Eclipse crash at startup [message #114406] |
Thu, 03 November 2005 10:25  |
Originally posted by: ivan.elabor.homelinux.org
Hi all!
I'm new in Eclipse. I have a SPARC architecture, with suse 9.3. I have
installed eclipse using yast installation tool and dependencies are met.
When I start eclipse I receive the following message:
!SESSION Nov 03, 2005 16:11:51.574
eclipse.buildId=200409161125
java.version=1.5.0_03
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
!ENTRY org.eclipse.osgi Nov 03, 2005 16:11:51.580
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: /usr/lib/eclipse/libswt-pi-gtk-3063.so:
/usr/lib/eclipse/libswt-pi-gtk-3063.so: cannot open shared object file: No
such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1751)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1660)
at java.lang.Runtime.loadLibrary0(Runtime.java:822)
at java.lang.System.loadLibrary(System.java:992)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
and so on...
Now I found libswt-pi-gtk-3063.so inside /usr/lib/eclipse and I tried to
run
ldd libswt-pi-gtk-3063.so
to check dependencies but it's all ok.
What can I do now?
Thank you very much, =)
Ivan
Re: Eclipse crash at startup [message #114647 is a reply to message #114607] |
Fri, 04 November 2005 02:42   |
Shame on me!
No, I have *not* a SPARC architecture! I have a sun machine and when I ask
uname -a
I got:
Linux sun 2.6.11.4-21.9-default #1 Fri Aug 19 11:58:59 UTC 2005 x86_64 x86_64
x86_64 GNU/Linux
Sorry for the mistake!
Now, what can I do? Any hint for me? :)
Many thanks,
Ivan
Billy Biggs wrote:
> Ivan wrote:
>> Hi all!
> Are you sure you have a SPARC architectures? :)
> The eclipse you are using thinks it is on x86.
> Eclipse.org does not provide a Linux/SPARC build of the Eclipse SDK,
> but you could file a bug against "Platform > Releng" requesting one.
> -Billy
Re: Eclipse crash at startup [message #114846 is a reply to message #114647] |
Fri, 04 November 2005 15:13   |
Ivan Ricotti wrote:
> Shame on me!
> uname -a
> I got:
> x86_64 x86_64 GNU/Linux
> Many thanks,
> Ivan
> Billy Biggs wrote:
>> Ivan wrote:
>>> Hi all!
>>> have installed eclipse using yast installation tool and dependencies
>>> are met.
>> -Billy
did u try mine?
regards Astrid
Re: Eclipse crash at startup [message #114946 is a reply to message #114647] |
Sat, 05 November 2005 00:20  |
Originally posted by: bbiggs.ca.ibm.com
> uname -a
> I got:
For running Eclipse on x86-64, you need to have all of these match:
JVM -- Eclipse -- GTK+/system libraries
So, if you're using an x86-64 JVM, you need the x86-64 Eclipse and
x86-64 GTK+.
If you're using an x86 JVM, you need x86 Eclipse and x86 GTK+.
Probably, one of those is not correct on your system, and so Eclipse
fails to launch.
-Billy
FUDForum. Page generated in 0.10887 seconds
