Home » Archived » Visual Editor (VE) » changing color of AWT.label (1.2M1)
changing color of AWT.label (1.2M1) [message #118597] |
Mon, 20 February 2006 12:56 |
Originally posted by: emailmuell.posur.com
I'm creating a 1.1 compatible applet with Eclipse 3.2M5 + VE 1.2M1.
When I change the color of an AWT.label (e.g. black -> blue) the result is
first fine.
After re-loading the project the label ist black again in the editor and I
get an error:
IWAV0164E Expression type sent in invalid orderThis will not happen with
Eclipse 3.12 with VE 1.1.01Did anybody notice this behaviour too ?
Re: changing color of AWT.label (1.2M1) [message #118604 is a reply to message #118597] |
Mon, 20 February 2006 14:58 |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Could you please attach the code as a file to the newsgroup? We need to
see it to understand the problem.
> first fine.
> get an error:
Rich Kulp
Re: changing color of AWT.label (1.2M1) [message #118651 is a reply to message #118624] |
Mon, 20 February 2006 17:42 |
Thanks, I did update, but it won't solve the problem, it had occured also
with 3.2M4.
Code is simple:
label_131 = new Label();
label_131.setText("Datum: ");
label_131.setFont(new Font("Dialog",
Font.BOLD, 18));
label_131.setForeground(Color.blue);
label_131.setAlignment(java.awt.Label.RIGHT);
setForeground was addes by VE. Next time I start eclipse, label_131 is not
blut but gives an IWAV0164E Error. When I do a project - clean and then
close the VE tab and start loading jave file with VE again, label_131 ist
blue and from this moment on everything ist allright.
Hope that helps.
"Peter Walker" <walkerp@us.ibm.com> schrieb im Newsbeitrag
news:dtcqu1$nm9$1@utils.eclipse.org...
> VE 1.2M1 only works with it's pre-req Eclipse 3.2M4. There has been many
> changes in Eclipse from M4 to M5 and broke some of the code in VE.
> If you need to work with Eclipse 3.2M5, try working with the latest VE 1.2
> integration build.
> I just built and posted a new build today that is based on Eclipse 3.2M5
> http://download.eclipse.org/tools/ve/downloads/drops/I-I2006 0220-200602200943/index.html
> Regards...
> Peter Walker
> VE Development
>> is first fine.
>> I get an error:
Re: changing color of AWT.label (1.2M1) [message #118663 is a reply to message #118651] |
Mon, 20 February 2006 19:00 |
When you say next time you start Eclipse, did you close Eclipse with
the VE open, or was the VE closed? The reason I ask is because there is
slight difference in paths taken if you open Eclipse that was shutdown
with an editor open than one that the editor closed when Eclipse
shutdown and then opened again after Eclipse has been started up again.
Rich Kulp
Re: changing color of AWT.label (1.2M1) [message #118686 is a reply to message #118663] |
Mon, 20 February 2006 20:19 |
I closed Eclise with VE open.
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> schrieb
> When you say next time you start Eclipse, did you close Eclipse with the
> VE open, or was the VE closed? The reason I ask is because there is slight
> difference in paths taken if you open Eclipse that was shutdown with an
> editor open than one that the editor closed when Eclipse shutdown and then
Re: changing color of AWT.label (1.2M1) [message #118697 is a reply to message #118663] |
Tue, 21 February 2006 15:40 |
I did some more testing.
It occurs not only on changing color, but also font size etc.
No matter whether I close Eclipse with VE open or not, if I did changes in
awt.label, next time I open the file in VE I get those ''IWAV0164E
Expression type sent in invalid order'' errors.
Only project - clear seems to help.
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> schrieb im Newsbeitrag
news:dtd3la$7rs$2@utils.eclipse.org...
Re: changing color of AWT.label (1.2M1) [message #118735 is a reply to message #118697] |
Wed, 22 February 2006 15:59 |
Sorry, but I can't reproduce the problem.
Could you please do Help->About Eclipse->Configuration Details->Copy to
Clipboard and take then paste that into a reply so that I can see your
configuration?
Also please attach the .log file showing the error.
Rich Kulp
Re: changing color of AWT.label (1.2M1) [message #118752 is a reply to message #118735] |
Wed, 22 February 2006 18:01 |
configuration file attached.
but sorry, there is no log file or no entry in the eclipse log file.
