Home » Eclipse Projects » GEF » What is the best place to set a reference creation Request's factory?
What is the best place to set a reference creation Request's factory? [message #118614] |
Fri, 20 February 2004 17:17 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: vgusev.graphlogic.com
When a node is dropped on a connection, the connection should receive a new
child. This child is not a node being dropped, but a new reference to that
node - a different type of class. To create this new reference, I would like
to use the same pattern as in creating new objects when dragging from
pallette, using SimpleFactory. So my question is what is the best place to
set the request's factory. Is it in the connection policy's
getTargetEditPart(request), method, or should I go somewhere deeper like
TargetingTool.createTargetRequest()?
Thanks a lot.
Vladimir
Re: What is the best place to set a reference creation Request's factory? [message #118745 is a reply to message #118614] |
Fri, 20 February 2004 22:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Well, Vladimir,
TargetingTool.createTargetRequest() method is called when the drag starts,
and the Target is not known yet. If you set the request's SimpleFactory at
that point, you will limit all drags to creating a child's reference, this
is not what you want in all cases, especially when the Target is not a
Connection, do you?
In Policy.getTargetEditPart(request) it maybe too late, because your request
will be ChangeBoundsRequest, which does not have the factory field and
thereby
is not intended for instance creation.
Sounds like you'll have to create your reference instance in without
ressorting to
request.getNewObject(), since your request is not CreateRequest anyway?
See if this canbe done using ChangeBoundsRequest in the Policy.getCommand(),
without actually using it although it maybe not the best solution, at least
you'll limit
this behaviour to your edit part.
Vladimir
"Vladimir" <vgusev@graphlogic.com> wrote in message
news:c15f99$cpc$1@eclipse.org...
> Hello,
new
like
> Thanks a lot.
> Vladimir
Re: What is the best place to set a reference creation Request's factory? [message #118758 is a reply to message #118745] |
Fri, 20 February 2004 22:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hey Vladimir,
Go check DND paper by Bordeau - this may give you the freedom to do exactly
what you need, although within GraphicalEditor. All you need to do is to
extend AbstractTransferDropTargetListener and other small parts.
Vladimir
news:c160il$25l$1@eclipse.org...
> Well, Vladimir,
> Connection, do you?
request
> thereby
> ressorting to
least
> you'll limit
> Vladimir
> > Hello,
> new
that
> like
to
like
> > Thanks a lot.
> > Vladimir
Re: What is the best place to set a reference creation Request's factory? [message #118914 is a reply to message #118758] |
Mon, 23 February 2004 15:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Wow, our first schizophrenic posting! ;-)
Are you talking about native DND of an existing object in your model? Or
just straight creation tool stuff from the palette? Please use concrete
terms in your description. For example, are you dragging a class from a
"model explorer" view into another class, and trying to create an attribute
of that type in the class.
Thanks.
news:c161u7$3ou$1@eclipse.org...
> Hey Vladimir,
exactly
> Vladimir
> > Well, Vladimir,
starts,
this
> > Connection, do you?
> request
> > thereby
> > ressorting to
> least
> > you'll limit
> > Vladimir
> > > Hello,
a
> > new
> that
would
> > like
place
> to
> like
> > > Thanks a lot.
> > > Vladimir
Re: What is the best place to set a reference creation Request's factory? [message #118939 is a reply to message #118914] |
Mon, 23 February 2004 16:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Finally, somebody noticed ;-)
I have a graphical node (editpart, model etc.) and a connection between two
other graphical nodes. I am dragging the first node on a connection. When
this node is dropped, I need to set an attribute of the connection's model
to a special class, representing a reference to the first node's model.
After drop is finished, the first node should remain where it was in the
beginning.
Vladimir
"Randy Hudson" <none@us.ibm.com> wrote in message
news:c1d6fs$7p5$1@eclipse.org...
attribute
> Thanks.
> > Hey Vladimir,
> exactly
> > Vladimir
> > > Well, Vladimir,
> starts,
SimpleFactory
> at
> this
> > > Connection, do you?
> > request
> > > thereby
> > > ressorting to
anyway?
