Home » Modeling » GMF (Graphical Modeling Framework) » Figure around other (externally) , borders, layout ..
Figure around other (externally) , borders, layout .. [message #901] Sun, 30 July 2006 03:51 Go to next message
Hi all!
I'm trying to get something like that :
child _____________ child
[]-----| container |---[]
| | other
other | |---[]
[]-----|_____________|
I can easily get:
_____________
| container |
|child |
| [] child |
|________[]___|
I thought about using a biggest and invisible container rectangle but I
can't manage to sort out the layouts in order to get something good.
Have you got any advice in order to do that, or may be a sample project or
documentation to point me to ?
thanks
Re: Figure around other (externally) , borders, layout .. [message #1082 is a reply to message #901] Mon, 31 July 2006 09:52 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Hello!
Is there any constraint how far children may be located from the container?
Cédric Brun wrote:
> Hi all!
> | | other
> other | |---[]
> I can easily get:
> _____________
> | container |
> |child |
> | [] child |
> |________[]___|
> thanks
Re: Figure around other (externally) , borders, layout .. [message #1267 is a reply to message #1082] Tue, 01 August 2006 03:17 Go to previous messageGo to next message
Yes, it should stay not far from the container figure. Let's says in the
best case I would like to be able to fix this length.
Dmitry Stadnik wrote:
> Hello!
> container?
> Cédric Brun wrote:
>> Hi all!
>> | | other
>> other | |---[]
>> I can easily get:
>> _____________
>> | container |
>> |child |
>> | [] child |
>> |________[]___|
>> or documentation to point me to ?
>> thanks
Re: Figure around other (externally) , borders, layout .. [message #1289 is a reply to message #1267] Tue, 01 August 2006 04:38 Go to previous messageGo to next message
Hello!
I could suggest you two approaches:
1. Use diagram structure that differs from domain model structure as
discussed in "Semantical container != Graphical container"; you'll find
yourself hacking through the labyrinths of gmf code soon but in the end
you'll be able to get exactly what you need.
2. Define container figure with transparent border and use diagram
structure you say "I can easily get". Note that you should not use
draw2d Border since children can't be placed over it; possible solution
is to write custom figure that overrides paintFigure() method to paint
smaller rectangle (and optionally containsPoint() /
findDescendantAtExcluding() to make border transparent for mouse clicks).
>> Hello!
>> container?
>> Cédric Brun wrote:
>>> Hi all!
>>> | | other
>>> other | |---[]
>>> I can easily get:
>>> _____________
>>> | container |
>>> |child |
>>> | [] child |
>>> |________[]___|
>>> thanks
Re: Figure around other (externally) , borders, layout .. [message #1327 is a reply to message #1289] Tue, 01 August 2006 07:51 Go to previous message
Thank you for all these information, I'll try that :)
Cédric
> Hello!
>>> Hello!
>>> container?
>>> Cédric Brun wrote:
>>>> Hi all!
>>>> | | other
>>>> other | |---[]
>>>> I can easily get:
>>>> _____________
>>>> | container |
>>>> |child |
>>>> | [] child |
>>>> |________[]___|
>>>> thanks
Previous Topic:problem with synchronizing model change in different diagram
Next Topic:Stability of GMF Tooling models
Current Time: Wed Oct 15 03:31:41 EDT 2025
Powered by FUDForum. Page generated in 0.05967 seconds
