Home » Language IDEs » ServerTools (WTP) » unable to add tomcat installation
unable to add tomcat installation [message #116576] Wed, 06 July 2005 06:46 Go to next message
Originally posted by: joerg.eschke.net
I try to add a tomcat v5 to the Installed Server Runtime Environment within
the preferences but recieve "The Tomcat installation directory is not
correct. It does not point to a valid Tomcat installation." from the
wizard.
I am running 0.7m5 using the default tomcat 5 installation
provided by SuSE Linux 9.3
Any hints ?
How does the wizard determine a so called "valid" tomcat installation ?
Greets,
Joerg
Re: unable to add tomcat installation [message #116628 is a reply to message #116576] Wed, 06 July 2005 09:02 Go to previous messageGo to next message
The Tomcat support expects the Tomcat installation to be under a single
install directory, like what is found the tar.gz binary distributions
that can be downloaded from Apache Jakarta. I assume the problem is
that the Tomcat installation appears under multiple directories.
If you identify your directory structure, I may be able to suggest how
to trick the Tomcat support in to accepting that structure. You are
also welcome to file an enhancement request in the Bug database.
Larry
> wizard.
> Any hints ?
> Greets,
> Joerg
Re: unable to add tomcat installation [message #116641 is a reply to message #116628] Wed, 06 July 2005 09:16 Go to previous messageGo to next message
the directory structure look like this:
/usr/share/tomcat5/
bin
common
conf -> /srv/www/tomcat5/base/conf
logs -> /srv/www/tomcat5/base/logs
server
shared
temp -> /srv/www/tomcat5/base/temp
webapps -> /srv/www/tomcat5/base/webapps
work -> /srv/www/tomcat5/base/work
You are right, after installing a Tomcat .tar.gz binary distribution from
the Apache Jakarta Page everything works fine.
Joerg
> Cheers,
> Larry
>> within the preferences but recieve "The Tomcat installation directory is
>> not correct. It does not point to a valid Tomcat installation." from the
>> wizard.
>> Any hints ?
>> Greets,
>> Joerg
Re: unable to add tomcat installation [message #116670 is a reply to message #116628] Wed, 06 July 2005 10:27 Go to previous messageGo to next message
This is probably the reason. But in most distros (most means Debian is
this case ;) Tomcat installation is divided into multiple locations.
> Cheers,
> Larry
Tomasz 'Zen' Napierala
JID: tzn@jabber.org | GSM: 509694518
http://debian.linux.org.pl | http://www.alrauna.org
RLU: 312924 | Debian SID | Firefox 1.0
Re: unable to add tomcat installation [message #116682 is a reply to message #116641] Wed, 06 July 2005 10:41 Go to previous messageGo to next message
I don't have a *nix system to play with at the moment, so I can't say
exactly why the symlinks aren't being accepted. I'll see what I can
find out. I don't know of a reason not to try to make this work.
Larry
> /usr/share/tomcat5/
> bin
> common
> server
> shared
> Joerg
>>Cheers,
>>Larry
>>>wizard.
>>>Any hints ?
>>>Greets,
>>>Joerg
Re: unable to add tomcat installation [message #116768 is a reply to message #116682] Wed, 06 July 2005 11:49 Go to previous messageGo to next message
Hmm, the directory structure doesn't seem to be the problems cause.
Using a SuSE Linux 9.1 installation where the tomcat directory structure is
identically the wizard does his job as expected.
> Cheers,
> Larry
>> /usr/share/tomcat5/
>> bin
>> common
>> server
>> shared
>> Thanks,
>> Joerg
>>>Cheers,
>>>Larry
>>>>wizard.
>>>>Any hints ?
>>>>Greets,
>>>>Joerg
Re: unable to add tomcat installation [message #120517 is a reply to message #116576] Wed, 13 July 2005 14:53 Go to previous messageGo to next message
> wizard.
