked in
the manifest for the camel-core bundle and it has Build-Jdk: 1.5.0_13. If
I embed the feature in the application without p2, it works fine, so I
don't think this is a real runtime problem, but a problem with the p2
requirements resolver. Is there something I can do to get p2 to understand
that these packages are present in the Java 1.6 version that the
application is running in so that it will allow me to install this feature?
Edwin
Full error text:
Cannot complete the request. See the details.
Unsatisfied dependency: [org.apache.camel.camel-core 1.3.0]
requiredCapability: java.package/javax.xml.bind.annotation/0.0.0
requiredCapability: java.package/javax.xml.stream/0.0.0
Unsatisfied dependency: [com.rbc.fusion.ats 1.5.0] requiredCapability:
Unsatisfied dependency: [com.rbccm.eddie.client 1.0.0.SNAPSHOT]
requiredCapability:
java.package/com.rbccm.eddie.fusion.ats.file/1.0.0.SNAPSHOT
requiredCapability:
java.package/com.rbccm.eddie.globalproductgroup/1.0.0.SNAPSH OT
requiredCapability:
java.package/com.rbccm.eddie.fusion.camel.component.ats.upda te/1.0.0.SNAPSHOT
requiredCapability: java.package/org.apache.camel.impl/0.0.0
requiredCapability: java.package/com.rbccm.eddie.rmds/1.0.0.SNAPSHOT
requiredCapability: java.package/org.apache.camel.spi/0.0.0
requiredCapability: java.package/com.rbccm.eddie.util/1.0.0.SNAPSHOT
requiredCapability:
java.package/com.rbccm.eddie.fusion.camel.jmx/1.0.0.SNAPSHOT
requiredCapability: java.package/com.rbccm.eddie.security/1.0.0.SNAPSHOT
requiredCapability:
java.package/com.rbccm.eddie.fusion.camel.component.ats/1.0. 0.SNAPSHOT
requiredCapability:
java.package/com.rbccm.eddie.fusion.camel.processor/1.0.0.SN APSHOT
requiredCapability: java.package/org.apache.camel/0.0.0
requiredCapability:
java.package/com.rbccm.eddie.springframework/1.0.0.SNAPSHOT
requiredCapability: java.package/com.rbccm.eddie.fusion.ats/1.0.0.SNAPSHOT
requiredCapability: java.package/org.apache.camel.util.jndi/1.3.0
requiredCapability: java.package/org.apache.camel.component.timer/1.3.0
requiredCapability: java.package/org.apache.camel.model.dataformat/1.3.0
requiredCapability: java.package/org.apache.camel.component.vm/1.3.0
requiredCapability: java.package/org.apache.camel.language.bean/1.3.0
requiredCapability: java.package/org.apache.camel.management/1.3.0
requiredCapability: java.package/org.apache.camel.model/1.3.0
requiredCapability: java.package/org.apache.camel.component.file/1.3.0
requiredCapability: java.package/org.apache.camel.builder/1.3.0
requiredCapability: java.package/org.apache.camel.spi/1.3.0
requiredCapability: java.package/org.apache.camel.impl/1.3.0
requiredCapability: java.package/org.apache.camel.component.ref/1.3.0
requiredCapability: java.package/org.apache.camel.language/1.3.0
requiredCapability: java.package/org.apache.camel/1.3.0
requiredCapability: java.package/org.apache.camel.builder.xml/1.3.0
requiredCapability:
java.package/org.apache.camel.processor.loadbalancer/1.3.0
requiredCapability: java.package/org.apache.camel.component.mock/1.3.0
requiredCapability: java.package/org.apache.camel.component.seda/1.3.0
requiredCapability: java.package/org.apache.camel.view/1.3.0
requiredCapability:
java.package/org.apache.camel.processor.resequencer/1.3.0
requiredCapability: java.package/org.apache.camel.component.direct/1.3.0
