| CVS Add Directory Problem [message #116699] | Thu, 13 November 2003 16:43  |  |
| Eclipse User  |  |  |  |  | Originally posted by: groberts.seabase.com
 Hi All,
 I am having a problem with either the CVS plugin or with CVS itself.
 Here's the setup:
 I have two users UA and UB.
 I have two repositories RA and RB.
 The users have the same version of eclipse and the same os.
 The repositories are on two different machines. Both machines have the
 same version of Linux, have the same version of CVS, have the same project
 imported. File and permissions are also the same.
 Here's the problem:
 If UA adds a directory and a file within it to RA, then UB runs
 Team/Synchronize against RA everything works. That is, Team>Synchronize
 shows that the directory and file have been added. UB can then run an
 update and life is good.
 Do the same thing with RB.  That is, UA adds and UB synchs and
 Team>Synchronize shows the message that the workspace and the repository
 are in synch.  They of course are not in synch. Running update -d from the
 command line will bring them into synch.
 I'll summarize:
 With RA, UA adds, UB synchs, and Team>Synchronize shows a difference.
 With RB, UA adds, UB synchs, and Team>Synchronize shows NO difference.
 Can anyone account for this difference in behavior between RA and RB?
 It is as if eclipse is setting the update -d flag is when using RA but not
 setting it when using RB.
| Re: CVS Add Directory Problem [message #117032 is a reply to message #116699] | Fri, 14 November 2003 14:02   |  |
| Eclipse User  |  |  |  |  | Can you provide more versions info about CVS/Eclipse platform?
 Geoffry Roberts wrote:
 > Hi All,
 > Here's the setup:
 > Here's the problem:
 > I'll summarize:
 > Thanks
| Re: CVS Add Directory Problem [message #117107 is a reply to message #117032] | Fri, 14 November 2003 17:08  |  |
 Versions are
 Linux:   2.4.7-10 (kernel)
 CVS:     1.11.1p1
 eclipse: 2.12
 Another bit of information that may matter is that RA has entries in
 CVSROOT/modules and RB does not.
 Thanks for responding.
 > > Hi All,
 > > Here's the setup:
 > > Here's the problem:
 > > I'll summarize:
 > > Thanks
FUDForum. Page generated in 0.03933 seconds