> > least
> > > you'll limit
> > > Vladimir
> > > > Hello,
receive
> a
> > > new
to
> > that
> would
> > > like
from
> place
> > to
> > like
> > > > Thanks a lot.
> > > > Vladimir
Re: What is the best place to set a reference creation Request's factory? [message #119004 is a reply to message #118939] |
Mon, 23 February 2004 16:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Consider me a user, and describe what is happening to the user. My guess is
you should just handle everything in your command, and not think about
reusing CreationFactory simply because you are instantiating an object in
your model.
news:c1d83l$a1e$1@eclipse.org...
two
> beginning.
> Vladimir
> attribute
> > Thanks.
> > > Hey Vladimir,
> > exactly
to
> > > Vladimir
> > > > Well, Vladimir,
> > starts,
> SimpleFactory
> > at
reference,
> > this
a
> > > > Connection, do you?
> > > request
and
> > > > thereby
> > > > ressorting to
> anyway?
> > > least
> > > > you'll limit
> > > > Vladimir
> > > > > Hello,
> receive
> > a
> > > > new
> to
> > > that
> > would
> > > > like
> from
> > place
> > > to
deeper
> > > like
> > > > > Thanks a lot.
> > > > > Vladimir
Re: What is the best place to set a reference creation Request's factory? [message #119069 is a reply to message #119004] |
Mon, 23 February 2004 16:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
User has three nodes defined before in the editor pallete. Two nodes are
connected with a Connection.
User needs to create a reference to the third node in the Connection. To do
that, the user drags and drops this third node on the Connection. However,
this is not a usual move or copy drop - because nothing happens to the node
being dragged.
news:c1da11$cv2$1@eclipse.org...
is
> your model.
> two
When
model
> > beginning.
> > Vladimir
Or
concrete
a
> > attribute
> > > Thanks.
> > > > Hey Vladimir,
> > > exactly
is
> to
> > > > Vladimir
> > > > > Well, Vladimir,
> > > starts,
> > SimpleFactory
> > > at
> reference,
> > > this
not
> a
> > > > > Connection, do you?
your
> > > > request
> and
> > > > > thereby
without
> > > > > ressorting to
> > anyway?
> at
> > > > least
> > > > > you'll limit
> > > > > Vladimir
> > > > > > Hello,
> > receive
> > > a
> > > > > new
reference
> > to
> > > > that
I
> > > would
> > > > > like
> > from
best
> > > place
> > > > to
> deeper
> > > > like
> > > > > > Thanks a lot.
> > > > > > Vladimir
Re: What is the best place to set a reference creation Request's factory? [message #119134 is a reply to message #119069] |
Mon, 23 February 2004 19:40 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
In GEF as soon as the target is different than the parent, in this it is the
connection, then the default drag tracker will interpret this as an
ORPHAN+ADD. You can probably live with this, all you have to do is check
who is the new parent, and act accordingly. You can also extend the tool
and add your own LINK_TO_CONNECTION request type, and change the tool to use
this when conncetions are targeted.
news:c1danl$dv9$1@eclipse.org...
do
node
> being dragged.
guess
> is
in
> > your model.
between
> > two
> When
> model
model.
the
> > > beginning.
> > > Vladimir
..zl6wroteinmessagenewsc1d6fs$7p5$1@eclipse.org...Wow,ourfirstschizophrenicpo
sting!;-)
model?
> Or
> concrete
from
> a
> > > attribute
> > > > Thanks.
> > > > > Hey Vladimir,
do
> > > > exactly
> is
> > to
> > > > > Vladimir
> > > > > > Well, Vladimir,
drag
> > > > starts,
> > > SimpleFactory
> > > > at
> > reference,
> > > > this
> not
> > a
> > > > > > Connection, do you?
> your
> > > > > request
field
> > and
> > > > > > thereby
> without
> > > > > > ressorting to
> > > anyway?
solution,
> > at
> > > > > least
> > > > > > you'll limit
> > > > > > Vladimir
> > > > > > > Hello,
> > > receive
> > > > a
> > > > > > new
> reference
> > > to
> > > > > that
reference,
> I
> > > > would
> > > > > > like
dragging
> > > from
> best
> > > > place
> > > > > to
> > deeper
> > > > > like
> > > > > > > Thanks a lot.
