Re: occurrences feature not working for variables/functions [message #10593 is a reply to message #10560] |
Wed, 28 March 2007 22:51 |
Originally posted by: hertzel.hotmail.com
Joshua Ross wrote:
> One of the features I am having a hard time living without from PHPEclipse
> is the occurrences feature. The occurrences feature was/is the same as in
> the Java editor. Basically, a single click on a variable or function
> "highlights" the variable/function and displays an indicator in the
> occurrences(annotations?) bar of all occurrences of that variable/function.
> The occurrences bar is the same vertical bar at the rightmost of the editor
> window that shows the occurrences of all TODO tags and errors amongst other
> items. I think this funcitonality is part of eclipse's default editor
> however it isn't working for me in PDT.
> Relevant information
> PDT - Nightly build (N20070325)
> Eclipse (3.2.2r322_v20070104)
> Windows XP
> Java 6(relevant? probably not)
> Any chance we can get this working in PDT? It would be greatly appreciated.
> -Joshua-
I'm missing that function too..is really useful
Re: occurrences feature not working for variables/functions [message #10626 is a reply to message #10593] |
Thu, 29 March 2007 16:42 |
Originally posted by: pavel.kunc.google.com
On Thu, 29 Mar 2007 00:51:23 +0200, Hertzel Armengol <hertzel@hotmail.com>
wrote:
>> PHPEclipse is the occurrences feature. The occurrences feature was/is
>> the same as in the Java editor. Basically, a single click on a
>> variable or function "highlights" the variable/function and displays an
>> indicator in the occurrences(annotations?) bar of all occurrences of
>> that variable/function. The occurrences bar is the same vertical bar at
>> the rightmost of the editor window that shows the occurrences of all
>> TODO tags and errors amongst other items. I think this funcitonality
>> is part of eclipse's default editor however it isn't working for me in
>> PDT.
>> Windows XP
>> appreciated.
>> Thanks,
>> -Joshua-
I also miss this feature. I think that in PHPEclipse is also possible
setup of code checker to mark defined but non-used variables as
notice/warning/error. This is usefull to eliminate or easy find typos in
variables.
Pavel
FUDForum. Page generated in 0.04458 seconds
