Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Column name for attribute override
Column name for attribute override [message #116797] Thu, 03 April 2008 20:50 Go to next message
Originally posted by: pavata.vsp.com
This is regarding the column name restriction on inherited field from a
superclass. We have a parent class and subclass hierarchy as Email.xsd and
MyEmail.xsd respectively. A field name emailaddress is inherited from Email
class to MyEmail class and the attribute override column name is
EMAIL_ADDRESS. But teneo overrides the column name as MYEMAIL_ADDRES once it
identifies specified column name starts with parent class name. We don't
understand the need to override the column name when it counters this
situation. The specific class that is performing this is
ClassicMappingContext.class
Can you throw some light on this funtionality? It is forcing us to rename
our class names to some other names which we really don't want to.
- Pavan
Re: Column name for attribute override [message #116820 is a reply to message #116797] Fri, 04 April 2008 02:18 Go to previous messageGo to next message
Hi Pavan,
Can you post a small xsd sample so I can better understand what you try to do?
btw, you can always replace the mapping context class with your own implementation which does what
you want. See the extensions mechanism of Teneo.
gr. Martin
Pavan Tata wrote:
> - Pavan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Column name for attribute override [message #116882 is a reply to message #116820] Fri, 04 April 2008 12:11 Go to previous messageGo to next message
Hi Martin,
I wanted to confirm with you before I have my own implementation of
mappingcontext. Here is what I am doing.
The superclass annotation is
<xsd:complexType name="Email">
<xsd:annotation><xsd:appinfo source="teneo.jpa">@MappedSuperclass
@Embeddable</xsd:appinfo></xsd:annotation>
<xsd:sequence>
<xsd:element default="" nillable="true" name="emailAddress"
type="xsd:string">
<xsd:annotation>
@Column(name=XXX,nullable="false")
</xsd:appinfo>
<xsd:documentation>
Type of e-mail address [we need codes here]
</xsd:documentation>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
and subclass annotation is
<xsd:complexType name="MyEMail">
<xsd:annotation>
@AttributeOverrides({
@AttributeOverride(name="emailAddress", @Transient
column=@Column(name="EMAIL_ADDR", length="50")),
@Table(
name="CMR3607T"
uniqueConstraints = { @UniqueConstraint(columnNames={"EMAIL_SK"})
</xsd:appinfo>
And the column name in the hibernate mapping finally turns out to be
MYEMAIL_ADDR. Can you tell me why it is modifying the name?
- Pavan
"Martin Taal" <mtaal@elver.org> wrote in message
news:ft4h7q$taa$1@build.eclipse.org...
> Hi Pavan,
> do?
> gr. Martin
> Pavan Tata wrote:
>> and MyEmail.xsd respectively. A field name emailaddress is inherited from
>> Email class to MyEmail class and the attribute override column name is
>> it identifies specified column name starts with parent class name. We
>> don't understand the need to override the column name when it counters
>> this situation. The specific class that is performing this is
>> rename our class names to some other names which we really don't want to.
>> - Pavan
> The Netherlands
Re: Column name for attribute override [message #116895 is a reply to message #116882] Fri, 04 April 2008 13:20 Go to previous messageGo to next message
Hi Pavan,
This renaming is required for the case that an ereference is inherited from a mapped superclass, in
this case the join-column of the e-reference will be placed in another table. If one ereference is
inherited by multiple subtypes then this goes wrong because they then all share the same join column
with foreign keys relating it to different tables, and multiple foreign keys on one column can not
point to different directions.
Currently there are two things which are wrong with this behavior:
- the renaming is not required for eattributes (afaics)
- it ignores the attributeoverrides annotation
I will repair this for the next build (within a few days or earlier).
In the meantime to work around this you can create your own MappingContext.
gr. Martin
Pavan Tata wrote:
> Hi Martin,
> <xsd:sequence>
> type="xsd:string">
> <xsd:annotation>
> </xsd:appinfo>
> <xsd:documentation>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> <xsd:annotation>
> @Table(
> name="CMR3607T"
> </xsd:appinfo>
> - Pavan
>> Hi Pavan,
>> do?
>> gr. Martin
>> Pavan Tata wrote:
>>> Hi,
>>> - Pavan
>> The Netherlands
The Netherlands
Re: Column name for attribute override [message #117046 is a reply to message #116882] Sun, 06 April 2008 17:01 Go to previous messageGo to next message
Hi Pavan,
The latest I-build (of today) should solve this issue. Can you check?
gr. Martin
Pavan Tata wrote:
> Hi Martin,
> <xsd:sequence>
> type="xsd:string">
> <xsd:annotation>
> </xsd:appinfo>
> <xsd:documentation>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> <xsd:annotation>
> @Table(
> name="CMR3607T"
> </xsd:appinfo>
> - Pavan
>> Hi Pavan,
>> do?
