Home » Eclipse Projects » Equinox » Does server-side equinox support to be deployed in WebSphere6.1?
Does server-side equinox support to be deployed in WebSphere6.1? [message #114046] Mon, 14 July 2008 00:46 Go to next message
Originally posted by: jeffidea.hotmai.com
I heard about that WebSphere6.1 base on equinox, and it's servlet
container is an osgi entironment, so does server-side equinox support to
Re: Does server-side equinox support to be deployed in WebSphere6.1? [message #114056 is a reply to message #114046] Mon, 14 July 2008 03:23 Go to previous messageGo to next message
Simon Kaegi is currently offline Simon KaegiFriend
Yes. The servletbridge has been formally tested with the most common app
servers (including WAS 6.1) and AFAIK should work with any app server or
servlet container.
"Jeff" <jeffidea@hotmai.com> wrote in message
news:168623e984a5d1850d1b52af57265f8f$1@www.eclipse.org...
>I heard about that WebSphere6.1 base on equinox, and it's servlet container
>is an osgi entironment, so does server-side equinox support to be deployed
>in WebSphere6.1?
Re: Does server-side equinox support to be deployed in WebSphere6.1? [message #114064 is a reply to message #114056] Mon, 14 July 2008 06:47 Go to previous messageGo to next message
Thank you Simon Kaegi:
So does that means osgi entironment can hold another osgi entironment as a
bundle? That will be an extremely complex classloader mechanism!
Are you sure:)?
And is there any limitation of the depth of osgi-nesting?
Re: Does server-side equinox support to be deployed in WebSphere6.1? [message #114071 is a reply to message #114064] Mon, 14 July 2008 14:17 Go to previous message
> So does that means osgi entironment can hold another osgi environment as a
It's probably not as complex as you think. The bundle class loaders are not
arranged hierarchically so that within a particular instance of the
framework things look fairly much the same regardless if you're in the nth
nested framework or a top-level instance.
> Are you sure:)? Positive :)
There's nothing in the framework that would prevent an arbitrary depth
however I don't this has been investigated much beyond about 5 nestings
though. On the other hand I've run 100s of top-level instances of the
framework in one process so don't see this necessarily being a problem.
-Simon
Previous Topic:UserAdmin wrong password data after restart equinox
Next Topic:problems with chmod touchpoint action
Current Time: Mon Dec 30 16:20:20 GMT 2024
Powered by FUDForum. Page generated in 0.03255 seconds
