Home » Eclipse Projects » Remote Application Platform (RAP) » Failed to register resource if 2 session start simultaneously
Failed to register resource if 2 session start simultaneously [message #114611] |
Fri, 05 December 2008 16:10 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Enrico Zanaga![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ezanaga%40efsw.it) Messages: 50 Registered: July 2009 |
Member |
I've deployed a RAP 1.2.0M3 application on Tomcat 5.5 and I've created a
Windows batch file that starts two Internet Explorer opening the url of
the application. The batch file looks like:
start iexplore.exe http://127.0.0.1:8080/rap
One IE runs correctly, while the other one shows a
ResourceRegistrationException, I've reported the stack trace on the bottom.
The exception throws random on one IE only.
This is the method ResourceManagerImpl.doRegister:
private void doRegister( final String name,
final String charset,
final RegisterOptions options )
String key = createKey( name );
// TODO [rh] should throw exception if contains key but has different
// charset or options
if( !repository.containsKey( key ) ) {
boolean compress = shouldCompress( options );
try {
int[] content = ResourceUtil.read( name, charset, compress );
doRegister( name, charset, options, key, content );
} catch ( IOException e ) {
String text = "Failed to register resource ''{0}''.";
String msg = MessageFormat.format( text, new Object[] { name } );
throw new ResourceRegistrationException( msg, e ) ;
repository.put( key, name );
The access at "repository" map should be synchronized?
Or maybe synchronized another method that calls
ResourceManagerImpl.register and ResourceManagerImpl.doRegister, like
QooxdooResourcesUtil.registerResources?
Enrico
----- Exception stack trace: -----
org.eclipse.rwt.internal.resources.ResourceRegistrationExcep tion: Failed
to register resource 'resource/static/history/historyHelper.html'.
org.eclipse.rwt.internal.resources.ResourceManagerImpl.doReg ister(ResourceManagerImpl.java:411)
org.eclipse.rwt.internal.resources.ResourceManagerImpl.regis ter(ResourceManagerImpl.java:214)
org.eclipse.swt.internal.widgets.displaykit.QooxdooResources Util.registerResources(QooxdooResourcesUtil.java:149)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.write Libraries(DisplayLCA.java:297)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCAFacade Impl.writeLibrariesInternal(DisplayLCAFacadeImpl.java:31)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCAFacade .writeLibraries(DisplayLCAFacade.java:36)
org.eclipse.rwt.internal.lifecycle.DisplayUtil.writeLibrarie s(DisplayUtil.java:66)
org.eclipse.rwt.internal.service.LifeCycleServiceHandlerConf igurer.getLibraries(LifeCycleServiceHandlerConfigurer.java:2 01)
org.eclipse.rwt.internal.service.LifeCycleServiceHandlerConf igurer.getTemplateOfStartupPage(LifeCycleServiceHandlerConfi gurer.java:61)
org.eclipse.rwt.internal.service.BrowserSurvey.renderScript( BrowserSurvey.java:89)
org.eclipse.rwt.internal.service.BrowserSurvey.sendBrowserSu rvey(BrowserSurvey.java:50)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.int ernalService(LifeCycleServiceHandler.java:197)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.acc ess$1(LifeCycleServiceHandler.java:185)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler$Lif eCycleServiceHandlerSync.doService(LifeCycleServiceHandler.j ava:150)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.serviceInternal(RWTLifeCycleServiceHandlerSync.java:45 )
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.service(RWTLifeCycleServiceHandlerSync.java:33)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.ser vice(LifeCycleServiceHandler.java:157)
org.eclipse.rwt.internal.service.ServiceManager$HandlerDispa tcher.service(ServiceManager.java:101)
org.eclipse.rwt.internal.engine.RWTDelegate.doPost(RWTDelega te.java:63)
org.eclipse.rwt.internal.engine.RWTDelegate.doGet(RWTDelegat e.java:45)
javax.servlet.http.HttpServlet.service(HttpServlet.java:627)
javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
Re: Failed to register resource if 2 session start simultaneously [message #114628 is a reply to message #114611] |
Fri, 05 December 2008 17:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Member |
Sorry,
follows the full stack trace of the exception:
to register resource 'org/eclipse/swt/browser/Browser.js'.
org.eclipse.rwt.internal.resources.ResourceManagerImpl.regis ter(ResourceManagerImpl.java:224)
org.eclipse.swt.internal.widgets.displaykit.QooxdooResources Util.register(QooxdooResourcesUtil.java:262)
org.eclipse.swt.internal.widgets.displaykit.QooxdooResources Util.registerResources(QooxdooResourcesUtil.java:205)
at org.eclipse.rwt.internal.engine.RWTDelegate.doPost(RWTDelega te.java:63)
at org.eclipse.rwt.internal.engine.RWTDelegate.doGet(RWTDelegat e.java:45)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:627)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:269)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:188)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:172)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:117)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:108)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:174)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:875)
org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:665)
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:528)
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:81)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:689)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.io.IOException: Could not create directory structure:
C:\Program Files (x86)\Apache Software Foundation\Tomcat
5.5\webapps\wf\org\eclipse\swt\browser
org.eclipse.rwt.internal.resources.ResourceManagerImpl.creat eFile(ResourceManagerImpl.java:444)
org.eclipse.rwt.internal.resources.ResourceManagerImpl.doReg ister(ResourceManagerImpl.java:427)
org.eclipse.rwt.internal.resources.ResourceManagerImpl.doReg ister(ResourceManagerImpl.java:407)
... 36 more
Enrico Zanaga ha scritto:
> Hi
> try {
> Thanks
> Enrico
Re: Failed to register resource if 2 session start simultaneously [message #114911 is a reply to message #114611] |
Tue, 09 December 2008 10:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: rherrmann.innoopract.com
thanks for pointing that out. From looking at the code, I agree with
your assumption.
Could you file a bugzilla so that we can track progress on this issue?
Rüdiger
Enrico Zanaga wrote:
> Hi
> try {
> Thanks
> Enrico
Re: Failed to register resource if 2 session start simultaneously [message #115211 is a reply to message #114911] |
Wed, 10 December 2008 09:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Member |
https://bugs.eclipse.org/bugs/show_bug.cgi?id=258246
Enrico
Rüdiger Herrmann ha scritto:
> your assumption.
> Thanks
> Rüdiger
>> Hi
>> a Windows batch file that starts two Internet Explorer opening the url
>> of the application. The batch file looks like:
>> bottom.
>> try {
>> Thanks
>> Enrico
>> Failed to register resource 'resource/static/history/historyHelper.html'.
Current Time: Sat Jul 27 12:46:17 GMT 2024
Powered by FUDForum. Page generated in 0.03880 seconds