in the VE the awt.label I have changed shows an exclamation mark with an
on-mouse info:
font: java.lang.IllegalStateException (IWAV0164E Expression type sent in
invalid order, received: Method Invoke: Receiver, expected Class Instance
Creation: Argum... (rest not readable, line to long)
*** Date: Wed Feb 22 18:55:01 CET 2006
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=I20060217-1115
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
J:\Anwendungen\Eclipse\eclipse3.2\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
824_6c
-vm
D:\WINDOWS\system32\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1140630822328
eclipse.vm=D:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
J:\Anwendungen\Eclipse\eclipse3.2\eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=J:\Anwendungen\Eclipse\eclipse3.2\eclipse\st artup.jar
java.class.version=49.0
java.endorsed.dirs=J:\Anwendungen\Java\JRE5.0_6\lib\endorsed
java.ext.dirs=J:\Anwendungen\Java\JRE5.0_6\lib\ext
java.home=J:\Anwendungen\Java\JRE5.0_6
java.io.tmpdir=D:\DOKUME~1\Winfried\LOKALE~1\Temp\
java.library.path=D:\WINDOWS\system32;.;D:\WINDOWS\system32; D:\WINDOWS;D:\WINDOWS\system32;D:\WINDOWS;D:\WINDOWS\system3 2\WBEM;D:\PROGRA~1\Borland\CBUILD~1\Projects\Bpl;D:\PROGRA~1 \Borland\CBUILD~1\Bin;D:\Programme\VDMSound;D:\PROGRA~1\Borl and\Delphi4\Bin;C:\WINDOWS;C:\WINDOWS\COMMAND;C:\PROGRA~1\BO RLAND\DELPHI4\BIN;C:\WINDOWS\Twain_32\SwUSB;C:\PROGRA~1\BORL AND\CBUILD~1\BIN;C:\PROGRA~1\BORLAND\CBUILD~1\PROJECTS\BPL
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_06-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_06
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_06-b05
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=de
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.core.jobs@2:start,
org.eclipse.core.runtime.compatibility.registry,
org.eclipse.equinox.registry@2:start, org.eclipse.equinox.preferences,
org.eclipse.core.contenttype, org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundlestore=J:\Anwendungen\Eclipse\eclipse3.2\eclipse\c onfiguration\org.eclipse.osgi\bundles
osgi.configuration.area=file:/J:/Anwendungen/Eclipse/eclipse 3.2/eclipse/configuration/
osgi.framework=file:/j:/Anwendungen/Eclipse/eclipse3.2/eclip se/plugins/org.eclipse.osgi_3.2.0.v20060214.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.0.v20060214
osgi.install.area=file:/J:/Anwendungen/Eclipse/eclipse3.2/ec lipse/
osgi.instance.area=file:/J:/Anwendungen/Eclipse/eclipse3.2/e clipse/workspace/
osgi.instance.area.default=file:/D:/Dokumente und
Einstellungen/Winfried/workspace/
osgi.logfile=J:\Anwendungen\Eclipse\eclipse3.2\eclipse\works pace\.metadata\.log
osgi.manifest.cache=J:\Anwendungen\Eclipse\eclipse3.2\eclips e\configuration\org.eclipse.osgi\manifests
osgi.nl=de_DE
osgi.os=win32
osgi.splashLocation=j:\Anwendungen\Eclipse\eclipse3.2\eclips e\plugins\org.eclipse.platform_3.2.0.v20060214-1600\splash.b mp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=j:\Anwendungen\Eclipse\eclipse3.2\eclipse\plugi ns
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=J:\Anwendungen\Java\JRE5.0_6\lib\rt.jar; J:\Anwendungen\Java\JRE5.0_6\lib\i18n.jar;J:\Anwendungen\Jav a\JRE5.0_6\lib\sunrsasign.jar;J:\Anwendungen\Java\JRE5.0_6\l ib\jsse.jar;J:\Anwendungen\Java\JRE5.0_6\lib\jce.jar;J:\Anwe ndungen\Java\JRE5.0_6\lib\charsets.jar;J:\Anwendungen\Java\J RE5.0_6\classes
sun.boot.library.path=J:\Anwendungen\Java\JRE5.0_6\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=DE
user.dir=J:\Anwendungen\Eclipse\eclipse3.2\eclipse
user.home=D:\Dokumente und Einstellungen\Winfried
user.language=de
user.name=Winfried
user.timezone=Europe/Berlin
user.variant=
*** Features:
org.eclipse.emf (2.2.0) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.ecore.sdo (2.2.0) "EMF Service Data Objects (SDO)"
org.eclipse.gef (3.2.0) "Graphical Editing Framework"
org.eclipse.jdt (3.2.0.v20060215-1200-0cq-cuim1y) "Eclipse Java Development
Tools"
org.eclipse.jdt.source (3.2.0.v20060215-1200-0cq-cuim1y) "Eclipse Java
Development Tools SDK"
org.eclipse.jem (1.2.0) "Java EMF Model"
org.eclipse.pde (3.2.0.v20060210--qSWJzJJez) "Eclipse Plug-in Development
Environment"
org.eclipse.pde.source (3.2.0.v20060210--qSWJzJJez) "Eclipse Plug-in
Development Environment Developer Resources"
org.eclipse.platform (3.2.0.v20060215-6arkIf-1sI) "Eclipse Platform"
org.eclipse.platform.source (3.2.0.v20060215-6arkIf-1sI) "Eclipse Platform
Plug-in Developer Resources"
org.eclipse.rcp (3.2.0.v20060210-3BlARRhN5X) "Eclipse RCP"
org.eclipse.rcp.source (3.2.0.v20060210-3BlARRhN5X) "Eclipse RCP Plug-in
org.eclipse.sdk (3.2.0.v20060210--hQXJzJJez) "Eclipse Project SDK"
org.eclipse.ve (1.2.0) "Visual Editor"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.2) "Event Model" [Resolved]
com.ibm.icu (3.4.2) "International Components for Unicode for Java (ICU4J)"
[Active]
com.ibm.icu.source (3.4.2) "International Components for Unicode for Java
(ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.18) "Jsch Plug-in" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.103.v20051212) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.100.v20060216) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.2.0.v20060216a) "Ant UI" [Resolved]
org.eclipse.compare (3.2.0.v20060209) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.0.v20051108) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060214-1600) "Commands" [Active]
org.eclipse.core.contenttype (3.2.0.v20060215a) "Eclipse Content Mechanism"
[Active]
org.eclipse.core.expressions (3.2.0.v20060215-1200) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.2.0.v20060215-1200) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060206) "Core File Systems" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20051114) "Core File System
for Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.v20060206) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.0.v20060214) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060123) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060130) "Core Resource Management
Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060216) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0.v20060123) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.0.v20060215a) "Eclipse
Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060209) "Core Variables" [Active]
org.eclipse.debug.core (3.2.0.v20060216e) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.0.v20060216e) "Debug UI" [Active]
org.eclipse.draw2d (3.2.0) "Draw2d" [Active]
org.eclipse.emf (2.2.0) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.ant (2.2.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.2.0) "EMF Template Code Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.2.0) "EMF Ecore Code Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.0) "EMF Ecore Code Generation UI"
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI"
[Resolved]
org.eclipse.emf.common (2.2.0) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.2.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
org.eclipse.emf.converter (2.2.0) "EMF Model Convert Support" [Resolved]
org.eclipse.emf.ecore (2.2.0) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.0) "EMF Ecore Change Model" [Active]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support"
[Resolved]
org.eclipse.emf.ecore.edit (2.2.0) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.2.0) "Sample Ecore Editor" [Resolved]
[Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO) Edit
Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO)
Editor" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.0) "EMF XMI" [Active]
org.eclipse.emf.edit (2.2.0) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.2.0) "EMF Edit UI" [Resolved]
org.eclipse.emf.exporter (2.2.0) "EMF Model Export Support" [Resolved]
org.eclipse.emf.importer (2.2.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.2.0) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.2.0) "EMF Annotated Java Importer"
[Resolved]
org.eclipse.emf.importer.rose (2.2.0) "EMF Rose Importer" [Resolved]
org.eclipse.emf.mapping (2.2.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0) "Ecore to Ecore Mapping"
[Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0) "Ecore to Ecore Mapping
Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0) "Ecore to XML Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.emf.mapping.ui (2.2.0) "EMF Mapping UI" [Resolved]
org.eclipse.equinox.common (1.0.0.v20060215a) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.preferences (1.0.0.v20060215a) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (3.2.0.v20060217) "Extension Registry Support"
[Active]
org.eclipse.gef (3.2.0) "Graphical Editing Framework" [Active]
org.eclipse.help (3.2.0.v20060212) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20051212) "Help Application Server"
[Resolved]
org.eclipse.help.base (3.2.0.v20060212) "Help System Base" [Resolved]
org.eclipse.help.ui (3.2.0.v20060212) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.0.v20060212) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.2.0.v20060216-0800) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.2.0.v20060214-2220) "Java Annotation Processing
Core" [Resolved]
org.eclipse.jdt.apt.ui (3.2.0.v20060214-2220) "Java Annotation Processing
UI" [Resolved]
org.eclipse.jdt.core (3.2.0.v_642) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.0.0.v20060215-1200) "Java Code
Manipulation Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.0.v20060216d) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.0.v20060215b) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.2.0.v20060215-1200) "Eclipse JDT Plug-in
Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060215-1200) "Eclipse Java Development
User Guide" [Resolved]
org.eclipse.jdt.junit (3.2.0.v20060215-1200) "Java Development Tools JUnit
support" [Resolved]
org.eclipse.jdt.junit.runtime (3.2.0.v20060215-1200) "Java Development Tools
JUnit runtime support" [Resolved]
org.eclipse.jdt.launching (3.2.0.v20060210a) "Java Development Tools
Launching Support" [Active]
Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.0.v20060217-1100) "Java Development Tools UI"
[Active]
org.eclipse.jem (1.2.0) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.2.0) "Java EMF Model BeanInfo (Introspection)
Support" [Active]
org.eclipse.jem.proxy (1.2.0) "Java EMF Model Proxy Support" [Active]
org.eclipse.jem.ui (1.2.0) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.2.0) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (1.2.0) "Java EMF Model Workbench Support"
[Resolved]
org.eclipse.jface (3.2.0.I20060216-1600) "JFace" [Active]
org.eclipse.jface.databinding (3.2.0.I20060214-1600) "JFace Data Binding"
[Resolved]
org.eclipse.jface.text (3.2.0.v20060215-1200) "JFace Text" [Active]
org.eclipse.ltk.core.refactoring (3.2.0.v20060215-1200) "Refactoring Core"
[Active]
org.eclipse.ltk.ui.refactoring (3.2.0.v20060215-1200) "Refactoring UI"
[Active]
org.eclipse.osgi.services (3.1.100.v20060109) "OSGi Release 3 Services"
[Resolved]
org.eclipse.osgi.util (3.1.100.v20060109) "OSGi R3 Utility Classes"
[Resolved]
org.eclipse.pde (3.2.0.v20060213-1200) "Eclipse Plug-in Development
Environment" [Resolved]
org.eclipse.pde.build (3.2.0.v20060217) "Plug-in Development Environment
Build Support" [Resolved]
org.eclipse.pde.core (3.2.0.v20060217-0800) "Plug-in Development Core"
[Resolved]
org.eclipse.pde.doc.user (3.1.0.v20060216-1600) "Eclipse Plug-in Development
org.eclipse.pde.junit.runtime (3.2.0.v20060213-1200) "PDE JUnit Plug-in
Test" [Resolved]
org.eclipse.pde.runtime (3.2.0.v20060131) "Plug-in Development Environment
Runtime" [Resolved]
Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.0.v20060216-1030) "Plug-in Development UI"
