How to insert a menu by VE [message #115772] |
Tue, 24 January 2006 19:27 |
Originally posted by: alexandre.gzsistemas.com.br
Hi all,
I'm trying to insert a menu into a Shell but I can't find how to do it.
I've searched on newsgroups, helps, but I didn't find a solution.
Can anyone help me ?
Re: How to insert a menu by VE [message #115784 is a reply to message #115772] |
Tue, 24 January 2006 19:53 |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Drop a menubar on the shell. Then you can drop menus on the menubar in
the JavaBeans viewer.
Alexandre Boaventura wrote:
> Hi all,
Rich Kulp
Re: How to insert a menu by VE [message #115847 is a reply to message #115784] |
Wed, 25 January 2006 12:02 |
Rich Kulp escreveu:
>> Hi all,
>> it. I've searched on newsgroups, helps, but I didn't find a solution.
Well, a menubar component is not available at swt pallete. What could be
wrong ?
Re: How to insert a menu by VE [message #115859 is a reply to message #115835] |
Wed, 25 January 2006 12:03 |
Enric Tordera escreveu:
> "Alexandre Boaventura" <alexandre@gzsistemas.com.br> escribió en el mensaje
> news:dr5v38$3s7$1@utils.eclipse.org...
>> Hi all,
> Make sure you are using the last version of Visual Editor. If not sure try
> updating from the Help menu.
> Enric
I suppose I'm using the latest version because I downloaded and
installed from Update Manager yesterday !
Re: How to insert a menu by VE [message #115871 is a reply to message #115859] |
Wed, 25 January 2006 15:20 |
Just check and make sure that you have VE 1.1.0.1 installed if you are
working on Eclipse 3.1.x. If you just did an install for the first time
of VE from the update manager it will pick up VE 1.1.0. You will need to
run update again to get it up to 1.1.0.1.
VE 1.1.0.1 has a palette category labeled SWT Menus.
Rich Kulp
Re: How to insert a menu by VE [message #115884 is a reply to message #115871] |
Wed, 25 January 2006 18:44 |
Rich Kulp escreveu:
Thank you Rich.
Now it works !
Re: How to insert a menu by VE [message #611821 is a reply to message #115772] |
> Hi all,
Rich Kulp
Re: How to insert a menu by VE [message #611837 is a reply to message #115859] |
Rich Kulp
FUDForum. Page generated in 0.04193 seconds
