Home » Eclipse Projects » GEF » I'm missing something obvious with this whole EditPolicy/Request architecture...
| I'm missing something obvious with this whole EditPolicy/Request architecture... [message #118578] |
Fri, 20 February 2004 11:02  |
Originally posted by: daniel_nospam.enigmatec.net
Hi there,
Say I want to just listen for selection of an EditPart. So I create an
EditPart and register an EditPolicy. For example the following:
protected void createEditPolicies() {
installEditPolicy(EditPolicy.SELECTION_FEEDBACK_ROLE, new
MyEditPolicy());
And then I have my own EditPolicy as follows:
private final class MyEditPolicy extends SelectionEditPolicy {
/* (non-Javadoc)
* @see
org.eclipse.gef.editpolicies.SelectionEditPolicy#hideSelecti on()
protected void hideSelection() {
System.err.println("hideSelection");
// Called when the user clicks away from the assoc message
label
/* (non-Javadoc)
* @see
org.eclipse.gef.editpolicies.SelectionEditPolicy#showSelecti on()
protected void showSelection() {
System.err.println("showSelection");
// Called when the user clicks on the assoc message label
public Command getCommand(Request request) {
System.err.println("getCommand: " + request.getType());
return [something];
So hide() and show() are fired as expected... only I want to use
Requests. So I examine them, but the only requests ever fired have a type
of "delete". These are also always GroupRequests. Is there no such thing
as a request of type "selection"? GroupRequest does not provide me with
anything useful for what I want, e.g. location of the mouse pointer.
I've tried different EditPolicies and roles only the same thing, just
"delete" all the time.
Can anyone help here?
Thanks, Dan
| Re: I'm missing something obvious with this whole EditPolicy/Request architecture... [message #118796 is a reply to message #118732] |
Sun, 22 February 2004 09:18   |
Originally posted by: dan.gravellnospam.mochamail.com
All I want is a small clickable icon on the drawing surface of my
editor. Located somewhere near one of my EditParts (actually a
Connection). When the user clicks on the icon they get a popup allowing
them to associate something with the Connection.
What I do now is create the icon as a child EditPart of the Connection.
This would be accomplished ideally with GEF commands for undo/redo
functionality. I thought this could be done with Requests, selecting the
icon (which would be an EditPart I thought) would cause some kind of
request, no?
Thanks, Dan
Randy Hudson wrote:
> What are you trying to do? Selection has nothing to do with mouse location,
> you can select with the keyboard.
> "Dan Gravell" <daniel_nospam@enigmatec.net> wrote in message
> news:Xns9495A3B962C66danielnospamenigmate@204.138.98.10...
>>Hi there,
>>MyEditPolicy());
>>/* (non-Javadoc)
>>* @see
>>label
>>/* (non-Javadoc)
>>* @see
>>return [something];
>>Thanks, Dan
| Re: I'm missing something obvious with this whole EditPolicy/Request architecture... [message #119017 is a reply to message #118796] |
Mon, 23 February 2004 11:39   |
"Dan Gravell" <dan.gravellnospam@mochamail.com> wrote in message
news:c1adgb$6b4$1@eclipse.org...
Can I delete this "child"? Drag it? If not, it could just be a figure
which decorates the PolylineConnection figure.
> request, no?
If the child is its own editpart, it will receive OPEN and DIRECT_EDIT
requests. But, even if it is NOT an editpart, the connection will receive
these requests, and the connection can compare the request *location* to the
location of the icon figure.
> Thanks, Dan
location,
> >>Hi there,
> >>MyEditPolicy());
> >>/* (non-Javadoc)
> >>* @see
> >>label
> >>/* (non-Javadoc)
> >>* @see
> >>return [something];
type
> >>Thanks, Dan
| Re: I'm missing something obvious with this whole EditPolicy/Request architecture... [message #119214 is a reply to message #119017] |
Tue, 24 February 2004 03:50   |
Originally posted by: dan.gravellnospam.enigmatec.net
Well that's the problem. I don't get OPEN or DIRECT_EDIT requests, just
GroupRequests with type "delete". I think the editor must be configured
incorrectly somewhere (this is an existing codebase I'm working on here).
Thanks, Dan
>>request, no?
>>Thanks, Dan
> location,
>>>>Hi there,
>>>>MyEditPolicy());
>>>>/* (non-Javadoc)
>>>>* @see
>>>>label
>>>>/* (non-Javadoc)
>>>>* @see
>>>>return [something];
> type
>>>>Thanks, Dan
| Re: I'm missing something obvious with this whole EditPolicy/Request architecture... [message #119333 is a reply to message #119214] |
Tue, 24 February 2004 14:05  |
This is working fine for me. performRequest is called with both types of
requests for wires in the logic example.
"Dan Gravell" <dan.gravellnospam@enigmatec.net> wrote in message
news:c1f32n$em8$1@eclipse.org...
> Thanks, Dan
> >>request, no?
receive
the
> >>Thanks, Dan
> > location,
> >>>>Hi there,
> >>>>MyEditPolicy());
> >>>>/* (non-Javadoc)
> >>>>* @see
> >>>>label
> >>>>/* (non-Javadoc)
> >>>>* @see
> >>>>return [something];
> > type
thing
with
> >>>>Thanks, Dan
Current Time: Mon Oct 27 01:08:14 EDT 2025
Powered by FUDForum. Page generated in 0.10416 seconds
