Home » Eclipse Projects » Equinox » Invalid console port error in OSGI console
Invalid console port error in OSGI console [message #116357] Thu, 21 August 2008 06:03 Go to next message
Hello All,
I have built a command line RCP which works fine from my workspace but
giving error as "Invalid console port: {argument}" when some command line
arguments are passed. I am using eclipse europa and java 1.5.
when i run application in OSGI console -
app_cmdline -console
it runs fine. But when pass an argument (here a properties file)
app_cmdline -console test.properties
it fails and says "Invalid console port: test.properties"
Can anyone tell what could be the problem.
Thanks in advance. Regards,
Ramapriya
Re: Invalid console port error in OSGI console [message #117076 is a reply to message #116357] Wed, 03 September 2008 15:21 Go to previous message
-console has an optional port that comes after it on the command line.
If the argument following -console does not start with "-" then it is
interpreted as the port number.
Try changing the order of your arguments. Or maybe -console ""
-Andrew
Ramapriya wrote:
> Hello All,
> line arguments are passed. I am using eclipse europa and java 1.5.
> Ramapriya
Previous Topic:Launching equinox
Next Topic:Jetty + HTTPS
Current Time: Thu Oct 16 10:39:25 EDT 2025
Powered by FUDForum. Page generated in 0.03979 seconds
