problem opening a new editor on double click [message #115945] |
Mon, 02 April 2007 06:50 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: bhatia1984.yahoo.com
hiiii
I am trying to open a new editor on double click of diagram element.I am
able to do that but the problen is when i reopen that editor again on
double click a new editor window gets open even if the previous window
which gets open on double click is already open.
i am not able to figure what went wrong
pls help me
varun Bhatia
Re: problem opening a new editor on double click [message #115977 is a reply to message #115945] |
Mon, 02 April 2007 07:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: Stefan.Warwas.freenet.de
there was a discussion about this problem 1 or 2 weeks ago. I can not
remember the name of the thread but somebody provided a simple solution
for it.
Stefan
varun schrieb:
> hiiii
> pls help me
> Thanks
> varun Bhatia
Re: problem opening a new editor on double click [message #115990 is a reply to message #115977] |
Mon, 02 April 2007 07:23 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
hi stefan
I know there was disussion on this topic but i am not able to find that &
my editor was not showing that strange behaviour before. But today when i
started my editor again it showing that strange behaviour.Cn u pls help me.
thanks
Varun
Re: problem opening a new editor on double click [message #116015 is a reply to message #116003] |
Mon, 02 April 2007 10:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
hi stefan
Thanks for ur help.I have made the changes bt i am getting exception now &
one thing i want to know that why that is happening now when this bug is
fixed.
Also one more thing it was not happeing before but today when i again open
my editor to work on it this bug came.
This is the exception i am getting now on double click:
org.eclipse.core.runtime.CoreException: ERROR
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.createPartControl(DiagramDocumentEditor. java:1458)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:596)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:214)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2588)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2521)
org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2513)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2498)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2493)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2470)
com.siemens.ctindia.gmf.tde.packages.diagram.edit.policies.O penDiagramEditPolicy$OpenDiagramCommand.doExecuteWithResult( OpenDiagramEditPolicy.java:121)
org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTr ansactionalCommand.doExecute(AbstractTransactionalCommand.ja va:246)
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:127)
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:509)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:205)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:168)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:155)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.performRequest(GraphicalEditPart.java:1060)
org.eclipse.gef.tools.SelectEditPartTracker.performOpen(Sele ctEditPartTracker.java:187)
org.eclipse.gef.tools.SelectEditPartTracker.handleDoubleClic k(SelectEditPartTracker.java:131)
org.eclipse.gef.tools.AbstractTool.mouseDoubleClick(Abstract Tool.java:944)
org.eclipse.gef.tools.SelectionTool.mouseDoubleClick(Selecti onTool.java:501)
at org.eclipse.gef.EditDomain.mouseDoubleClick(EditDomain.java: 204)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse DoubleClicked(DomainEventDispatcher.java:285)
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseDoubl eClick(LightweightSystem.java:508)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:141)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Varun Bhatia
Re: problem opening a new editor on double click [message #120056 is a reply to message #116381] |
Wed, 18 April 2007 04:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
hi alex
Sorry for such a late reply.
I am not able to connect to cvs using eclipse due to firewall.so i just
want to know in which cvs & in whcih proj i can find ecore diagarm sample
source.
Pls help me
varun
Re: problem opening a new editor on double click [message #120672 is a reply to message #115945] |
Thu, 19 April 2007 11:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
hi alex
i am once again reframing my ques so that i am able to explain myself
better.
My ques was ...
after generating diagram code i invoke an instance of eclipse application.
then i open my gmf editor.on double click of a daiagram element i open
another eitor.
Now i close the eclipse apllication.
Now i once againg invoke eclipse application.
Now what i found is that on both the editor diagarm element of former
editor (i.e editor from which i invoke double click) will be there & now
when i double click on the diagarm element of the editor a new editor gets
opened having diagarm element of later editor.
pls help me.
i have to do it urgently
Varun
Re: problem opening a new editor on double click [message #121439 is a reply to message #121293] |
Tue, 24 April 2007 09:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
hi alex
i hv checked my ???matchingstrategy class after making the changes u told
earlier in matching strategy class.
what i am getting in matches(IEditorReference editorRef, IEditorInput
input)
here input is of type :- DiagramEditorInput whereas
editorInput = editorRef.getEditorInput();
this line return editor input as of type :- FileEditorInput.
so it doesnt enter into the loop :
if (editorInput instanceof URIEditorInput && input instanceof
URIEditorInput)
& always false is returned.
also this is what is written in my doexecutewithresult method in
opendiagram policy
protected CommandResult doExecuteWithResult(IProgressMonitor monitor,
IAdaptable info) throws ExecutionException {
try {
Diagram diagram = getDiagramToOpen();
if (diagram == null) {
diagram = intializeNewDiagram();
final DiagramEditorInput editorInput = new DiagramEditorInput(
diagram);
IWorkbenchPage page = PlatformUI.getWorkbench()
.getActiveWorkbenchWindow().getActivePage();
page.openEditor(editorInput, getEditorID());
return CommandResult.newOKCommandResult();
} catch (Exception ex) {
throw new ExecutionException("Can't open diagram", ex);
thanks
varun
FUDForum. Page generated in 0.04691 seconds