[Resolved]
org.eclipse.platform (3.2.0.v20060214-1600) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.2.0.I20060217-1100) "Eclipse Platform
Plug-in Developer Guide" [Resolved]
org.eclipse.platform.doc.user (3.2.0.v20060213-0010) "Eclipse Workbench User
Guide" [Resolved]
Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.win32.win32.x86 (3.2.0.v20060215-6arkIf-1sI)
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.2.0.v20051206) "Eclipse RCP" [Resolved]
org.eclipse.rcp.source.win32.win32.x86 (3.2.0.v20060210-3BlARRhN5X) "Eclipse
RCP Plug-in Developer Resources" [Resolved]
org.eclipse.sdk (3.2.0.v20060214) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.0.v20060217-1100) "Search Support" [Resolved]
org.eclipse.swt (3.2.0.v3224m) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.0.v3224) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.2.0.I200602141600) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.0.I200602161200) "CVS Team Provider Core"
[Resolved]
org.eclipse.team.cvs.ssh (3.2.0.I20051128) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.0.I200602161600) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.0.I200602170010) "CVS Team Provider UI"
[Resolved]
org.eclipse.team.ui (3.2.0.I200602170010) "Team Support UI" [Resolved]
org.eclipse.text (3.2.0.v20060215-1200) "Text" [Active]
org.eclipse.tomcat (4.1.130.v20060212) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.2.0.I20060216-1600) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060212) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.0.v20060212) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.v20060214) "Console" [Active]
org.eclipse.ui.editors (3.2.0.v20060215-1200) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.100.v20060206) "External Tools" [Active]
org.eclipse.ui.forms (3.2.0.v20060212b) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.2.0.I20060216-1200) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.0.v20060213) "Welcome Framework" [Resolved]
org.eclipse.ui.navigator (3.2.0.I20060210-0800) "Common Navigator View"
[Resolved]
org.eclipse.ui.navigator.resources (3.2.0.I20060210-0800) "Navigator
Workbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060207-0800) "R21 Presentation
Plug-in" [Resolved]
org.eclipse.ui.views (3.2.0.I20060207-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.0.I20060213-2000) "Tabbed
Properties View" [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060207-0800) "Eclipse UI Win32 Enhancements"
[Resolved]
org.eclipse.ui.workbench (3.2.0.I20060216-1600) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060207-0800) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060216-0800) "Text Editor
Framework" [Active]
org.eclipse.update.configurator (3.1.100.v20051214) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.1.100.v20051215a) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.1.100.v20051205) "Install/Update Core for
Windows" [Resolved]
org.eclipse.update.scheduler (3.1.100) "Automatic Updates Scheduler"
[Active]
org.eclipse.update.ui (3.1.100.v20051215) "Install/Update UI" [Resolved]
org.eclipse.ve (1.2.0) "Visual Editor" [Resolved]
org.eclipse.ve.cde (1.2.0) "Visual Editor Common Data Editor" [Active]
org.eclipse.ve.doc (1.2.0) "Visual Editor for Java User Guide" [Resolved]
org.eclipse.ve.java.core (1.2.0) "Visual Editor Java Core" [Active]
org.eclipse.ve.jfc (1.2.0) "Visual Editor for Java Foundation Classes"
[Active]
org.eclipse.ve.propertysheet (1.2.0) "Visual Editor PropertySheet" [Active]
org.eclipse.ve.swt (1.2.0) "Visual Editor for Standard Widget Toolkit"
[Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
system.bundle (3.2.0.v20060214) "OSGi System Bundle" [Active]
*** User Preferences:
#Wed Feb 22 18:55:02 CET 2006
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.ve.java.core/PALETTE_STATE=4
/instance/org.eclipse.ve.java.core/PALETTE_WIDTH=125
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.ui.ide/platformState=157
@org.eclipse.help.ui=3.2.0.v20060212
/project/BNK-Umfrage/org.eclipse.jdt.core/org.eclipse.jdt.co re.compiler.debug.localVariable=generate
@org.eclipse.ve.java.core=1.2.0
file_export_version=3.0
/project/BNK-Umfrage/org.eclipse.jdt.core/org.eclipse.jdt.co re.compiler.codegen.unusedLocal=preserve
@org.eclipse.jdt.ui=3.2.0.v20060217-1100
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templat es_migrated=true
/instance/org.eclipse.core.resources/version=1
/project/BNK-Umfrage/org.eclipse.jdt.core/org.eclipse.jdt.co re.compiler.compliance=1.3
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
/project/BNK-Umfrage/org.eclipse.jdt.core/org.eclipse.jdt.co re.compiler.codegen.inlineJsrBytecode=disabled
@org.eclipse.jdt.launching=3.2.0.v20060210a
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .source=1.5
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.eclipse.jdt.debug.ui.show_null_entries=true
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .compliance=1.5
/instance/org.eclipse.ui/showIntro=false
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@org.eclipse.jdt.core=3.2.0.v_642
/project/BNK-Umfrage/org.eclipse.jdt.ui/internal.default.com pliance=default
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=J\:\\Anw endungen\\Eclipse\\eclipse3.2\\eclipse\\workspace
/instance/org.eclipse.help.ui/browser.y=191
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
/instance/org.eclipse.help.ui/browser.x=98
/instance/org.eclipse.help.ui/browser.w=1024
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.assertIdentifier=error
/project/BNK-Umfrage/org.eclipse.jdt.core/org.eclipse.jdt.co re.compiler.problem.assertIdentifier=ignore
@org.eclipse.ui.ide=3.2.0.I20060216-1200
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/project/BNK-Umfrage/org.eclipse.jdt.core/org.eclipse.jdt.co re.compiler.debug.sourceFile=generate
