ve doesn't display gui [message #116603] |
Thu, 02 February 2006 00:24 |
Originally posted by: geezmo06.gmx.at
hi
i run eclipse under linux gtk and when i try to create a new visual class
following errors appear:
i hope there's somebody that can help me.
greets, geezmo
export of my Error Log:
!ENTRY org.eclipse.ve.java.core 2 0 2006-02-02 01:11:18.603
!MESSAGE +++ Warning +++: Thu Feb 02 01:11:18 CET 2006 Skipping
expression: jContentPane.setLayout(new BorderLayout())
!ENTRY org.eclipse.ve.java.core 4 0 2006-02-02 01:11:18.628
!MESSAGE Invalid PropertyDecorator
!ENTRY org.eclipse.jem.proxy 2 0 2006-02-02 01:11:18.677
!MESSAGE !STACK 0
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
java.awt.AWTError: Cannot load AWT toolkit:
gnu.java.awt.peer.gtk.GtkToolkit
at java.awt.Toolkit.getDefaultToolkit() (/usr/lib/libgcj.so.6.0.0)
at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment()
org.eclipse.ve.internal.jfc.vm.FreeFormAWTDialog.getScreenLo cation(boolean)
(Unknown Source)
at java.lang.reflect.Method.invoke(java.lang.Object,
java.lang.Object[]) (/usr/lib/libgcj.so.6.0.0)
at org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un()
(Unknown Source)
at org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n()
(Unknown Source)
at .GC_start_routine (/usr/lib/libgcj.so.6.0.0)
at .__clone (/lib/tls/i686/cmov/libc-2.3.5.so)
Caused by: java.lang.ClassNotFoundException:
gnu.java.awt.peer.gtk.GtkToolkit not found in
gnu.gcj.runtime.SystemClassLoader{urls=[file:/home/geezmo/bi n/eclipse/configuration/org.eclipse.osgi/bundles/150/1/.cp/v m/remotevm.jar,file:./,file:/home/geezmo/workspace/GH/,file: /home/geezmo/bin/eclipse/plugins/org.eclipse.jem.proxy_1.2.0 .jar,file:./,file:/home/geezmo/bin/eclipse/configuration/org .eclipse.osgi/bundles/145/1/.cp/vm/jfcbeaninfo.jar,file:/hom e/geezmo/bin/eclipse/plugins/org.eclipse.jem.beaninfo_1.2.0. jar,file:./,file:/home/geezmo/bin/eclipse/configuration/org. eclipse.osgi/bundles/144/1/.cp/vm/beaninfovm.jar,file:/home/ geezmo/bin/eclipse/configuration/org.eclipse.osgi/bundles/14 7/1/.cp/vm/javaremotevm.jar,file:./,file:/home/geezmo/bin/ec lipse/configuration/org.eclipse.osgi/bundles/145/1/.cp/vm/jf cvm.jar],
parent=gnu.gcj.runtime.ExtensionClassLoader{urls=[], parent=null}}
at java.net.URLClassLoader.findClass(java.lang.String)
at java.lang.ClassLoader.loadClass(java.lang.String, boolean)
at java.lang.ClassLoader.loadClass(java.lang.String)
at java.lang.Class.forName(java.lang.String, boolean,
java.lang.ClassLoader) (/usr/lib/libgcj.so.6.0.0)
at java.lang.Class.forName(java.lang.String) (/usr/lib/libgcj.so.6.0.0)
...7 more
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:459)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.processErrorReturn(REMStandardBeanProxyFactory.java:51 0)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:221)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeW ithParms(REMMethodProxy.java:178)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:102)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invoke( REMMethodProxy.java:226)
org.eclipse.jem.internal.proxy.remote.REMMethodProxy.invokeC atchThrowableExceptions(REMMethodProxy.java:251)
org.eclipse.ve.internal.jfc.core.BeanAwtUtilities.getOffScre enLocation(BeanAwtUtilities.java:72)
org.eclipse.ve.internal.jfc.core.WindowProxyAdapter.primInst antiateBeanProxy(WindowProxyAdapter.java:91)
org.eclipse.ve.internal.jfc.core.FrameProxyAdapter.primInsta ntiateBeanProxy(FrameProxyAdapter.java:71)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teAndInitialize(BeanProxyAdapter.java:387)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teBeanProxy(BeanProxyAdapter.java:328)
org.eclipse.ve.internal.java.core.MemberContainerProxyAdapte r.initSetting(MemberContainerProxyAdapter.java:547)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.su bInitBeanProxy(CompositionProxyAdapter.java:315)
org.eclipse.ve.internal.java.core.MemberContainerProxyAdapte r.initBeanProxy(MemberContainerProxyAdapter.java:566)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:2082)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
!ENTRY org.eclipse.jem.proxy 4 0 2006-02-02 01:11:19.730
!MESSAGE Exception thrown.
