| Home » Eclipse Projects » Equinox » Additional plugin model considerations
 Goto Forum:|
| Additional plugin model considerations [message #10638] | Sat, 08 March 2003 19:32  |  |
| Eclipse User  |  |  |  |  | Originally posted by: joerg.schaible.web.de
 apart from the current discussion about the update and dependecies between
 plugins,
 there are some other topics, that have to be considered in the plugin model.
 1) Clear model to separate between default settings, project dependent
 settings and
 local settings.
 Currently it is not really possible to share a project's settings with the
 CVS (...), because
 a lot of the settings are in the workspace and will not be shared among the
 developers (e.g.
 the compiler warnigns, code formatting, etc.). But the workspace will also
 include rwo other
 kind of settings: Individual ones like key bindings and default settings.
 So, if you have to ensure that a team works with the same settings for a
 project, it is
 currently a major process: Adjust the default settings like code formatter,
 ensure that
 everyone use the project individual settings (at least for the settings,
 that provide this option).
 When a project setting should be shared, the a plugin should be capable of
 saving all its
 non-individual default settings into a project settings file kept with the
 project. Settings of
 individual choice should not be considered for saving there (e.g. font or
 colors). Basically
 every team member should be able to build the project with the same settings
 getting the
 exaclty same result as everyone else.
 2) The support for external contexts/environment.
 Problem: When I start Eclipse with my notebook offline, some of my plugins
 come really into
 trouble, because of the missing external net ressource causing several
 errors in Eclipse.
 Basically they should be informed by a context provided from the core at
 initialization, what
 ressources are currently available. They should be deactivating or sleeping,
 if they cannot run,
 but without having Eclipse deleting all the according views. Such contexts
 might be provided
 by the core itself (e.g. am I (Eclipse) running in debug mode, do I have net
 access, is a printer
 available, is a DB available a special plugin in needs, ...) or by user
 defined XML profiles
 with this resources provided at startup, so I can have two startup scripts
 for Eclipse that I use
 in the different environment.
 J
| Re: Additional plugin model considerations [message #10708 is a reply to message #10638] | Sat, 08 March 2003 22:37   |  |
| Eclipse User  |  |  |  |  | Originally posted by: jeff_mcaffer_REMOVE.ca.ibm.com
 "Joerg R. Schaible" <joerg.schaible@web.de> wrote in message
 news:b4e2vh$is6$1@rogue.oti.com...
 > settings and local settings.
 I have seen several bug reports relating to this in the past while.  It is a
 great idea but a deceptively hard problem.  My hope is that it will be
 addressed in scope of the Eclipse platform project rather than in Equinox.
 > come really into
 > errors in Eclipse.
 sleeping,
 > if they cannot run,
 > might be provided
 net
 Can you be more specific as to what plugins are failing/views disappearing?
 I am assuming that all your plugins are local and some of those have not
 gone missing?
 The profile idea is intriguing.  It is a way of the user telling the plugins
 not to expect certain things and that it is ok.  Individual plugin writers
 will still have to know about the profile values and handle the various
 settings.  Alternatively, plugin could be more resilient to cases where some
 resource was there and now it is not.  This is especially true of networked
 resources.  For example, if the network goes down for a while, a database
 plugin should not start failing.
 Jeff
| Re: Additional plugin model considerations [message #10802 is a reply to message #10708] | Sun, 09 March 2003 09:30   |  |
 Hi Jeff,
 "Jeff McAffer" <jeff_mcaffer_REMOVE@ca.ibm.com> schrieb im Newsbeitrag
 news:b4ed4j$mur$1@rogue.oti.com...
 > > Hi,
 a
 Well, but configurations and settings are also inherited by the dependency
 between the plugins. Even more - a plugin can offer a replacement for core
 settings (e.g. Jalopy rules as general code formatter, any assistent would
 use
 this plugin to reformat generated code before pasting it to the editor).
 Possibly this leeds away from the pure configuration level to a
 service-oriented
 view: A plugin just says, well give me the Java-code-formatter or give me
 the XML parser or give me the configured browser. There are definatly such
 mechanisms in Eclipse, but I am not sure about the generality.
 Think of installing Debian - you can define a dependency on a general mail
 processing component without explicitly defining "I need sendmail". See the
 mess
 such a missing concept leeds looking at the browsers. Everyone claims to be
 another
 in their HTTP header, instead of just saying - well, I am DOM compliant or
 CSS1
 or CSS2 aware.
 Regarding the persistance of the configuration each plugin has to separate
 between
 its current settings on project or individual level and should be able to
 answer
 a request for them.
 [snip]
 disappearing?
 > gone missing?
 I had bad experiences with the p4eclipse 0.0.8. If you're offline, you
 cannot
 edit a single file even if they are checked out. While this is not the fault
 of Eclipse
 at general, I am quite sure, that the plugin developer might have been more
 carefull if the API would have told him "hey - currently no network".
 plugins
 > settings.
 Sure, but they need a chance. And even if every net-aware plugin would take
 care
 on its own for available network services ... normally everything is on halt
 until the
 network timeout occurs.
 networked
 Yes, that would be extremly helpful. In case of p4eclipse you cannot even
 save
 your edited file if it happens.
 J
| Re: Additional plugin model considerations [message #12063 is a reply to message #10802] | Mon, 10 March 2003 09:35  |  |
| Eclipse User  |  |  |  |  | Originally posted by: ogruber.us.ibm.com
 Behing that idea of profiles... showing what is there or not...
 isn't it where a dynamic service-oriented framework would help.
 I know Java is poorly structured in that regard, but if those things
 were modelled as service, and that service users would be
 dynamically notified of services appearing and disappearing,
 it would "strongly suggests" plugin writers to handle the case.
 I believe that is one of the most valuable aspects of service
 frameworks, like OSGi. However, it does mean that the
 programming model for plug-ins is altered. It also means that
 some JRE functionality, like java.net or jdbc, would have to be
 surfaced as services rather than their current library-like API.
 Olivier Gruber, Ph.D.
 Persistent & Distributed Object Platforms and Frameworks
 IBM TJ Watson Research Center
 news:b4fjcf$e2p$1@rogue.oti.com...
 > Hi Jeff,
 > > > Hi,
 is
 > a
 Equinox.
 > use
 > service-oriented
 the
 > mess
 be
 > another
 > CSS1
 > or CSS2 aware.
 > between
 > answer
 > a request for them.
 > [snip]
 > disappearing?
 > > gone missing?
 > cannot
 fault
 > of Eclipse
 more
 > plugins
 writers
 > > settings.
 take
 > care
 halt
 > until the
 > networked
 database
 > save
 > J
 Current Time: Fri Oct 31 08:16:09 EDT 2025
 Powered by FUDForum . Page generated in 0.03345 seconds |