/instance/org.eclipse.jdt.ui/fontPropagated=true
/project/BNK-Umfrage/org.eclipse.jdt.core/org.eclipse.jdt.co re.compiler.source=1.3
@org.eclipse.core.resources=3.2.0.v20060214
@org.eclipse.ui=3.2.0.I20060216-1600
@org.eclipse.jdt.debug.ui=3.2.0.v20060215b
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 1,0 "
defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="0" javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/"
name\="JRE5.0_6"
path\="J\:\\Anwendungen\\Java\\JRE5.0_6"/>\r\n</vmType>\r\n </vmSettings>\r\n
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.enumIdentifier=error
/instance/org.eclipse.help.ui/browser.h=768
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?><templates/>
@org.eclipse.ui.editors=3.2.0.v20060215-1200
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=10
/project/BNK-Umfrage/org.eclipse.jdt.core/org.eclipse.jdt.co re.compiler.debug.lineNumber=generate
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.targetPlatform=1.5
@org.eclipse.search=3.2.0.v20060217-1100
/project/BNK-Umfrage/org.eclipse.jdt.core/org.eclipse.jdt.co re.compiler.problem.enumIdentifier=ignore
/instance/org.eclipse.search/org.eclipse.search.defaultPersp ective=org.eclipse.search.defaultPerspective.none
/instance/org.eclipse.ve.cde/CUSTOMIZELAYOUTWINDOW_Y=616
/instance/org.eclipse.ve.cde/CUSTOMIZELAYOUTWINDOW_X=420
@org.eclipse.ve.cde=1.2.0
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/project/BNK-Umfrage/org.eclipse.jdt.core/org.eclipse.jdt.co re.compiler.codegen.targetPlatform=1.1
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDO W=false
*** Current Install Configuration:
Install configuration:
Last changed on 20.02.2006
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/configuratio n/org.eclipse.update/platform.xml
Configured sites:
platform:/base/
Configured features:
ID: org.eclipse.platform, Version: 3.2.0.v20060215-6arkIf-1sI
ID: org.eclipse.jdt, Version: 3.2.0.v20060215-1200-0cq-cuim1y
ID: org.eclipse.jdt.source, Version: 3.2.0.v20060215-1200-0cq-cuim1y
ID: org.eclipse.jem, Version: 1.2.0
ID: org.eclipse.pde.source, Version: 3.2.0.v20060210--qSWJzJJez
ID: org.eclipse.sdk, Version: 3.2.0.v20060210--hQXJzJJez
ID: org.eclipse.gef, Version: 3.2.0
ID: org.eclipse.rcp.source, Version: 3.2.0.v20060210-3BlARRhN5X
ID: org.eclipse.emf, Version: 2.2.0
ID: org.eclipse.rcp, Version: 3.2.0.v20060210-3BlARRhN5X
ID: org.eclipse.platform.source, Version: 3.2.0.v20060215-6arkIf-1sI
ID: org.eclipse.ve, Version: 1.2.0
ID: org.eclipse.pde, Version: 3.2.0.v20060210--qSWJzJJez
ID: org.eclipse.emf.ecore.sdo, Version: 2.2.0
Configured plug-ins:
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.workbench_3.2.0.I20060216-1600.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jdt.apt.ui_3.2.0.v20060214-2220.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.forms_3.2.0.v20060212b.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.core.runtime.compatibility.registry_3.2.0.v20060215a /
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.pde.runtime_3.2.0.v20060131.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.help.ui_3.2.0.v20060212.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.compare_3.2.0.v20060209.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jface.databinding_3.2.0.I20060214-1600.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.core.runtime.compatibility_3.1.0.v20060123.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.platform.doc.user_3.2.0.v20060213-0010.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.team.cvs.ssh_3.2.0.I20051128.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.workbench.compatibility_3.2.0.I20060207-0800/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.team.cvs.core_3.2.0.I200602161200.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.team.core_3.2.0.I200602141600.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.editors_3.2.0.v20060215-1200.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jdt.junit_3.2.0.v20060215-1200/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.core.resources.win32_3.2.0.v20060130.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.browser_3.2.0.v20060212.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.intro_3.2.0.v20060213.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jdt.debug_3.2.0.v20060216d/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.search_3.2.0.v20060217-1100.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.equinox.registry_3.2.0.v20060217.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.equinox.preferences_1.0.0.v20060215a.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.debug.ui_3.2.0.v20060216e.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.update.configurator_3.1.100.v20051214.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ltk.ui.refactoring_3.2.0.v20060215-1200.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jdt.apt.core_3.2.0.v20060214-2220.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. apache.ant_1.6.5/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.win32_3.2.0.I20060207-0800.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.pde.source_3.2.0.v20060210--qSWJzJJez/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.help.appserver_3.1.100.v20051212.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.team.cvs.ui_3.2.0.I200602170010.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.help.base_3.2.0.v20060212.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.rcp_3.2.0.v20051206.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.equinox.common_1.0.0.v20060215a.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ltk.core.refactoring_3.2.0.v20060215-1200.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.pde.junit.runtime_3.2.0.v20060213-1200/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.osgi.services_3.1.100.v20060109.