!STACK 0
java.io.EOFException
at java.io.DataInputStream.readByte(DataInputStream.java:243)
org.eclipse.jem.internal.proxy.common.remote.Commands.readBa ckValue(Commands.java:1243)
org.eclipse.jem.internal.proxy.common.remote.ExpressionComma nds.sendSyncCommand(ExpressionCommands.java:261)
org.eclipse.jem.internal.proxy.remote.REMConnection.sync(REM Connection.java:320)
org.eclipse.jem.internal.proxy.remote.REMExpression.pushInvo ke(REMExpression.java:970)
org.eclipse.jem.internal.proxy.core.Expression.invokeExpress ion(Expression.java:685)
org.eclipse.ve.internal.java.core.MemberContainerProxyAdapte r.initBeanProxy(MemberContainerProxyAdapter.java:582)
!ENTRY org.eclipse.ve.java.core 2 0 2006-02-02 01:11:19.731
!STACK 0
java.lang.IllegalStateException: IWAV0173I Command Exception occurred. See
log file for details.
org.eclipse.jem.internal.proxy.remote.REMExpression.throwIll egalStateException(REMExpression.java:193)
org.eclipse.jem.internal.proxy.remote.REMExpression.pushInvo ke(REMExpression.java:1001)
!ENTRY org.eclipse.jem.proxy 2 0 2006-02-02 01:11:19.850
!MESSAGE +++ Warning +++: Thu Feb 02 01:11:19 CET 2006 Project (GH)-VM
for GH:err>
at java.awt.EventQueue.invokeLater(java.lang.Runnable)
at javax.swing.SwingUtilities.invokeLater(java.lang.Runnable)
javax.swing.RepaintManager.addInvalidComponent(javax.swing.J Component)
at javax.swing.JComponent.revalidate() (/usr/lib/libgcj.so.6.0.0)
at javax.swing.JComponent.setOpaque(boolean)
at javax.swing.JPanel.JPanel(java.awt.LayoutManager, boolean)
at javax.swing.JPanel.JPanel() (/usr/lib/libgcj.so.6.0.0)
at javax.swing.JRootPane.createGlassPane()
at javax.swing.JRootPane.getGlassPane() (/usr/lib/libgcj.so.6.0.0)
at javax.swing.JRootPane.JRootPane() (/usr/lib/libgcj.so.6.0.0)
at javax.swing.JFrame.createRootPane() (/usr/lib/libgcj.so.6.0.0)
at javax.swing.JFrame.getRootPane() (/usr/lib/libgcj.so.6.0.0)
at javax.swing.JFrame.frameInit() (/usr/lib/libgcj.so.6.0.0)
at javax.swing.JFrame.JFrame() (/usr/lib/libgcj.so.6.0.0)
at java.lang.Class.newInstance() (/usr/lib/libgcj.so.6.0.0)
org.eclipse.jem.internal.proxy.initParser.tree.ExpressionPro cesser.pushClassInstanceCreation(java.lang.Class,
int) (Unknown Source)
org.eclipse.jem.internal.proxy.vm.remote.ExpressionProcesser Controller.process(java.io.DataInputStream)
(Unknown Source)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.p rocessExpressionCommand(org.eclipse.jem.internal.proxy.commo n.remote.Commands$ValueObject,
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler$I nvokableValueSender)
(Unknown Source)
(Unknown Source)
(Unknown Source)
...22 more
!ENTRY org.eclipse.jem.proxy 2 0 2006-02-02 01:11:29.020
!MESSAGE +++ Warning +++: Thu Feb 02 01:11:29 CET 2006 Project (GH)-VM
for GH:err>
Exception in thread "Thread-2" !ENTRY org.eclipse.jem.proxy 2 0
2006-02-02 01:11:29.359
for GH:err>
at org.eclipse.jem.internal.proxy.vm.remote.AWTStarter$1.run()
(Unknown Source)
...3 more
Re: ve doesn't display gui [message #116610 is a reply to message #116603] |
Thu, 02 February 2006 00:27 |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
There's something strange about the GTKToolkit you have on your system.
Either it can't be found or it is an incompatible version for the Java
JDK you are using.
Rich Kulp
Re: ve doesn't display gui [message #116638 is a reply to message #116615] |
Thu, 02 February 2006 11:38 |
hi
i know..but i also have the sun java runtime on my machine...how can i
tell eclipse to use the sun jre?
i start it with the option -vm /sun1.5.0_06/bin/java
geezmo
Re: ve doesn't display gui [message #116845 is a reply to message #116729] |
Fri, 03 February 2006 11:45 |
hi
thanks...i've found the option. window -> preferences -> java -> installed
jre ...there i specified the path of my sun java. now it works.
thanks a lot!!
greetes,
geezmo
Re: ve doesn't display gui [message #121350 is a reply to message #116615] |
Sun, 02 April 2006 09:36 |
Originally posted by: thunderaxiom.gmail.com
Jeff Myers skrev den 02-02-2006 01:43:
> You are using a GCJ Java runtime, which isn't supported by the VE.
> You'll need to switch to a Sun or IBM JRE to use the VE properly.
Just curious :) Could you elaborate a bit on why?
Thorbjørn
Re: ve doesn't display gui [message #611935 is a reply to message #116603] |
JDK you are using.
Rich Kulp
Re: ve doesn't display gui [message #611941 is a reply to message #116615] |
hi
geezmo
Re: ve doesn't display gui [message #611960 is a reply to message #116729] |
hi
thanks a lot!!
greetes,
geezmo
Re: ve doesn't display gui [message #612454 is a reply to message #116615] |
Thorbjørn
FUDForum. Page generated in 0.04643 seconds
