Re: strange behavior with transparent png-file [message #114396 is a reply to message #114300] |
Thu, 04 December 2008 14:51 |
Originally posted by: rsternberg.innoopract.com
Hi Roland,
transparent shells are not supported yet. The shell has a background
color that shines through your transparent image. Maybe
Shell#setOpacity() is of any help for your case?
Otherwise feel free to file a bug report if you need transparent shells.
Best regards, Ralf
Roland Siebert wrote:
> I have tried it with css.
> Shell {
> border: 0px;
> background-color: transparent;
> But i get an IllegalArgumentException: "Transparency not allowed for key
> shell.background"
> Roland
Re: strange behavior with transparent png-file [message #114602 is a reply to message #114542] |
Fri, 05 December 2008 15:11 |
> Hmm.
> I don't find this method for Shell.
I'm sorry, it's called setAlpha().
Ralf
> Roland
> Ralf Sternberg schrieb:
>> Hi Roland,
>> Best regards, Ralf
Re: strange behavior with transparent png-file [message #122147 is a reply to message #122056] |
Fri, 20 February 2009 15:22 |
Hi Roland,
with the new generic CSS theming engine, Shells can now have a
transparent background:
Shell {
So there's no need to mess around with private fields ;-)
Ralf
> I found a way to set the background of the Shell to transparent.
> In org.eclipse.swt.widgets.Control I found "private boolean
> backgroundTransparency;" and changed it to protected.
> When I now set "backgroundTransparency=true" and
> setBackgroundMode(SWT.INHERIT_FORCE) before adding some other content
> (like Composites) to this Shell the background is transparent.
> Could you have a look at this and perhabs make this change also in cvs?
> Roland
FUDForum. Page generated in 0.04698 seconds
