Home » Newcomers » Newcomers » Line spacing problem in Eclipse 3.0 on Solaris/Motif
Line spacing problem in Eclipse 3.0 on Solaris/Motif [message #118562] Sat, 19 November 2005 23:26 Go to next message
Originally posted by: gracin.tel.fer.hr
Hello!
I'm using Eclipse 3.0.0 on Solaris/x86 with Motif. Everything works
fine, more or less, but there's one problem. In Java editor, the width
of lines is very big, regardless of the chosen font, and it appears as
if line spacing is 2 or something. Does anyone have an idea how I can
change this?
I've set up a fontList X resource and it is honored by other widgets
(navigator etc.) and they look nice, with normal space between lines.
But this does not influence Java editor window.
Thanks!
Re: Line spacing problem in Eclipse 3.0 on Solaris/Motif [message #118908 is a reply to message #118562] Tue, 22 November 2005 03:19 Go to previous messageGo to next message
> change this?
I'm not sure how to fix this, but it does sound like a bug. Can you
file a bug about this at:
http://bugs.eclipse.org/bugs/
Against Platform, component SWT. Please include a screenshot. Even
better if you can reproduce using a 3.2 milestone. :)
-Billy
Re: Line spacing problem in Eclipse 3.0 on Solaris/Motif [message #119618 is a reply to message #118908] Thu, 24 November 2005 21:36 Go to previous message
Sure, I'll do that.
Here it is: http://veeone.tel.fer.hr/~gracin/eclipse.png
> Even better if you can reproduce using a 3.2 milestone. :)
Oh boy, I wish I could try that! However, this is on Solaris/x86
platform and the latest version is 3.0, with Motif support.
Previous Topic:JDK 1.5 library problems
Next Topic:Replacing Java file header comment globally in a project
Current Time: Fri Nov 08 22:04:29 GMT 2024
Powered by FUDForum. Page generated in 0.07149 seconds
