Home » Language IDEs » ServerTools (WTP) » Installing WTP on Eclipse 3.1
Installing WTP on Eclipse 3.1 [message #118552] Fri, 08 July 2005 15:51 Go to next message
David Goodenough is currently offline David GoodenoughFriend
As I understand it (and this may of course be my mistake) the latest build
of WTP works on Eclipse 3.1. I am completely failing to get it to work
and would be greatful of any help anyone could give.
I installed a fresh version of 3.1 (I have been using 3.0 with Lomboz for
a while now for Java and JSP development) and added the pre-reqs for WTP
and then WTP. But I can not find any bits of WTP anywhere on the
Eclipse window. I have looked in the logs but there is nothing there
saying that there are any problems, and I have tried running eclipse -clean
to ensure that the new plugins and features are notes.
Looking at the Configuration logs it says that the plugins are Installed
and there are not errors that I can see anywhere. Any ideas as to where
I look next?
David
Re: Installing WTP on Eclipse 3.1 [message #118579 is a reply to message #118552] Fri, 08 July 2005 18:44 Go to previous messageGo to next message
Haris Peco is currently offline Haris PecoFriend
try open xml or jsp file ?
> -clean to ensure that the new plugins and features are notes.
> I look next?
> David
Re: Installing WTP on Eclipse 3.1 [message #118583 is a reply to message #118552] Fri, 08 July 2005 17:19 Go to previous messageGo to next message
Dave Carlson is currently offline Dave CarlsonFriend
David,
In the configuration log, "Installed" does not mean the plugin is available.
It must show "Resolved", i.e. all prereqs are resolved.
Check your .metadata/.log file, it may show more information about missing
prereqs.
Dave Carlson
"David Goodenough" <david.goodenough@btconnect.com> wrote in message
news:dam7dj$vug$1@news.eclipse.org...
> I look next?
> David
Re: Installing WTP on Eclipse 3.1 [message #118585 is a reply to message #118579] Fri, 08 July 2005 17:24 Go to previous messageGo to next message
>> build
>> I look next?
>> David
It just opens it as a flat file. No colour highlighting, and no auto
completion.
David
Re: Installing WTP on Eclipse 3.1 [message #118588 is a reply to message #118583] Fri, 08 July 2005 17:26 Go to previous messageGo to next message
Dave Carlson wrote:
> David,
> available. It must show "Resolved", i.e. all prereqs are resolved.
> prereqs.
> Dave Carlson
>> I look next?
>> David
Some are Resolved, but not all. However the .metadata/.log file has nothing
referring to missing pre-reqs.
David
Re: Installing WTP on Eclipse 3.1 [message #118594 is a reply to message #118588] Fri, 08 July 2005 17:46 Go to previous messageGo to next message
Originally posted by: dkantala.modulant.com
Goto Help -> Software Updates -> Manage Configurations
Expand "Eclipse SDK" and the expand "C:\eclipse"
The "C:\eclipse" maybe different depending on where you installed it.
Make sure the following are enabled (pay attention to version numbers).
They will not have a non-smoking circle if they are enabled. Once
everything is enabled, you should have a new perspective called J2EE.
Eclipse SDK 3.1.0
EMF SDK 2.1.0.I200506230200
GEF SDK 3.1.0
J2EE Standard Tools Feature and Web Standard Tools Feature SDK 0.7.0
Java EMF Model SDK 1.1.0
Visual Editor SDK 1.0.2.1
Here are the locations if you do not have any of them installed.
Eclipse SDK 3.1.0:
http://eclipse.org/downloads/index.php
EMF:
http://download.eclipse.org/webtools/downloads/drivers/emf-s do-xsd-SDK-I200506230200.zip
GEF:
http://download.eclipse.org/webtools/downloads/drivers/GEF-S DK-3.1RC4.zip
J2EE Standard Tools Feature and Web Standard Tools Feature SDK 0.7.0:
http://download.eclipse.org/webtools/downloads/drops/S-1.0M5 -200506302219/wtp-1.0M5.zip
Java EMF Model SDK 1.1.0:
http://download.eclipse.org/webtools/downloads/drivers/JEM-S DK-I20050623.zip
The Visual Editor I believe is standard and I am pretty sure I have done
one update to it. I do have a little X on it, so that maybe fine for now.
Also, I have a configuration for J2EE Standard Tools Feature and Web
Standard Tools Feature SDK 1.0.0. That one does not work, disable that
if you have to and enable 0.7.0 instead.
You probably don't have to install the SDK version of the plugins, but I
am sending you a setup that works for me.
Hope this helps,
> Dave Carlson wrote:
>>David,
>>prereqs.
>>Dave Carlson
>>>I look next?
>>>David
> David
Re: Installing WTP on Eclipse 3.1 [message #118649 is a reply to message #118585] Fri, 08 July 2005 22:39 Go to previous messageGo to next message
>>> build
>>> for a while now for Java and JSP development) and added the pre-reqs for
>>> WTP
>>> I look next?
>>> David
> completion.
> David
see open with - is there xml editor ? try add files association
Re: Installing WTP on Eclipse 3.1 [message #118973 is a reply to message #118594] Sun, 10 July 2005 13:57 Go to previous messageGo to next message
Originally posted by: graffiti.yahoo.com
On Fri, 08 Jul 2005 13:46:25 -0400, Dmytro Kantala wrote:
> Hope this helps,
Thanks a lot! I don't know whether it helped the original poster, but
it certainly has helped me!!
thx,
bB
Re: Installing WTP on Eclipse 3.1 [message #119041 is a reply to message #118594] Sun, 10 July 2005 22:15 Go to previous messageGo to next message
While I now have the components Resolved rather than Installed
this has not fixed the problem. I still can not find any
trace of the action function of WTP. For instance JSP files
have no context completion or colouring.
