Master Page Footer & Data row ?? [message #118510] |
Fri, 27 January 2006 11:02 |
Originally posted by: xxx.xxx.com
Hi all,
When i use row["xxxxxx"] in Footer with ObjectDataSource, i can't get the
value of my data. Footer is generat before the main so how can i get and
work with my values in Header or Footer ?
Regards.
Denis.
Re: Master Page Footer & Data row ?? [message #118515 is a reply to message #118510] |
Fri, 27 January 2006 11:09 |
Originally posted by: jan.tanis.coas.com
Hi Denis,
What do you want to achieve in your footer. Sum? Then you should use
something like Total.sum(row["row_to_use"]);
Regards, Jan.
Denis wrote:
> Hi all,
> the value of my data. Footer is generat before the main so how can i get
> and work with my values in Header or Footer ?
> Regards.
> Denis.
Re: Master Page Footer & Data row ?? [message #118531 is a reply to message #118515] |
Fri, 27 January 2006 11:53 |
Hi jan,
i have an object (from DataSourceObject & open/fetch method) and i write
some properties in the body (table with link and row["xxxx"]). After, i
want write another attributes of my object in the footer, actually i
can't. I have link my text expression but i've no result. any idea ? (if i
copy my footer's text expression to body, it's ok i've result, but i want
it in footer :D)
Regards.
Denis.
Re: Master Page Footer & Data row ?? [message #118626 is a reply to message #118531] |
Fri, 27 January 2006 12:15 |
Hi Denis,
You can only refer to row[] in your table body. I suggest that if you
want some data in your footer you should use JavaScript.
Regards, Jan.
Denis wrote:
> Hi jan,
> i copy my footer's text expression to body, it's ok i've result, but i
> want it in footer :D)
> Regards.
> Denis.
Re: Master Page Footer & Data row ?? [message #118668 is a reply to message #118644] |
Fri, 27 January 2006 13:47 |
You should do something like this in your DATA object
if(you_want_to_store_this_record_for_some_reason) {
value_to_store = row["record_you_want_to_store"];
I hope this will get you going, if have no examples to show you, sorry.
Best regards, Jan.
Denis wrote:
> Thanks Jan. Have you got some samples ?
> Regards.
> Denis.
Re: Master Page Footer & Data row ?? [message #118835 is a reply to message #118668] |
Fri, 27 January 2006 16:04 |
Sincerely, i don't find solution to get data in my page footer :(
If i have an object, how can i get value in footer ?
I declare variable, and i set it, and how can i get it in footer with
javascript ? ...
Re: Master Page Footer & Data row ?? [message #119503 is a reply to message #118835] |
Mon, 30 January 2006 06:03 |
Hi Denis,
Place a Data field in it and then you can reference your JavaScript
value from it.
Regards, Jan.
> javascript ? ...
FUDForum. Page generated in 0.03705 seconds
