PDF output broken since upgrade to 2.0RC2 [message #114088] |
Tue, 24 January 2006 12:55 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mlorenz.nc.rr.com
Under 1.0.1, PDF output worked (with known bugs such as no line wrap).
Since I upgraded to 2.0RC2, I do not get any output if I pick PDF as the
format (HTML does have output).
Any ideas what might be the problem? I've looked at other advice on the
newsgroup, but I have not found anything that solves my problem.
Thanks for any help.
Mark
Re: PDF output broken since upgrade to 2.0RC2 [message #114442 is a reply to message #114088] |
Tue, 24 January 2006 14:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Mark,
Have you tried relese 2.0? Make sure you get the iText jar in the correct
place.
Also verify the size of iText jar file. Should be over 1 MB.
Jason
"Mark Lorenz" <mlorenz@nc.rr.com> wrote in message
news:ed976dca4cba4b5405c5949f68e0d714$1@www.eclipse.org...
> Mark
Re: PDF output broken since upgrade to 2.0RC2 [message #115518 is a reply to message #114442] |
Wed, 25 January 2006 12:37 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
No I had not - didn't see it was available! I'll definitely try that.
I *am* using the larger iText jar file (just fixed that yesterday ...
should probably be an installation note about this, since multiple people
have had the problem of the wrong jar - the iText download page is
misleading as to which file to get).
Mark
FUDForum. Page generated in 0.06060 seconds
