how to shut off the reverse-parser? [message #115320] |
Mon, 16 January 2006 05:44  |
Originally posted by: dbhomers.becker-print-soft.com
How can i shut off the Update-Process of the VE?
If i must change a lot, this process slow down my work cause it updates
after every char i changed.
thanks for helping!
Re: how to shut off the reverse-parser? [message #115350 is a reply to message #115320] |
Mon, 16 January 2006 09:15  |
Dirk,
There's a pause button on the toolbar - it looks like two yellow
vertical rectangles, and has the tooltip that says "Pause". This halts
the reverse parser so that you can make significant changes to the
source. When you're done making changes click the button again to have
the visual model sync up with the source again.
Hope this helps,
- Jeff
Re: how to shut off the reverse-parser? [message #611787 is a reply to message #115320] |
Dirk,
Hope this helps,
- Jeff
FUDForum. Page generated in 0.02975 seconds
