Re: Logging in AGR [message #118560 is a reply to message #118553] |
Fri, 23 November 2007 11:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Paul Slauenwhite![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=paulslau%40ca.ibm.com) Messages: 975 Registered: July 2009 |
Hi Channing,
You are using a dated version of the AGR documentation. For 4.4.x,
please see:
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-4-0.html
If you still find an issue with the documentation, please open a defect
against the Test.Doc component:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=TPTP%20T esting
Currently, there is no logging infrastructure for unresolved widgets.
The only notification is the error dialog and an entry in the test execution
file (e.g. *.execution).
Paul
"Channing Walton" <channingwalton@mac.com> wrote in message
news:fi48qv$93d$1@build.eclipse.org...
> I am using TPTP (4.4.1) with AGR (4.1) on Eclipse 3.3.1.1, and would like
> to add reporting for unresolved widgets. I am following the guide at
> http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI.html,
> section 2.4.2, but there are inconsistencies with the documentation and
> reality.
> The first two points in the guide are:
> 1. Add a new test case: Open the test suite > Switch to the 'Test Cases'
> page > Click on 'Add'
> 2. Start a fresh workbench: Start a workbench with a different workspace >
> Click on the 'Window' menu > Preferences... > Select Profiling and Logging
> > Check the option 'Enable logging' > OK
> There is no Add button on the test cases page, and no 'Enable Logging'
> option in the preference page described.
> I would appreciate some help in getting started.
> I would also like to report this as a bug against the documentation but
> there is no option for AGR in bugzilla. Where should I report problems?
> Channing
FUDForum. Page generated in 0.02954 seconds