requiredCapability: java.package/org.apache.camel.model.config/1.3.0
requiredCapability: java.package/org.apache.camel.converter.jaxp/1.3.0
requiredCapability:
java.package/org.apache.camel.component.file.strategy/1.3.0
requiredCapability: java.package/org.apache.camel.language.simple/1.3.0
requiredCapability: java.package/org.apache.camel.component.bean/1.3.0
requiredCapability: java.package/org.apache.camel.component.dataset/1.3.0
requiredCapability:
java.package/org.apache.camel.processor.interceptor/1.3.0
requiredCapability: java.package/org.apache.camel.model.loadbalancer/1.3.0
requiredCapability: java.package/org.apache.camel.converter/1.3.0
requiredCapability: java.package/org.apache.camel.component.jmx/1.3.0
requiredCapability: java.package/org.apache.camel.component.list/1.3.0
requiredCapability: java.package/org.apache.camel.processor/1.3.0
requiredCapability:
java.package/org.apache.camel.processor.idempotent/1.3.0
requiredCapability:
java.package/org.apache.camel.processor.validation/1.3.0
requiredCapability: java.package/org.apache.camel.model.language/1.3.0
requiredCapability: java.package/org.apache.camel.util/1.3.0
requiredCapability: java.package/org.apache.camel.component.log/1.3.0
requiredCapability: java.package/org.apache.camel.converter.stream/1.3.0
requiredCapability: java.package/org.apache.camel.processor.aggregate/1.3.0
requiredCapability: java.package/org.apache.camel.impl.converter/1.3.0
Unsatisfied dependency: [com.rbccm.eddie.ui 1.0.0.SNAPSHOT]
requiredCapability: java.package/com.rbccm.eddie.util/0.0.0
requiredCapability: java.package/com.rbccm.eddie.ui.action/1.0.0.SNAPSHOT
requiredCapability: java.package/com.rbccm.eddie.ui.view/1.0.0.SNAPSHOT
requiredCapability: java.package/com.rbccm.eddie.ui/1.0.0.SNAPSHOT
requiredCapability: java.package/com.rbccm.eddie.security/0.0.0
requiredCapability: java.package/com.rbccm.eddie.globalproductgroup/0.0.0
requiredCapability: java.package/com.rbccm.eddie.fusion.ats/0.0.0
Unsatisfied dependency: [com.rbccm.eddie.ui.feature.feature.group 1.0.0]
requiredCapability:
org.eclipse.equinox.p2.iu/com.rbccm.eddie.ui/[1.0.0.SNAPSHOT ,1.0.0.SNAPSHOT]
requiredCapability:
org.eclipse.equinox.p2.iu/org.apache.camel.camel-core/[1.3.0 ,1.3.0]
requiredCapability:
org.eclipse.equinox.p2.iu/com.rbccm.eddie.client/[1.0.0.SNAP SHOT,1.0.0.SNAPSHOT]
Re: p2 installing jdk 1.5 bundles under jdk 1.6 [message #118747 is a reply to message #118655] Tue, 30 September 2008 14:54 Go to previous messageGo to next message
Simon Kaegi is currently offline Simon KaegiFriend
Can you please open a bug for this. Thanks.
"Edwin Park" <esp1@cornell.edu> wrote in message
news:6fa0ea1b2cd5ee360938870d714f4c08$1@www.eclipse.org...
> feature?
> Edwin
> Full error text:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
Re: p2 installing jdk 1.5 bundles under jdk 1.6 [message #119102 is a reply to message #118747] Tue, 07 October 2008 18:11 Go to previous message
Posted the bug under Equinox/p2:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=250003
The problem seems to stem from incomplete package metadata being generated
in PDE Build for the 'a.jre' installable unit.
Previous Topic:P2 mirror selection
Next Topic:[p2] too much diskspace needed for metadata
Current Time: Thu Dec 26 22:21:47 GMT 2024
Powered by FUDForum. Page generated in 0.03040 seconds
