Re: Gef + org.eclipse.ui.ide [message #117658 is a reply to message #117647] |
Mon, 16 February 2004 00:22 |
The intentions are to require only RCP. We should be very close to removing
this dependency.
"James Willans" <jwillans@cs.york.ac.uk> wrote in message
news:c0ocfd$670$1@eclipse.org...
> The integration release of GEF seems to have a dependency on
> org.eclipse.ui.ide which prevents it being used in an RCP context. Why is
> this and are there plans to remove the dependency? If so, how far are we
> away from that point?
> Thanks.
> James
Re: Gef + org.eclipse.ui.ide [message #118068 is a reply to message #117647] |
Tue, 17 February 2004 15:48 |
So, we can remove the eclipse.ui.ide requirement, but we cannot remove
"org.eclipse.ui.views". If we did, we wouldn't be able to provide property
sheet support. We can consider making this plug-in optional.
> Thanks.
> James
Re: Gef + org.eclipse.ui.ide [message #118157 is a reply to message #118126] |
Wed, 18 February 2004 00:28 |
AbstractEditPart#getAdapter(Class c) makes a reference to IPropertySource.
So, we need to make sure this code can function properly in the event that
that class is not found. I suppose we need to dynamically lookup the class
at runtime by name. Are you interested in testing the changes once they are
made?
news:c0u3bj$pqr$1@eclipse.org...
> That sounds great! At what point will this change get into an integration
> release?
> James
property
Why is
we
> > > Thanks.
> > > James
FUDForum. Page generated in 0.03511 seconds
