| Unnecessary resetting of object references [message #114851] |
Sun, 16 March 2008 09:33  |
Hi Martin,
in the context of another problem I had with the generated gmf source (for
a detailed description look at my question in the gmf group) I discovered
that the EReferencePropertyHandler.set() does a reset of an object even if
the new object is the same as the old one.
If the reference is not bidirectional the current source lines are
if (curValue == null && value == null) {
return; // do nothing in this case
Could this be replaced by something like this
if (curValue == value) {
without any harm?
Best regards
Manfred
| Re: Unnecessary resetting of object references [message #114865 is a reply to message #114851] |
Sun, 16 March 2008 14:11  |
Hi Manfred,
Yes no problem, I will make the change. There will probably be a new build today. Btw, I also worked
on the GMF-teneo integration incl. persisting the diagram. I will probably publish a new tutorial
today also.
gr. Martin
Manfred Hahn wrote:
> Hi Martin,
> (for a detailed description look at my question in the gmf group) I
> discovered that the EReferencePropertyHandler.set() does a reset of an
> object even if the new object is the same as the old one.
> without any harm?
> Best regards
> Manfred
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: Unnecessary resetting of object references [message #615893 is a reply to message #114851] |
Hi Manfred,
today also.
gr. Martin
Manfred Hahn wrote:
> Hi Martin,
> without any harm?
> Best regards
> Manfred
The Netherlands
FUDForum. Page generated in 0.75558 seconds
