Home » Eclipse Projects » Remote Application Platform (RAP) » the supposed uploaded file doesn't exist on disk after successful upload process
the supposed uploaded file doesn't exist on disk after successful upload process [message #118456] Wed, 14 January 2009 11:16 Go to next message
Hi everyone!
I've downloaded the file upload widget's last update.
Everything compile un run fine except that for:
private class FileUploadAdapter extends UploadAdapter {
public void uploadFinished(final UploadEvent event) {
if (event.isFinished()) {
UploadDialog.this.uploadedFile = new
File(UploadDialog.this.upload.getLastFileUploaded());
UploadDialog.this.filePath = UploadDialog.this.uploadedFile.getName();
UploadDialog.this.uploadInfo = "File sucessfully uploaded!\r\n" +
"Absolute Path: " + UploadDialog.this.uploadedFile.getAbsoluteFile() +
"\r\n" +
"Name: " + UploadDialog.this.filePath + "\r\n" +
"Total File size: " + event.getUploadedTotal() + "\r\n" +
"Parcial size: " + event.getUploadedParcial() + "\r\n" +
(UploadDialog.this.uploadedFile.exists() ? "File exist on disk" :
"Sorry, the file doesn't exist at " +
UploadDialog.this.uploadedFile.getAbsoluteFile()) + "\r\n";
} else {
UploadDialog.this.uploadInfo = "File couldn't be uploaded yet";
UploadDialog.this.performFinish();
this UploadDialog logs on my console:
14 janv. 2009 17:12:13 xxx.yyy.zzz.ui.util.dialog.UploadDialog
performFinish
INFO: File sucessfully uploaded!
Absolute Path: C:\Program Files\eclipse\aFileThatDoesNotExist.zip
Total File size: 41973071
Parcial size: 36315704
Sorry, the file doesn't exist at C:\Program
What's the problem? and the ...solution if exist! ;)
I'm running my application in eclipse hosted mode.
Thank U!
Re: the supposed uploaded file doesn't exist on disk after successful upload process [message #118461 is a reply to message #118456] Thu, 15 January 2009 03:07 Go to previous messageGo to next message
the uploaded file isn't necessarily stored on the disk but also could be
stored in memory only (this is handled by Apache commons fileupload). To
access the file you can use
Upload#getUploadItem()#getFileInputStream().
Hope that helps,
Stefan.
New Yop Javeloper schrieb:
> Hi everyone!
> @Override
> uploaded!\r\n" +
> "Absolute Path: " +
> UploadDialog.this.uploadedFile.getAbsoluteFile() + "\r\n" +
> disk" : "Sorry, the file doesn't exist at " +
> } else {
> performFinish
> Thank U!
Re: the supposed uploaded file doesn't exist on disk after successful upload process [message #118496 is a reply to message #118461] Thu, 15 January 2009 07:46 Go to previous message
Hi!
Right!
It works fine!
Here is the code:
final InputStream inputStream =
UploadDialog.this.upload.getUploadItem().getFileInputStream( );
final File temp = new File(System.getProperty("java.io.tmpdir") +
RWT.getSessionStore().getId() + new Random().nextLong());
temp.deleteOnExit();
FileOutputStream outputStream = null;
try {
outputStream = new FileOutputStream(temp);
} catch (final FileNotFoundException e) {
final byte[] buffer = new byte[1024];
int length;
try {
while ((length = inputStream.read(buffer)) > 0) {
outputStream.write(buffer, 0, length);
} catch (final IOException e) {
try {
inputStream.close();
outputStream.close();
UploadDialog.this.uploadedFile = temp;
} else {
Thank You All! ;)
Previous Topic:RAP integration into WebSphere Portal
Next Topic:New RWT graphic widget GCCanvas
Current Time: Sat Sep 13 23:45:34 EDT 2025
Powered by FUDForum. Page generated in 0.08697 seconds