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.update.core_3.1.100.v20051215a.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. junit_3.8.1/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.swt.win32.win32.x86_3.2.0.v3224.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jdt.launching_3.2.0.v20060210a.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.console_3.1.100.v20060214.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.osgi_3.2.0.v20060214.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.osgi.util_3.1.100.v20060109.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.swt_3.2.0.v3224m.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.core.boot_3.1.0.v20051108.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.core.commands_3.2.0.I20060214-1600.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ant.ui_3.2.0.v20060216a.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.tomcat_4.1.130.v20060212/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.platform.source_3.2.0.v20060215-6arkIf-1sI/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.cheatsheets_3.2.0.v20060212.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.update.scheduler_3.1.100.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.pde.ui_3.2.0.v20060216-1030.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.pde.doc.user_3.1.0.v20060216-1600.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.sdk_3.2.0.v20060214/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.team.ui_3.2.0.I200602170010.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui_3.2.0.I20060216-1600.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.navigator_3.2.0.I20060210-0800.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.help.webapp_3.2.0.v20060212/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.core.filesystem.win32.x86_1.0.0.v20051114.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.update.core.win32_3.1.100.v20051205.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.core.resources.compatibility_3.2.0.v20060123.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.navigator.resources_3.2.0.I20060210-0800.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.views_3.2.0.I20060207-0800.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jdt_3.2.0.v20060216-0800.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jdt.junit.runtime_3.2.0.v20060215-1200/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.text_3.2.0.v20060215-1200.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.presentations.r21_3.2.0.I20060207-0800.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.platform.source.win32.win32.x86_3.2.0.v20060215-6ark If-1sI/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.workbench.texteditor_3.2.0.v20060216-0800.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.debug.core_3.2.0.v20060216e.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jface_3.2.0.I20060216-1600.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.core.runtime_3.2.0.v20060216.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. apache.lucene_1.4.103.v20051212/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.platform_3.2.0.v20060214-1600/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.externaltools_3.1.100.v20060206.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jdt.core_3.2.0.v_642.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.platform.doc.isv_3.2.0.I20060217-1100.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.ide_3.2.0.I20060216-1200.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.rcp.source_3.2.0.v20060210-3BlARRhN5X/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.core.jobs_3.2.0.v20060206.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jdt.ui_3.2.0.v20060217-1100.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ui.views.properties.tabbed_3.2.0.I20060213-2000.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.pde.core_3.2.0.v20060217-0800.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.update.ui_3.1.100.v20051215.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.core.expressions_3.2.0.v20060215-1200.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.rcp.source.win32.win32.x86_3.2.0.v20060210-3BlARRhN5 X/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.core.resources_3.2.0.v20060214.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.core.filebuffers_3.2.0.v20060215-1200.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.pde.build_3.2.0.v20060217/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.team.cvs.ssh2_3.2.0.I200602161600/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.core.variables_3.1.100.v20060209.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jdt.core.manipulation_1.0.0.v20060215-1200.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jdt.source_3.2.0.v20060215-1200-0cq-cuim1y/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jdt.doc.isv_3.2.0.v20060215-1200.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jdt.debug.ui_3.2.0.v20060215b.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.core.filesystem_1.0.0.v20060206.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.core.contenttype_3.2.0.v20060215a.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jdt.doc.user_3.2.0.v20060215-1200.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jface.text_3.2.0.v20060215-1200.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ant.core_3.1.100.v20060216.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.help_3.2.0.v20060212.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.pde_3.2.0.v20060213-1200.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/com. ibm.icu.source_3.4.2/
