Home » Eclipse Projects » Eclipse Platform » which plugins implement File Search?
which plugins implement File Search? [message #116631] Tue, 26 August 2003 12:55 Go to next message
Originally posted by: xing.cs.ualberta.ca
hi,
i'd like to search a piece of text within a bunch of .java file. do you
know which plugins can do that?
thanks
Re: which plugins implement File Search? [message #116720 is a reply to message #116631] Tue, 26 August 2003 14:15 Go to previous messageGo to next message
You can start looking here. I created an text file, hit ctrf-f and clicked
on "find".
Here is a partial method trace:
org.eclipse.ui.texteditor.FindReplaceDialog.findNext(java.la ng.String,boolea
n,boolean,boolean,boolean,boolean,boolean) {
org.eclipse.ui.texteditor.FindReplaceTarget.getSelection() {
org.eclipse.ui.texteditor.FindReplaceTarget.getTarget() {
org.eclipse.ui.texteditor.FindReplaceDialog.findIndex(java.l ang.String,int,b
org.eclipse.ui.texteditor.FindReplaceTarget.findAndSelect(in t,java.lang.Stri
ng,boolean,boolean,boolean) {
Chris
"zhenchang xing" <xing@cs.ualberta.ca> wrote in message
news:big3dc$gt9$1@eclipse.org...
> hi,
> thanks
Re: which plugins implement File Search? [message #118622 is a reply to message #116720] Thu, 28 August 2003 08:39 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
The trace shows Find/Replace which searches for text in 1 file. File
search is a different function and is contributed by org.eclipse.search
plug-in.
HTH
Dani
>on "find".
>Chris
>>hi,
>>thanks
Re: which plugins implement File Search? [message #118995 is a reply to message #118622] Thu, 28 August 2003 15:14 Go to previous message
right. I missed that in the question. A trace for File Search is attached.
Chris
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:bikt64$2jb$1@eclipse.org...
> plug-in.
> HTH
> Dani
clicked
> >on "find".
a
b
i
> >Chris
> >>hi,
> >>thanks
Previous Topic:File diff in eclipse...
Next Topic:accessing the message area?
Current Time: Sat Oct 25 02:44:15 EDT 2025
Powered by FUDForum. Page generated in 0.05988 seconds
