Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Extra Primary Key Join Column
Extra Primary Key Join Column [message #116033] |
Thu, 27 March 2008 02:46 |
Originally posted by: pavata.vsp.com
I am having an issue related to Primary key join column in an inheritance
strategy "JOINED". There is a custom join column mapping using
@PrimaryKeyJoinColumn(name="MyColumnName") between a parent class and sub
class. But teneo code recognizes the parent class and adds another primary
key join column based on the annotaton @Id and the generated name is a
combination of ParentClassName_ColumnNameofIDColumn and gets truncated by
ClassicSQLNameStrategy (specific class the is performing this functionality
is . So I am ending up with two primary key join columns.
Can you guide me if there is an option by which I can stop this this extra
primary key join column getting added.
Thanks!!
- Pavan
Re: Extra Primary Key Join Column [message #116234 is a reply to message #116053] |
Thu, 27 March 2008 18:36 |
Hi Martin,
Here I am giving you both XSD and the hibernate mapping that are generated.
I have stripped out other info and giving here only the required.
Parent Class XSD mapping:
<xsd:complexType name="ConsumerAssociation" abstract="true">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">
@Table(name="CMR3603T",uniqueConstraints =
@UniqueConstraint(columnNames="CONSUMER_ASSCTN_SK"}))
@Inheritance(strategy=InheritanceType.JOINED) </xsd:appinfo>
</xsd:annotation>
<xsd:sequence>
<xsd:element name="consumerAssociationSK" type="xsd:int">
<xsd:annotation> <xsd:appinfo source="teneo.jpa">
@Id @Column(name="CONSUMER_ASSCTN_SK" nullable="false" insertable=false
updatable=false)
@GeneratedValue(strategy=SEQUENCE generator="SEQ_CMR3603T")
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
</xsd:complexType>
If I add an annotation @PrimaryKeyJoinColumn(name="CONSUMER_ASSCTN_SK") in
the child class, it throws an error while generating the hibernate mapping
as below and it doesn't even generate a hbm file:
org.hibernate.MappingException: Foreign key (FKBFC28A9A5E702277:member
[consumer_assctn_sk,cnsmersscitin_cnsmerasscitinsk])) must have same number
of columns as the referenced primary key (cmr3603t [consumer_assctn_sk])
But if I don't add the primary key join column in subclass, then it
generates the hbm file with a default join column as below:
<joined-subclass name="com.vsp.consumer.model.impl.MemberImpl"
entity-name="Member" abstract="false" lazy="false"
extends="ConsumerAssociation" table="member">
<meta attribute="eclassName">Member</meta>
<meta attribute="epackage">http://model.consumer.vsp.com</meta>
<key>
<column name="cnsmersscitin_cnsmerasscitinsk"/>
</key>
But I would rather want to have a custom column name above.
Let me know if you want more details.
- Pavan
"Martin Taal" <mtaal@elver.org> wrote in message
news:fsfnpi$shd$1@build.eclipse.org...
> Hi Pavan,
> Seems like a bug, can you post the mapping of the subclass? Then I can see
> how it is mapped.
> gr. Martin
> Pavan Tata wrote:
>> inheritance strategy "JOINED". There is a custom join column mapping
>> using @PrimaryKeyJoinColumn(name="MyColumnName") between a parent class
>> and sub class. But teneo code recognizes the parent class and adds
>> another primary key join column based on the annotaton @Id and the
>> generated name is a combination of ParentClassName_ColumnNameofIDColumn
>> and gets truncated by ClassicSQLNameStrategy (specific class the is
>> performing this functionality is . So I am ending up with two primary key
>> join columns.
>> extra primary key join column getting added.
>> Thanks!!
>> - Pavan
> With Regards, Martin Taal
> Springsite/Elver.org
> Office: Hardwareweg 4, 3821 BV Amersfoort
> Postal: Nassaulaan 7, 3941 EC Doorn
> The Netherlands
> Tel: +31 (0)84 420 2397
> Fax: +31 (0)84 225 9307
> Mail: mtaal@springsite.com - mtaal@elver.org
> Web: www.springsite.com - www.elver.org
Re: Extra Primary Key Join Column [message #116247 is a reply to message #116234] |
Thu, 27 March 2008 19:35 |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Pavan,
Okay thanks, can you enter a bugzilla for this?
Teneo currently only tests for the primarykeyjoincolumn in case of a one-to-one it is clear that
also the superclass case should be tested (and work properly).
gr. Martin
Pavan Tata wrote:
> Hi Martin,
> <xsd:annotation>
> </xsd:annotation>
> <xsd:sequence>
> updatable=false)
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> </xsd:complexType>
> <key>
> </key>
> - Pavan
>> Hi Pavan,
>> how it is mapped.
>> gr. Martin
>> Pavan Tata wrote:
>>> Hi,
>>> join columns.
>>> Thanks!!
>>> - Pavan
>> The Netherlands
The Netherlands
Re: Extra Primary Key Join Column [message #616017 is a reply to message #116053] |
Hi Martin,
<xsd:annotation>
</xsd:annotation>
<xsd:sequence>
updatable=false)
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
</xsd:complexType>
<key>
</key>
- Pavan
> Hi Pavan,
> how it is mapped.
> gr. Martin
> Pavan Tata wrote:
>> join columns.
>> Thanks!!
>> - Pavan
> The Netherlands
Re: Extra Primary Key Join Column [message #616018 is a reply to message #116234] |
Hi Pavan,
gr. Martin
Pavan Tata wrote:
> Hi Martin,
> <xsd:annotation>
> </xsd:annotation>
> <xsd:sequence>
> updatable=false)
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> </xsd:complexType>
> <key>
> </key>
> - Pavan
>> Hi Pavan,
>> how it is mapped.
>> gr. Martin
>> Pavan Tata wrote:
>>> Hi,
>>> join columns.
>>> Thanks!!
>>> - Pavan
>> The Netherlands
The Netherlands
Current Time: Sun Oct 06 07:09:07 GMT 2024
Powered by FUDForum. Page generated in 0.03500 seconds