>> gr. Martin
>> Pavan Tata wrote:
>>> Hi,
>>> - Pavan
>> The Netherlands
The Netherlands
Re: Column name for attribute override [message #117141 is a reply to message #117046] Mon, 07 April 2008 14:52 Go to previous message
Martin,
Yep, that fixed it. I really appreciate the fact that you are so quick in
applying these solutions....such a pleasure working you.
- Pavan
news:ftbdo2$ne1$1@build.eclipse.org...
> Hi Pavan,
> gr. Martin
> Pavan Tata wrote:
>> Hi Martin,
>> <xsd:sequence>
>> type="xsd:string">
>> <xsd:annotation>
>> </xsd:appinfo>
>> <xsd:documentation>
>> </xsd:annotation>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:schema>
>> <xsd:annotation>
>> @Table(
>> name="CMR3607T"
>> </xsd:appinfo>
>> - Pavan
>>> Hi Pavan,
>>> to do?
>>> gr. Martin
>>> Pavan Tata wrote:
>>>> Hi,
>>>> a superclass. We have a parent class and subclass hierarchy as
>>>> Email.xsd and MyEmail.xsd respectively. A field name emailaddress is
>>>> inherited from Email class to MyEmail class and the attribute override
>>>> column name is EMAIL_ADDRESS. But teneo overrides the column name as
>>>> MYEMAIL_ADDRES once it identifies specified column name starts with
>>>> parent class name. We don't understand the need to override the column
>>>> name when it counters this situation. The specific class that is
>>>> performing this is ClassicMappingContext.class
>>>> to.
>>>> - Pavan
>>> The Netherlands
> The Netherlands
Re: Column name for attribute override [message #616071 is a reply to message #116797] Fri, 04 April 2008 02:18 Go to previous message
Hi Pavan,
gr. Martin
Pavan Tata wrote:
> - Pavan
The Netherlands
Re: Column name for attribute override [message #616076 is a reply to message #116820] Fri, 04 April 2008 12:11 Go to previous message
Hi Martin,
<xsd:sequence>
type="xsd:string">
<xsd:annotation>
</xsd:appinfo>
<xsd:documentation>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
<xsd:annotation>
@Table(
name="CMR3607T"
</xsd:appinfo>
- Pavan
> Hi Pavan,
> do?
> gr. Martin
> Pavan Tata wrote:
>> - Pavan
> The Netherlands
Re: Column name for attribute override [message #616077 is a reply to message #116882] Fri, 04 April 2008 13:20 Go to previous message
Hi Pavan,
gr. Martin
Pavan Tata wrote:
> Hi Martin,
> <xsd:sequence>
> type="xsd:string">
> <xsd:annotation>
> </xsd:appinfo>
> <xsd:documentation>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> <xsd:annotation>
> @Table(
> name="CMR3607T"
> </xsd:appinfo>
> - Pavan
>> Hi Pavan,
>> do?
>> gr. Martin
>> Pavan Tata wrote:
>>> Hi,
>>> - Pavan
>> The Netherlands
The Netherlands
Re: Column name for attribute override [message #616089 is a reply to message #116882] Sun, 06 April 2008 17:01 Go to previous message
Hi Pavan,
gr. Martin
Pavan Tata wrote:
> Hi Martin,
> <xsd:sequence>
> type="xsd:string">
> <xsd:annotation>
> </xsd:appinfo>
> <xsd:documentation>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> <xsd:annotation>
> @Table(
> name="CMR3607T"
> </xsd:appinfo>
> - Pavan
>> Hi Pavan,
>> do?
>> gr. Martin
>> Pavan Tata wrote:
>>> Hi,
>>> - Pavan
>> The Netherlands
The Netherlands
Re: Column name for attribute override [message #616096 is a reply to message #117046] Mon, 07 April 2008 14:52 Go to previous message
Martin,
- Pavan
> Hi Pavan,
> gr. Martin
> Pavan Tata wrote:
>> Hi Martin,
>> <xsd:sequence>
>> type="xsd:string">
>> <xsd:annotation>
>> </xsd:appinfo>
>> <xsd:documentation>
>> </xsd:annotation>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:schema>
>> <xsd:annotation>
>> @Table(
>> name="CMR3607T"
>> </xsd:appinfo>
>> - Pavan
>>> Hi Pavan,
>>> to do?
>>> gr. Martin
>>> Pavan Tata wrote:
>>>> Hi,
>>>> to.
>>>> - Pavan
>>> The Netherlands
> The Netherlands
Previous Topic:[CDO] Starting server code
Next Topic:[Announce] Texo project proposal: EMF technology for web application development environments
Current Time: Fri Apr 25 21:21:06 EDT 2025
Powered by FUDForum. Page generated in 0.03387 seconds
