Drag & Drop [message #118498] |
Thu, 19 February 2004 22:57 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: sandip.us.ibm.com
I am trying to customize dnd operations on the graphical viewer for the GEF
logic example
so that an item from the pallette can be only dropped into certain but not
all region of the
GraphicalViewer. To do this, I override the following methods in the
LogicTemplateTransferDropTargetListener class (the idea is I will check for
validity of a
drop inside these methods):
public void
dragEnter(DropTargetEvent event)
System.err.println("dragEnter called");
super.dragEnter(event);
protected void handleDragOver()
System.err.println("handleDragOver called");
super.handleDragOver();
protected void
handleHover()
System.err.println("handleHover called");
super.handleHover();
However, none of these methods are called when I select an item from the
pallet and move the cursor
over the GraphicalViewer area. Am I missing something here?
Thanks.
- Sandip
Re: Drag & Drop [message #118771 is a reply to message #118498] |
Fri, 20 February 2004 23:37 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
OK, here's what's happening: when I select a pallette item and hold down the
left mouse button, then the callbacks are getting called when I move the
mouse over the graphical editor. However, if simply select a pallette item
and then move the mouse *without* holding its left button down over the
graphical editor the callbacks are *not* getting called. However, the cursor
is changing to DND OK shape in both the cases.
- Sandip
"Sandip Lahiri" <sandip@us.ibm.com> wrote in message
news:c13eud$4in$1@eclipse.org...
GEF
> logic example
> all region of the
for
> validity of a
> public void
> protected void
> handleHover()
> Thanks.
> - Sandip
Re: Drag & Drop [message #119056 is a reply to message #118771] |
Mon, 23 February 2004 16:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
DND is only used if you hold down the mouse. Hence the name. What you are
seeing is the creation tool's cursor, which looks similar. It allows
creation, but the mechanism/callbacks are standard mouse events, not DND.
news:c165ka$7td$1@eclipse.org...
the
cursor
> - Sandip
> GEF
> > logic example
not
> > all region of the
> for
> > validity of a
> > public void
> > protected void
> > handleHover()
> > Thanks.
> > - Sandip
Re: Drag & Drop [message #119095 is a reply to message #119056] |
Mon, 23 February 2004 17:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Randy, mucho thanks!!!
- Sandip
"Randy Hudson" <none@us.ibm.com> wrote in message
news:c1daf2$dk4$1@eclipse.org...
are
> the
item
> cursor
> > - Sandip
the
> > GEF
> > > logic example
> not
> > > all region of the
check
> > for
> > > validity of a
> > > public void
> > > protected void
> > > handleHover()
the
> > > Thanks.
> > > - Sandip
FUDForum. Page generated in 0.03617 seconds
