Re: save resize figure [message #118440] |
Thu, 19 February 2004 14:50 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: yong.dong.sympatico.ca
Me too, since the new attribute size is not saved to the xml file. According
to the same reason,
other new shapes can not be saved in xml either. Now I try to serialize the
model object
to the disk and save it to the DB, then XML.
Michael
Hi Micheal,
I am still fighting with resizing. I am able to resize
and I can see the
resized image on the screen. When I close the editor,
it does not get saved
and shows up with the default size. Did you modify
NetworkPackageImpl.java's
CreatePackageContents() or InitializePackageContents()
methods? I included
the getNetworkNode().setSize() method in
NetworkNodeEditPart.java but it
does not help. It has to do with some minor change in
the model
(NodeImpl.java or NetworkImpl.java) that I am missing.
Let me know & Thanks in advance!
Bharath
Re: save resize figure [message #118450 is a reply to message #118440] |
Thu, 19 February 2004 15:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: bharath.starthis.com
Michael,
The "size" attribute is modeled as an EClass ONLY because it makes it
serializable! I must be missing out an extra method or so required to
enable its serialization and I am trying to find it. I will let you know
as soon as I get it working.
Thanks.
> to the same reason,
> model object
> Michael
> Hi Micheal,
> and I can see the
> methods? I included
> the model
> Bharath
Re: save resize figure [message #214404 is a reply to message #118450] |
Mon, 17 April 2006 16:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: micha.m2visio.de
Hello Guys
have you found a solution for this problem?
I'm working at the same issue at the moment and just can't get it.
Michael
"Bharath" <bharath@starthis.com> schrieb im Newsbeitrag
news:c12lqg$4f8$1@eclipse.org...
> Michael,
> Thanks.
>> According
>> to the same reason,
>> the
>> model object
>> Michael
>> Hi Micheal,
>> and I can see the
>> methods? I included
>> the model
>> Bharath
FUDForum. Page generated in 0.03041 seconds
