Home » Archived » Visual Editor (VE) » How to instal VE in Eclipse 3.1
How to instal VE in Eclipse 3.1 [message #115300] Mon, 16 January 2006 04:36 Go to next message
Originally posted by: neelakantan_k.infosys.com
hi,
I Unziped the EMF and GEF and the VE zip files into my Eclispe folder.Then
i started the eclipse with eclipse.exe -clean ,but still the Plugin is not
installed.
Any clue.
Neel
Re: How to instal VE in Eclipse 3.1 [message #115374 is a reply to message #115300] Mon, 16 January 2006 10:38 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
What versions of EMF, GEF, and VE did you use? Also you don't unzip into
the "eclipse" folder. You unzip only level up because the zip files
already contain "eclipse" as the root folder.
Plus if you are trying to install VE onto Eclipse 3.1, it is better to
use the update manager than to do unzips. That way all of the prereqs
will be taken care of correctly. However, if you do install using the
update manager, add
http://update.eclipse.org/tools/ve/updates/1.0/
As a discovery udpate site. That way you will the latest released VE
that works on Eclipse 3.1.
Neel wrote:
> hi,
> folder.Then i started the eclipse with eclipse.exe -clean ,but still the
> Plugin is not installed.
> Any clue.
> Neel
Rich Kulp
Re: How to instal VE in Eclipse 3.1 [message #115965 is a reply to message #115374] Thu, 26 January 2006 13:16 Go to previous message
Originally posted by: felipe-martins.procergs.rs.gov.br
I've tried install VE on my Eclipse 3.1 and I cannot use it too. Had
appeared to me a message: An internal error occurred during: "Setup Java
Visual Editor". In the Exception Stack Trace had been shown
java.lang.NoClassDefFoundError:
org/eclipse/emf/ecore/util/EcoreEList$UnmodifiableEList$Fast Compare.
I found out that when I use VE with Eclipse Modeling Framework (EMF)
Version: 2.1.1 the VE doesn't work. So I disabled the version 2.1.1 and I
changed by 2.1.0 and the VE starts to work.
However, now I cannot drop a shell from the palette to the editor. Nothing
happens. I was not able to pass from this point....
(Sorry my english)
Felipe.
Re: How to instal VE in Eclipse 3.1 [message #611789 is a reply to message #115300] Mon, 16 January 2006 10:38 Go to previous message
update manager, add
Neel wrote:
> hi,
> Any clue.
> Neel
Rich Kulp
Re: How to instal VE in Eclipse 3.1 [message #611863 is a reply to message #115374] Thu, 26 January 2006 13:16 Go to previous message
(Sorry my english)
Felipe.
Previous Topic:ve creates widgets by itself
Next Topic:widget properties problem
Current Time: Wed Apr 16 01:38:10 EDT 2025
Powered by FUDForum. Page generated in 0.03414 seconds
