problems to debug in threads [message #117768] |
Fri, 27 August 2004 15:29 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ralf.becker.ids.de
I have a problem to debug in threads.
I use eclipse 3.0, CDT 2.0 and SUSE 9.0.
I create a project with "Managed Make c Project".
For example the poject contains 1 file thread1.c.
I have set pthread in the window libraries(-l).
Window Console C-Build[thread1]
make -k all
Building file: ../thread1.c
gcc -O0 -g3 -Wall -c -fmessage-length=0 -othread1.o ../thread1.c
Finished building: ../thread1.c
Building target: thread1
gcc -othread1 thread1.o -lpthread
Finished building: thread1
Build complete for project thread1
C-Code:
#include <stdio.h>
#include <unistd.h>
#include <stdlib.h>
#include <pthread.h>
void *thread_function(void *arg);
char message[] = "Hello World";
int main() {
int res;
pthread_t a_thread;
void *thread_result;
res = pthread_create(&a_thread, NULL, thread_function, (void
*)message);
if (res != 0) { exit(EXIT_FAILURE); }
res = pthread_join(a_thread, &thread_result);
exit(EXIT_SUCCESS);
void *thread_function(void *arg) {
sleep(3);
printf("\n%s\n", message);
When I set a breakpoint in the line "printf("\n%s\n", message);" it works.
When I start the debugger with a breakpoint in the line "sleep(3);" the
following failure happens:
Window Debug:
<terminated>GDB Debugger (...) (Suspended) <Couldn't get registers. Kein
passender Prozess gefunden>
In my greater project with many threads I have this failure all the time
and I think the failur occurs whereever I set the breakpoint in the thread.
What is the failure ?
Thanks for help
Re: problems to debug in threads [message #118114 is a reply to message #117768] |
Mon, 30 August 2004 14:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: mikhailk.qnx.com
The message you're getting comes from gdb. To find out what is happening try
to get the gdb trace (see CDT debugger FAQ #5).
"Ralf Becker" <ralf.becker@ids.de> wrote in message
news:cgnjvt$7mb$1@eclipse.org...
> make -k all
> C-Code:
> #include <stdio.h>
> #include <unistd.h>
> #include <stdlib.h>
> int main() {
> int res;
> pthread_t a_thread;
> *)message);
> exit(EXIT_SUCCESS);
> sleep(3);
> Window Debug:
thread.
> Thanks for help
FUDForum. Page generated in 0.04176 seconds