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/com. jcraft.jsch_0.1.18.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/com. ibm.icu_3.4.2.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.gef_3.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.draw2d_3.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.ant_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.codegen.ecore.ui_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.codegen.ecore_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.codegen.ui_2.1.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.codegen_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.common.ui_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.common_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.commonj.sdo_2.1.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.converter_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.ecore.change.edit_2.1.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.ecore.change_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.ecore.edit_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.ecore.editor_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.ecore.sdo.edit_2.1.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.ecore.sdo.editor_2.1.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.ecore.sdo_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.ecore.xmi_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.ecore_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.edit.ui_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.edit_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.exporter_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.importer.ecore_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.importer.java_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.importer.rose_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.importer_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.mapping.ecore2ecore.editor_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.mapping.ecore2ecore_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.mapping.ecore2xml.ui_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.mapping.ecore2xml_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.mapping.ui_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf.mapping_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.emf_2.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/com. ibm.etools.emf.event_3.0.0.2.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jem.beaninfo_1.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jem.proxy_1.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jem.ui_1.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jem.util_1.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jem.workbench_1.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.jem_1.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ve.cde_1.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ve.doc_1.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ve.java.core_1.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ve.jfc_1.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ve.propertysheet_1.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ve.swt_1.2.0.jar
file:/J:/Anwendungen/Eclipse/eclipse3.2/eclipse/plugins/org. eclipse.ve_1.2.0.jar
news:dti1po$h0l$1@utils.eclipse.org...
> configuration?
>> in
> Rich Kulp
Re: changing color of AWT.label (1.2M1) [message #118766 is a reply to message #118752] |
Wed, 22 February 2006 19:52 |
Can you give me your entire class as is? I can see no reason why this
should be failing. There must be something else in the class that is
interfering.
Rich Kulp
Re: changing color of AWT.label (1.2M1) [message #118840 is a reply to message #118766] |
Thu, 23 February 2006 07:53 |
I sent you a private mail. It's an applet that should run at 600x400.
What I do to get the error: Run the applet from within Eclipse. Do a change
at an awt.labe. Run it again. So far it looks good. Exit Eclipse and start
it again. The label appears with an exclamation mark with on-mouse-over
error message.
news:dtifdm$9km$1@utils.eclipse.org...
> interfering.
Re: changing color of AWT.label (1.2M1) [message #118916 is a reply to message #118840] |
Thu, 23 February 2006 16:06 |
--------------090506080600080608080108
It doesn't fail for me. I just tried it and everything is fine.
What did you mean run at 600x400? Do you mean you have your screen
resolution set down to that? I couldn't do that, my screen wouldn't go
that low.
So, let's see if we can get some more info logged from your machine.
Take the attached file (.options) and put it in your current directory
from where you start your eclipse and then start eclipse with the -debug
option. For example if you system looks like this:
c:\Eclipse32
.options
eclipse\
eclipse.exe
And you have a command prompt up with the current directory being
c:\Eclipse32, use the following to start it:
c:\Eclipse32> eclipse\eclipse -debug
This should put a better trace message into the log file that you can
then send to me.
> error message.
>>interfering.
Rich Kulp
name=".options"
Content-Disposition: inline;
filename=".options"
org.eclipse.ve.cde/debug/logtrace=default
org.eclipse.ve.cde/debug/logtracefile=default
org.eclipse.ve.cde/debug/loglevel=INFO
--------------090506080600080608080108--
Re: changing color of AWT.label (1.2M1) [message #118928 is a reply to message #118916] |
Thu, 23 February 2006 17:20 |
I sent you the log with this error includes.
600x400 is not the screen resolution but the applet size in the browser, so
it looks good.
news:dtkmhv$ucl$1@utils.eclipse.org...
> that low.
> c:\Eclipse32
> .options
> eclipse\
> eclipse.exe
> then send to me.
Re: changing color of AWT.label (1.2M1) [message #118941 is a reply to message #118928] |
Thu, 23 February 2006 19:56 |
Thanks, I understand what is going on now. Please open a defect against
VE, subcomponent Java Core.
Title: Invalid Expression Order error when changing a property that is a
static field access.