> > > > > > > Vladimir
Re: What is the best place to set a reference creation Request's factory? [message #119148 is a reply to message #119134] |
Mon, 23 February 2004 22:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
In the meantime, I have implemented this using native DND. Could you please
let me know what would be the negative implications of using native DND
within one viewer?
Thanks.
Vladimir
news:c1dko7$s1s$1@eclipse.org...
the
use
> do
However,
> node
> > being dragged.
> guess
> > is
> in
> > > your model.
> between
> > > two
> > When
> > model
> model.
> the
> > > > beginning.
> > > > Vladimir
> sting!;-)
> model?
> > Or
> > concrete
> from
> > a
> > > > attribute
> > > > > Thanks.
> > > > > > Hey Vladimir,
> do
> > > > > exactly
do
> > is
> > > to
> > > > > > Vladimir
> > > > > > > Well, Vladimir,
> drag
> > > > > starts,
> > > > SimpleFactory
> > > > > at
> > > reference,
> > > > > this
is
> > not
> > > a
> > > > > > > Connection, do you?
because
> > your
> > > > > > request
> field
> > > and
> > > > > > > thereby
> > without
> > > > > > > ressorting to
CreateRequest
> > > > anyway?
> solution,
> > > at
> > > > > > least
> > > > > > > you'll limit
> > > > > > > Vladimir
> > > > > > > > Hello,
should
> > > > receive
> > > > > a
> > > > > > > new
> > reference
> > > > to
> > > > > > that
> reference,
> > I
> > > > > would
> > > > > > > like
> dragging
> > > > from
> > best
> > > > > place
> > > > > > to
somewhere
> > > deeper
> > > > > > like
> > > > > > > > Thanks a lot.
> > > > > > > > Vladimir
Re: What is the best place to set a reference creation Request's factory? [message #119346 is a reply to message #119148] |
Tue, 24 February 2004 19:51 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
There is no negative implications whatsoever, Vladimir.
Vladimir
news:c1e040$av7$1@eclipse.org...
please
> within one viewer?
> Thanks.
> Vladimir
> the
check
tool
> use
are
To
> > do
> However,
> > node
> > > being dragged.
> > guess
> > > is
about
object
> > in
> > > > your model.
> > between
> > > > two
connection.
> > > When
connection's
> > > model
> > model.
in
> > the
> > > > > beginning.
> > > > > Vladimir
> > sting!;-)
> > model?
> > > Or
> > > concrete
class
> > from
> > > a
an
> > > > > attribute
> > > > > > Thanks.
> > > > > > > Hey Vladimir,
to
> > do
> > > > > > exactly
to
> do
> > > is
> > > > to
parts.
> > > > > > > Vladimir
> > > > > > > > Well, Vladimir,
the
> > drag
> > > > > > starts,
> > > > > SimpleFactory
> > > > > > at
> > > > reference,
> > > > > > this
Target
> is
> > > not
> > > > a
> > > > > > > > Connection, do you?
> because
> > > your
> > > > > > > request
> > field
> > > > and
> > > > > > > > thereby
> > > without
> > > > > > > > ressorting to
> CreateRequest
> > > > > anyway?
> > solution,
> > > > at
> > > > > > > least
> > > > > > > > you'll limit
> > > > > > > > Vladimir
> > > > > > > > > Hello,
> should
> > > > > receive
> > > > > > a
> > > > > > > > new
> > > reference
> > > > > to
> > > > > > > that
> > reference,
> > > I
> > > > > > would
> > > > > > > > like
> > dragging
> > > > > from
the
> > > best
> > > > > > place
> > > > > > > to
policy's
> somewhere
> > > > deeper
> > > > > > > like
> > > > > > > > > Thanks a lot.
> > > > > > > > > Vladimir
Current Time: Sun Jul 21 22:27:14 GMT 2024
Powered by FUDForum. Page generated in 0.04404 seconds