David
> Eclipse SDK 3.1.0
> GEF SDK 3.1.0
> Eclipse SDK 3.1.0:
> EMF:
> GEF:
> now.
> Hope this helps,
>> Dave Carlson wrote:
>>>David,
>>>missing prereqs.
>>>Dave Carlson
>>>>I look next?
>>>>David
>> nothing referring to missing pre-reqs.
>> David
Re: Installing WTP on Eclipse 3.1 [message #119132 is a reply to message #119041] Mon, 11 July 2005 07:41 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Are you seeing any errors in your .log file? Have you installed
anything more than WTP and its prereqs?
- Nitin
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Installing WTP on Eclipse 3.1 [message #119247 is a reply to message #119132] Mon, 11 July 2005 10:23 Go to previous messageGo to next message
As I said earlier in this thread there are no errors in the .log file.
I did try installing the Lomboz stuff, but I cleared the entire
directory three for eclipse 3.1 and reinstalled.
David
Re: Installing WTP on Eclipse 3.1 [message #119308 is a reply to message #119247] Mon, 11 July 2005 14:17 Go to previous messageGo to next message
Have you tried creating a new workspace (don't import any previous work)
and testing to see if WTP works in that? Do a File -> New -> Project
and see if there is a J2EE folder.
This is based on the assumption that even after you cleared the entire
eclipse directory, your opening up the previous workspace. I am not
sure if anything in the old workspace may cause issues.
> David
Re: Installing WTP on Eclipse 3.1 [message #119336 is a reply to message #119308] Mon, 11 July 2005 14:44 Go to previous messageGo to next message
I had not tried this, but I have now.
I unpacked Eclipse 3.1, emf-sdo-xsd-SDK, GEF-SDK-3.1, GEM-SDK-I20050623
and WTP-1.0M5 into a new, empty eclipse directory, and then started it
from a totally new workspace directory. I got the same result.
In the About Eclipse Configuration log, all plugins are either Resolved
or Active. In the newly created workspace there is NO .log file in the
..metadata directory.
I am running on a Debian unstable system with Sun Java 1.5.0-b64.
David
>> David
Re: Installing WTP on Eclipse 3.1 [message #119349 is a reply to message #118594] Mon, 11 July 2005 14:48 Go to previous messageGo to next message
Originally posted by: felicia.burkard.gmx.de
hello,
i wanted to try some tutorials with web services and so on. but i just
cant get the wtp to work.
i took all the files as suggested in this thread (eclipse-SDK-3.1-win32,
emf-sdo-xsd-SDK-I200506230200, GEF-SDK-3.1RC4, JEM-SDK-I20050623,
wtp-1.0M5)
when i start eclipse i get the j2ee view and everything looks fine, but as
soon as i create a project and want to work in that everythings stucks...
Eclipse says "Building workspace: (60%)"
end this never finishes...
can somebody help me with that?
thx
Re: Installing WTP on Eclipse 3.1 [message #119455 is a reply to message #119336] Mon, 11 July 2005 18:55 Go to previous messageGo to next message
Travis Hume is currently offline Travis HumeFriend
I'm having the same problem since M5. Tried clean workspace without luck.
The editors don't seem to be registered because I can't even associate
extensions.
Re: Installing WTP on Eclipse 3.1 [message #119656 is a reply to message #119041] Tue, 12 July 2005 07:24 Go to previous messageGo to next message
hello,
i took all the files as suggested in this thread (Eclipse SDK 3.1.0, EMF,
GEF, J2EE Standard Tools Feature and Web Standard Tools Feature SDK 0.7.0,
Java EMF Model SDK 1.1.0)
can somebody help me with that please?
thanks a lot!
Re: Installing WTP on Eclipse 3.1 [message #119745 is a reply to message #119656] Tue, 12 July 2005 08:07 Go to previous messageGo to next message
edit:
it takes a lot of time for building the workspace and stopps with the
errors:
"cvc-elt.1: Cannot find the declaration of element 'web-app'."
and
"schema_reference.4:Failed to read schema document..."
so i can not work in the projekt.
can somebody help me with that please???
(i am pretty new to eclipse)
thanks a lot!
Re: Installing WTP on Eclipse 3.1 [message #120491 is a reply to message #119455] Wed, 13 July 2005 18:03 Go to previous message
Originally posted by: schulz.sce.carleton.ca
I had the same problem until a few minutes ago. It seems really
important to have at least the versions installed named as requirements.
And also important, not to confuse the JEM parts within VE with the JEM
package referred to as requirement. The latter requires EMF 2.1.0 to be
installed (which does not come with eclipse 3.1 containing EMF 2.0.1!).
I found it quite helpful to not copy the plugins into the eclipse folder
but to extract the plugins somewhere else and use the eclipse update
facility ("New local site ..." pointing to the eclipse folder created by
extracting the plugins). This is, because the update facility shows, if
the required packages for a plugin are yet to be installed.
Maybe this helps.
Stefan
> luck. The editors don't seem to be registered because I can't even
> associate extensions.
Previous Topic:problem with tomcat on eclipse 3.1
Next Topic:Do not have "J2EE Web Project" in wtp-eclipse-emf-gef-jem-sdk-1.0M4
Current Time: Sat Dec 21 16:49:37 GMT 2024
Powered by FUDForum. Page generated in 0.04834 seconds