Me too. Only I just installed in W2K according to
http://download.eclipse.org/webtools/downloads/drops/S-1.0M5 -200506302219/
eclipse-SDK-3.1-win32.zip
emf-sdo-xsd-SDK-I200506230200.zip
GEF-SDK-3.1RC4.zip
JEM-SDK-I20050623.zip
wtp-1.0M5.zip.part
wtp-wst-1.0M5.zip
I have Tomcat 5.5.4 (tho the dir name says 5.0), the dir listing is
below. This Tomcat installation worked well with M4.
Please send me a hint, I'm stopped.
TIA
Juan Lanus
Directorio de E:\Tomcat 5.0
13/07/2005 15:46 <DIR> .
13/07/2005 15:46 <DIR> ..
09/01/2005 16:51 <DIR> bin
27/11/2004 10:29 <DIR> common
02/07/2005 19:18 <DIR> conf
26/11/2004 14:58 <DIR> copia de conf
10/06/2005 07:54 <DIR> doc
12/06/2005 11:43 <DIR> docs
29/10/2004 15:15 11.357 license
20/06/2005 09:15 <DIR> logs
29/10/2004 15:15 688 notice
29/10/2004 15:13 6.441 release-notes
27/11/2004 10:30 <DIR> server
27/11/2004 10:30 <DIR> shared
09/01/2005 16:47 <DIR> source
27/11/2004 10:30 <DIR> temp
29/10/2004 16:14 21.630 tomcat.ico
27/11/2004 10:30 66.710 uninstall.exe
27/11/2004 10:30 <DIR> webapps
27/11/2004 10:30 <DIR> work
27/11/2004 11:46 0 __esto es tomcat 5.5.4.txt
Re: unable to add tomcat installation [message #120531 is a reply to message #120517] Wed, 13 July 2005 15:32 Go to previous messageGo to next message
When I used E:\tomcat instead of E:\Tomcat 5.0 the error didn't show.
It's bug, because E:\Tomcat 5.0 is valid locatios. The default install
is C:\program ...\Tomcat 5.0 and I'm sure it will also fail.
Entering "E:\Tomcat 5.0" (with quotes) also failed.
Juan Lanus
Re: unable to add tomcat installation [message #157622 is a reply to message #116576] Sun, 22 January 2006 21:15 Go to previous messageGo to next message
Has the problem finally been solved? I just expereience the same problem
running wtp1.0 and tomcat5. i can't get the wizard to accept my
directory as valid.
thx
max
> wizard.
> Any hints ?
> Greets,
> Joerg
Re: unable to add tomcat installation [message #157710 is a reply to message #157622] Mon, 23 January 2006 12:58 Go to previous messageGo to next message
> directory as valid.
Does the layout of your Tomcat 5.0 directory differ from the layout
in the .zip/.tar files provided by Apache?
- Nitin
Re: unable to add tomcat installation [message #157755 is a reply to message #157710] Mon, 23 January 2006 18:25 Go to previous messageGo to next message
Tomcat 5.0 came along with my Fedora Core 4 installation. Actually all
folders are there in /usr/share/tomcat5 as in the tar.gz. the only
difference is that almost all of the directories are symbolic links.
Max
Nitin Dahyabhai wrote:
>> problem running wtp1.0 and tomcat5. i can't get the wizard to accept
>> my directory as valid.
> Does the layout of your Tomcat 5.0 directory differ from the layout in
Re: unable to add tomcat installation [message #157786 is a reply to message #157755] Mon, 23 January 2006 21:26 Go to previous message
I did a fresh install with tomcat 5.5 and now it works. So the problem
seems be related to the symbolic links.
Is this behaviour wanted?
Max
> Max
Previous Topic:Applet jar under WebContent
Next Topic:I think i found a bug
Current Time: Thu Apr 24 00:17:20 EDT 2025
Powered by FUDForum. Page generated in 0.03721 seconds
