What is EngineHome for Birt 2.0.0 ? [message #118542] |
Fri, 27 January 2006 12:06 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: rani.gmail.com
hi
i generated report in birt 2.0.0 and Run the RunReport.java
here in this program Engine home is pointing to as follows
config.setEngineHome( "c:\\eclipse3.1
\\eclipse\\plugins\\org.eclipse.birt.report.viewer_1.0.1\\bi rt " );
and its showing following error
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper openReportDesign
SEVERE: invalid design file E:\Metrikus_Reports\Test2.rptdesign
Report Test2.rptdesign not found!
i thing its due to Engine home
could tell me to which folder i have to point in Birt 2.0.0 for Engine home
rani
Re: What is EngineHome for Birt 2.0.0 ? [message #118636 is a reply to message #118542] |
Fri, 27 January 2006 12:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jan.tanis.coas.com
Hi Rani,
This is my engine home:
C:\\birt\\2.0\\birt-runtime-2_0_0\\Report Engine
But it seems to me that not your engine home is incorrect but that it
just can't find the report file you want to generate.
Regards, Jan.
rani wrote:
> hi
> i generated report in birt 2.0.0 and Run the RunReport.java here in this
> rani
Re: What is EngineHome for Birt 2.0.0 ? [message #124906 is a reply to message #118542] |
Mon, 06 February 2006 18:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
You need to download the Report Engine seperately.
Take a look at the Report Engine API page.
http://www.eclipse.org/birt/phoenix/deploy/reportEngineAPI.p hp
Jason Weathersby
BIRT PMC
"rani" <rani@gmail.com> wrote in message
news:15a5dc4018c8c82c106163fd3b389575$1@www.eclipse.org...
> hi
> openReportDesign
> home
> rani
Re: What is EngineHome for Birt 2.0.0 ? [message #129027 is a reply to message #124906] |
Mon, 13 February 2006 11:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: huy.banh.gmail.com
Hello Jason,
I ran into this problem for almost a week and still can not get rig of
this yet. I have
config.setEngineHome( "/home/hbanh/birt-runtime-2_0_0/Report Engine" );
I always got "The output format html is not support" error.
I tried with other ways as setting env variable and passing system
property. All do not work.
Could you please tell me if I am still missing something? I browsed this
list already, but can't see any.
(PS: I am able to preview my report with the eclipse IDE. The error
happens at the line that calling IRunAndRenderTask.run(); )
> Jason Weathersby
> BIRT PMC
>>hi
>>openReportDesign
>>home
>>rani
Re: What is EngineHome for Birt 2.0.0 ? [message #129175 is a reply to message #129027] |
Mon, 13 February 2006 12:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Can you try renaming the directory to ReportEngine?
Delete the space between Report and Engine.
Jason
"Huy Banh" <huy.banh@gmail.com> wrote in message
news:43F06740.5020204@gmail.com...
> Hello Jason,
> this yet. I have
>> Jason Weathersby
>> BIRT PMC
>>>hi
>>>openReportDesign
>>>home
>>>rani
Re: What is EngineHome for Birt 2.0.0 ? [message #129573 is a reply to message #129175] |
Tue, 14 February 2006 01:48 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thank you, Jason.
I did try renaming "Report Engine" to "ReportEngine" already, but didn't
help :(
The error trace:
Feb 14, 2006 8:45:44 AM org.eclipse.birt.core.util.BirtTimer logTimeTaken
INFO: Engine startup takes 228 Milliseconds.
engine.getSupportedFormats().length: 0
report name: /home/hbanh/workspace/bkui/birt/journal.rptdesign
Feb 14, 2006 8:45:45 AM
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask
createContentEmitter
SEVERE: Error.OutputFormatNotSupported
org.eclipse.birt.report.engine.api.EngineException: The output format
html is not supported.
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.cre ateContentEmitter(RunAndRenderTask.java:97)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:174)
at com.jinnova.accounting.ui.RunReportAction.run(RunReportActio n.java:128)
at com.jinnova.accounting.ui.RunReportAction.run(RunReportActio n.java:43)
com.jinnova.accounting.ui.EmptyPerspective.createInitialLayo ut(EmptyPerspective.java:23)
org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Pers pective.java:696)
org.eclipse.ui.internal.Perspective.createPresentation(Persp ective.java:230)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:127)
org.eclipse.ui.internal.WorkbenchPage.createPerspective(Work benchPage.java:1389)
at org.eclipse.ui.internal.WorkbenchPage.init(WorkbenchPage.jav a:2104)
at org.eclipse.ui.internal.WorkbenchPage.<init>(WorkbenchPage.java:516)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:681)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:701)
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1309)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1261)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:190)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:706)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1073)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1695)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:397)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at com.jinnova.bookinno.ui.Application.run(Application.java:21)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:109)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:379)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask run
SEVERE: An error happened while running the report. Cause:
org.eclipse.birt.report.engine.api.EngineException: Error happened while
running the report
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:186)
Caused by: org.eclipse.birt.report.engine.api.EngineException: The
output format html is not supported.
... 33 more
> Jason
>>Hello Jason,
>>this yet. I have
>>>Jason Weathersby
>>>BIRT PMC
>>>>hi
>>>>openReportDesign
>>>>home
>>>>rani
Re: What is EngineHome for Birt 2.0.0 ? [message #129591 is a reply to message #129573] |
Mon, 13 February 2006 23:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Can you attach your code? What OS are you running on?
Also if you can do a listing of the "/home/hbanh/birt-runtime-2_0_0/Report
Engine" directory and attach it.
The only reason I ask this many questions is that this error is caused when
the org.eclipse.birt.report.engine.emitter.html plugin is
not found in the plugins directory. This could be because its not there or
a permission problem is preventing it or (I dont Know) :0
Jason
news:43F136F1.2080308@gmail.com...
> Thank you, Jason.
> help :(
> The error trace:
> org.eclipse.birt.report.engine.api.EngineException: The output format html
> is not supported.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> is not supported.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> running the report
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by: org.eclipse.birt.report.engine.api.EngineException: The output
> at
> at
> ... 33 more
>> Jason
>>>Hello Jason,
>>>this yet. I have
>>>>Jason Weathersby
>>>>BIRT PMC
>>>>>hi
>>>>>openReportDesign
>>>>>home
>>>>>rani
Re: What is EngineHome for Birt 2.0.0 ? [message #129799 is a reply to message #129573] |
Tue, 14 February 2006 05:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I am able to generate report using command line. However, my rcp
application is still failing.
I would step back to my installation. I did install
birt-report-framework-2_0_0.zip and birt-runtime-2_0_0.zip. I downloaded
but not install the birt-rcp-report-designer-2_0_0.zip. I think I don't
need birt-rcp-report-designer-2_0_0.zip yet. Am I right? Please.
Huy Banh wrote:
> Thank you, Jason.
> help :(
> The error trace:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> running the report
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 33 more
>> Jason
>>> Hello Jason,
>>> of this yet. I have
>>> this list already, but can't see any.
>>>> Jason Weathersby
>>>> BIRT PMC
>>>>> hi
>>>>> openReportDesign
>>>>> Engine home
>>>>> rani
Re: What is EngineHome for Birt 2.0.0 ? [message #129851 is a reply to message #129799] |
Tue, 14 February 2006 07:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: buday.metrikus.com
The Engine Home For BIRT 2.0.0 is only plugins which is present in
birt-runtime-2_0_0\Report Engine (Download this from birt home page)
Also u need to copy all jar files which are present in
Engine\ .... in your lib directory
Thank you
FUDForum. Page generated in 0.03771 seconds
