proxy recorder _not_ listening to port1080 [message #118489] |
Tue, 20 November 2007 11:46 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: pascoualito.google_mail.com
In Eclipse when I run a 'Test From Recording', everything seem working
well. I've the message 'proxy recorder listening to port1080' in eclipse
log but the port 1080 is in fact not open. My iptables has no rules so I
don't see where I'm wrong.
Someone has an idea about what can cause this ?
Version of
TPTP SDK : 4.4.0.3 working on Ubuntu 7.10
AC : 4.4.1.0 working on Debien 4.0
Best Regards.
Pascal.
Re: proxy recorder _not_ listening to port1080 [message #118535 is a reply to message #118504] |
Wed, 21 November 2007 11:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I've just tested with tptp.runtime-TPTP-4.5.0M3 and got the same result.
Eclipse lunch the browser but don't want to create the proxy HTTP for
recording all actions. If someone has an idea.
Best Regards.
Pascal.
Re: proxy recorder _not_ listening to port1080 [message #118540 is a reply to message #118529] |
Wed, 21 November 2007 13:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Paul,
I was thinking that the proxy was created by Eclipse but in fact it's open
by the Agent Controller (on another computer) when the recording phase
begin.
So I found the 1080 socks port but now a new problem is here. Mozilla find
the proxy but when I try to load a page, nothing append, it's loading the
page indefinitely.
I will try some other version of AC and keep you informed.
Here the log you asked me even if this is a other problem now:
Recording Started
Connecting to Agent controller on host '172.24.179.166' and port '10002'
Deploying required recorder files.
Sending commandInit
Sending commandStartRecording
Sending commandStartApp Mozilla
------------- Paused until I close Mozilla ------------------------
-- I have configured Mozilla with proxy 172.24.179.166 port 1080 --
-- but when I try to get access to a page, it's loading -----------
-- the page indefinitely ------------------------------------------
Recording completed
Test generation started with generator:TPTP URL Generator
Test to be generated:/PerfsCAS/test_login.testsuite
Test generation completed.
Here Eclipse logs :
!ENTRY org.eclipse.hyades.test.core 1 1 2007-11-21 12:43:06.220
!MESSAGE about to load recorder agent:
org.eclipse.hyades.execution.recorder.http.remote.SSLProxyRe corder
!ENTRY org.eclipse.hyades.test.core 1 1 2007-11-21 12:43:06.632
!MESSAGE load successful
!MESSAGE about to initialize recorder agent:
!MESSAGE initialization successful
!ENTRY org.eclipse.hyades.test.core 1 1 2007-11-21 12:43:06.983
!MESSAGE about to start SSLProxyServer
!ENTRY org.eclipse.hyades.test.core 1 1 2007-11-21 12:43:06.987
!MESSAGE proxy recorder listening to port1080
Thanks.
Best Resgard.
Pascal.
Re: proxy recorder _not_ listening to port1080 [message #118556 is a reply to message #118545] |
Thu, 22 November 2007 17:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Paul,
Under Windows 2000:
I've try under windows (AC 4.4.0.0 & SDK 4.4.0.3) and all recording phase
goes right. So the problem is just under linux.
Under linux:
I've done my tests with AC and runtime Eclipse on the same computer. I
have the same behavior with these AC versions :
4.4.0.0
4.4.1-200711150100
4.5M3
Browser tested (with proxy localhost 1080):
Firefox 2.0.0.8
Galeon 2.0.2
Eclipse is well connected on port 10002 and browser is well connected to
port 1080 :
#netstat -an | grep 10
tcp 0 0 0.0.0.0:10002 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:10006 0.0.0.0:* LISTEN
tcp 0 0 127.0.1.1:10002 127.0.1.1:45455
ESTABLISHED
tcp 0 0 127.0.0.1:34839 127.0.0.1:1080
ESTABLISHED
tcp6 0 0 :::10005 :::* LISTEN
tcp6 0 0 :::1080 :::* LISTEN
tcp6 0 0 ::ffff:127.0.0.1:1080 ::ffff:127.0.0.1:34839
ESTABLISHED
tcp6 0 0 ::ffff:127.0.1.1:58747 ::ffff:127.0.1.1:10005
TIME_WAIT
tcp6 0 0 ::ffff:127.0.1.1:45455 ::ffff:127.0.1.1:10002
ESTABLISHED
I will put a tarball with the AC 4.4.0.0 log (mode DEBUG) on rapidshare or
equivalent tonight, can't put it at work.
Best Regards.
Pascal.
Re: proxy recorder _not_ listening to port1080 [message #118937 is a reply to message #118535] |
Mon, 03 December 2007 20:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
DuWayne Morris![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=dmorris%40us.ibm.com) Messages: 36 Registered: July 2009 |
Member |
In your initial message, you indicated the following:
Version of
Note that the recorder is designed to do the recording on the local host,
although it deploys to either an AC or the IAC on the local machine. So,
I am confused as to how the AC is being used as you listed on another
machine, or at least a different OS.
The browser needs to be configured, either automatically or manually on
the host machine to point to the proxy recorder. So, while recording,
verify that the the browser is be set to use a SOCKS proxy at 127.0.0.1
(local host) on default port 1080.
Please note that these platforms (Ubuntu and Debien) are not supported or
tested, although that is not necessarily the root of the problem you are
having.
From your notes, it looks like you were able to proceed on Windows.
I will look at the details further after you confirm how you are
attempting to record on Linux and verify that the browser is set properly,
to alleviate my confusion. Also, please try to record to some common
public site like eclipse or google. Be aware that there are some issues
recording traffic on the localhost. If that is the case, then set your
browser to the machine IP address http://x.x.x.x/whatever.html rather than
to 127.0.0.1 or localhost.
DuWayne
Re: proxy recorder _not_ listening to port1080 [message #118976 is a reply to message #118950] |
Tue, 04 December 2007 08:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
In my last tests I've put AC & IAC (eclipse) on the same machine. As you
can see in my message from 22/11/2007 the browser is well configured and
connected to SOCKS proxy localhost 1080 but the recorder record nothing.
I've try recording some sites, not only localhost.
Pascal
FUDForum. Page generated in 0.04651 seconds