The problem is it is not parsing the java.awt.Color.black correctly when
coming back up from our internal cache files. It thinks it is a class
named java.awt.Color.black, and not a field access to the field black
within java.awt.Color class.
A workaround for now is to simply click on the Pause button twice on the
toolbar. It looks like two short vertical yellow bars. This causes us to
throw away the cache for only that class and to reconstruct it from
parsing the class. You have been doing a clean, but for this problem
that is overkill.
Rich Kulp
Re: changing color of AWT.label (1.2M1) [message #118955 is a reply to message #118941] |
Fri, 24 February 2006 08:04 |
Thanks, the workaround works for me.
I wonder why you could not reproduce the problem first.
I'm afraid "open a defect against VE" is something you must do for me, I
don't know how and my English and my understanding of Java is not good
enough.
> parsing the class. You have been doing a clean, but for this problem that
> is overkill.
Re: changing color of AWT.label (1.2M1) [message #118967 is a reply to message #118955] |
Fri, 24 February 2006 20:26 |
The reason was I was focused on changing properties. Not the change of
the color property. I was just going along and changing the property I
normally change on a label, the "text" property. But since that was just
a quoted string and not a static field reference the problem did not
surface. It wasn't until I got your code and realized that you said you
had changed the color that it dawned on me I was changing the wrong
property. :-(
> enough.
Rich Kulp
Re: changing color of AWT.label (1.2M1) [message #612155 is a reply to message #118597] |
> first fine.
> get an error:
Rich Kulp
Re: changing color of AWT.label (1.2M1) [message #612159 is a reply to message #118624] |
with 3.2M4.
Code is simple:
Font.BOLD, 18));
Hope that helps.
> integration build.
> Regards...
> Peter Walker
> VE Development
>> is first fine.
>> I get an error:
Re: changing color of AWT.label (1.2M1) [message #612160 is a reply to message #118651] |
Rich Kulp
Re: changing color of AWT.label (1.2M1) [message #612162 is a reply to message #118663] |
Re: changing color of AWT.label (1.2M1) [message #612163 is a reply to message #118663] |
Re: changing color of AWT.label (1.2M1) [message #612166 is a reply to message #118697] |
configuration?
Rich Kulp
Re: changing color of AWT.label (1.2M1) [message #612167 is a reply to message #118735] |
on-mouse info:
win32
-ws
win32
-arch
x86
-launcher
-name
Eclipse
-showsplash
600
-exitdata
824_6c
-vm
-Xmx256m
-jar
eof=eof
file.separator=\
line.separator=
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.nl=de_DE
osgi.os=win32
osgi.ws=win32
path.separator=;
sun.cpu.isalist=
sun.desktop=windows
user.country=DE
user.language=de
user.name=Winfried
user.variant=
*** Features:
Tools"
Environment"
[Active]
[Active]
[Active]
[Active]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
Support" [Resolved]
Editor" [Resolved]
[Resolved]
[Resolved]
Editor" [Resolved]
[Resolved]
[Active]
Mechanism" [Active]
[Active]
[Resolved]
[Resolved]
Core" [Resolved]
UI" [Resolved]
support" [Resolved]
[Active]
Support" [Active]
[Resolved]
[Resolved]
[Active]
[Active]
[Resolved]
[Resolved]
[Resolved]
Test" [Resolved]
Runtime" [Resolved]
[Resolved]
Guide" [Resolved]
Windows" [Resolved]
[Resolved]
[Resolved]
[Resolved]
Plug-in" [Resolved]
[Resolved]
Framework" [Active]
Windows" [Resolved]
[Active]
[Active]
[Resolved]
name\="JRE5.0_6"
Configured sites:
platform:/base/
> configuration?
>> in
> Rich Kulp
Re: changing color of AWT.label (1.2M1) [message #612168 is a reply to message #118752] |
interfering.
Rich Kulp
Re: changing color of AWT.label (1.2M1) [message #612174 is a reply to message #118766] |
error message.
> interfering.
Re: changing color of AWT.label (1.2M1) [message #612180 is a reply to message #118840] |
that low.
c:\Eclipse32
.options
eclipse\
eclipse.exe
then send to me.
> error message.
>>interfering.
Rich Kulp
name=".options"
filename=".options"
Re: changing color of AWT.label (1.2M1) [message #612181 is a reply to message #118916] |
it looks good.
> that low.
> c:\Eclipse32
> .options
> eclipse\
> eclipse.exe
> then send to me.
Re: changing color of AWT.label (1.2M1) [message #612182 is a reply to message #118928] |
that is overkill.
Rich Kulp
Re: changing color of AWT.label (1.2M1) [message #612183 is a reply to message #118941] |
enough.
> is overkill.
Re: changing color of AWT.label (1.2M1) [message #612184 is a reply to message #118955] |
property. :-(
> enough.
Rich Kulp
Current Time: Sun Oct 06 06:58:48 GMT 2024
Powered by FUDForum. Page generated in 0.06234 seconds
